Any truth to computer relearning your driving style?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FishingPups, Jun 25, 2019.
  1. Jun 27, 2019 at 5:24 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I know nothing about how the ECU "learns" but was proven in the HP Tuners thread that the 2012-15 Tacomas have softer throttle, fuel and ignition mapping than the earlier trucks. When I HP Tuned my lifted, armored, bigger tired 2014, it felt at least as lively as my wife's stock 2006 but was an absolute dog before it. HP Tuners is worth the money!
  2. Jun 27, 2019 at 6:27 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I don't know if there's a difference between pulling the ground strap off of the battery and waiting x number of mins. or doing what follows:
    From toyotanation.com - Dealer tech
    Disconnect the battery ground and wait 10 seconds. Touch the ground to the positive and hold there for 10 seconds. Wait 5 minutes. Repeat the ground to positive for 10 seconds and then reconnect. This puts it into learn mode. Take it on an aggressive test drive on a freeway.
    From tacomaworld.com - Dealer tech - did not agree with the "aggressive test drive" mentioned above. Here are his comments:
    Doing the battery cable stuff will erase the memory, but you don't want to do an aggressive test drive. You want to let it warm up fully after starting, then drive with light to more moderate throttle in a stop & go pattern. Like a neighborhood. This allows the ecu to learn how much time is needed to shift each gear as it compensates for wear in the transmission. After about 10 miles, you're done. Then you can drive how you please. You never want hard throttle during any relearn because all memory has been erased, shifting, knock learn, ignition timing, fuel trim. Everything's been set to base setting & hard throttle will not learn anything because it's going to max out all values to produce maximum engine torque.
    In cases where the battery cables are not long enough to reach one another, a jumper wire may need to be connected.
  3. Jun 27, 2019 at 5:51 PM
    FishingPups
    FishingPups [OP] Well-Known Member
    Barry
    2014 Tacoma TRD Sport Access Cab
    Prerunner, Towing Package, Convenience Package, Tonneau Cover
    "It is how fast you speed up" - Exactly what I am experiencing.
    "If you want your shift points to be more aggressive , you will have to dig into the gas pedal for a while" - And that is exactly what I am doing and as of today I am starting to notice a bit of a difference in how it shifts. I am going to continue this pattern for awhile.
    ImMrCrash likes this.
  4. Jun 27, 2019 at 6:43 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    The ECU doesn’t adapt to you, only a set of parameters that it’s given. More fuel, air, etc it adjusts.
    A lot of owners think Tacoma’s have some kind of built in AI, that’s not the case.
  5. Jun 27, 2019 at 6:46 PM
    FishingPups
    Barry
    But if the parameters change, doesn't it adjust over time?
  6. Jun 27, 2019 at 6:52 PM
    FishingPups
    Barry
    On the Ford I have when you disconnect the battery, there is a tech pub that states to expect some rough shifts until it relearns. And that is every time you disconnect the battery. I have experienced this first hand. It states that it takes about 250 to 500 miles to settle in the fuel/air/timing according to how it is driven.
  7. Jun 27, 2019 at 6:54 PM
    Grossomotto
    2017 4WDV6LB6MT
    From the 3rd Gen gurus and OVTune guys and everything I’ve read is there’s like three sets of parameters the ECU can use, just depends on the input (mostly the gas pedal). It’s constantly changing, it doesn’t remember you, per se.
  8. Jun 27, 2019 at 6:56 PM
    FishingPups
    Barry
    I think we are speaking the same language. I know it doesn't remember me. But it remembers or adjusts to how it is driven.
  9. Jun 27, 2019 at 7:05 PM
    Grossomotto
    2017 4WDV6LB6MT
    Yes, but I think it does it pretty fast.
  10. Jun 27, 2019 at 7:14 PM
    FishingPups
    Barry
    Right. It is basically only my fifth day of owning it and driving it daily.
  11. Jun 27, 2019 at 10:49 PM
    bax
    bax Well-Known Member
    Tyler
    Georgia
    Black 2015 DCSB TRD Off Road
    Mr. Literal is here to save the day. Obviously the truck doesn’t acknowledge a human specifically by name...
