anyone know how to stop this
Discussion in 'Technical Chat' started by awoit, Apr 15, 2008.
  1. Apr 15, 2008 at 11:26 AM
    awoit
    awoit [OP] Well-Known Member
    CA
    08 TRD, SR5
    i hate the sensor thing that beeps when you dont have your seatbelt on, how do i disable this on my 08 TRD?
  2. Apr 15, 2008 at 11:32 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    OMG!! I HATE that thing too!!!!!!!!!!!!!!!!!!!!!!!!!!
    Thank you so much for asking about this!! +1 rep for you!!
  3. Apr 15, 2008 at 11:32 AM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    Put your seat belt on..... its for your safety man
  4. Apr 15, 2008 at 11:36 AM
    neontrail
    Idaho
    True, BUT....It should be our CHOICE to wear it or not. That dang beep could drive me to drive off a cliff!
  5. Apr 15, 2008 at 11:43 AM
    missileman125fw
    missileman125fw Well-Known Member
    +1, It Is The LAW! A least in most states.:D
  6. Apr 15, 2008 at 11:53 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
  7. Apr 15, 2008 at 11:54 AM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    no -1 rep for you because it is in the cheap mods section... its called the search button:cool:
  8. Apr 15, 2008 at 11:54 AM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    i'm just kidding about the rep btw
  9. Apr 15, 2008 at 11:59 AM
    eordonez
    Ed
    Chihuahua, Mexico
  10. Apr 15, 2008 at 1:44 PM
    Munkey
    Munkey Well-Known Member
    Paducah, KY
    2008 Radiant Red 4X4 Double Cab Sport
    OEM Tube Steps, Bed Extender, Pioneer Avic D3 with Bluetooth and XM Radio modules
    I'd never drive off a cliff without my seatbelt on, that's just crazy.
  11. Apr 16, 2008 at 2:02 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Amen.
    Its against the law to not where a safety belt. Also, it will save your life.
    Thankfully
  12. Apr 16, 2008 at 6:51 PM
    awoit
    CA
    08 TRD, SR5
    it may be against the law, but u cant argue that its dangerous or in any way wrong to not where a seatbelt when backing in a boat into a tight driveway going 2 miles an hour in reverse, opening the door to see if you can make it or not
  13. Apr 17, 2008 at 3:47 PM
    orangebutte
    orangebutte Well-Known Member
    Tucson, AZ
    08 access cab 4x4 trd off road w/lock diff
    I disabled my seatbelt chime using the D.I.Y. thread. It chimes 5 times then stops.
  14. Apr 20, 2008 at 8:06 PM
    08beachtoy
    08beachtoy Well-Known Member
    Maryland
    08' reg cab 4x4 2.7ltr 5 spd
    Sony cd player /ipod , small amp, bed mat from Dee Zee , A.R.E. custom cap with yakima racks, weather gaurd floor mats , oem fog lights ,oem DRL mod, class III hitch ,custom bed mounted power inverter, tinted windows 5 % all around, oem hood protector /bugshield , avs door visors ,wet okole seat covers , Train air horn
    Phofener is right this does work I have done it to my truck I am in and out of my truck alot just follow the directions exactly . They also have directions for the passenger side just google toyota seat belt chime and click the link for the post at toyota nation its more in depth explaining how to do both sides and It does work like a charm
  15. Apr 20, 2008 at 9:26 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Does it also stop the light from blinking? The internet is slow at the moment so I can't go check the site out at the moment.
  16. Apr 21, 2008 at 8:31 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Just because the computer thinks I'm not strapped in does not necessarily mean that I'm being unsafe. The original poster may have reasons for this mod other than "I don't want to wear my seatbelt."
    Honestly, it's not something to judge someone about anyway. I grew up without laws dictating every action I take and I find it a little disturbing how much has changed in the past 20 years. Pain = learning danger aversion. I recently saw baby helmets for sale, intended for use while they're walking around the house. Think of the laws those kids are gonna need to protect themselves! :eek:
    Whoa! I'm gonna cut myself off before I start really ranting! :p
  17. Apr 21, 2008 at 11:51 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Well said. Its sad there are so many laws. I am still alive and didn't have half of them. Look at all the people in the world that have survived on their own all these years. What in the world would we do without the government. I live in the country so its not too bad here we still you common sense.
  18. Apr 23, 2008 at 5:34 AM
    80 atoyot
    80 atoyot Well-Known Member
    Bahstan Mass
    08 Access Cab-SR5-Boat Tower....We are both getting old !!!
    Double DIN JVC Head unit with Ipod and Bluetooth, Plays video even while driving Shhhhh...Speaker replacement, 200 W Alpine Amp. Glove box twin 12V power outlets
    You can choose whether to wear your belt or not. But you can't choose to have the STOOPID chime going !! whats up with that.
    Seat belt laws are laws, not chimes.
    I did the DIY as shown it worked great and you can reverse it if you want.
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
  19. Apr 27, 2008 at 12:42 PM
    ellsworth
    ellsworth Well-Known Member
    Buffalo
    08' off rd 6 speed
    6 inch Fabtech, st stabilizers, 18x9 DC -1s 305/65/18 bfg at's
    I am not trying to start a debate on civil liberties or gun control or cell phone use and speed limits...My ass was saved by a restraint in a car when I was 19 and my friend (the driver) did not have his on..We dead ass hit a jeep wrangler at under 20mph and he slamed into the steering column and whacked his head on the a-pillar and windshield...Holy #%^^, I can not imagine hitting something faster like highway speeds..To this day my friends neck and back is still screwed up..I think the ding chime is anoying, who wouldn't ??? It is nice to know though if you forget to buckle up (and everyone has) that there is that anyoing ding chime...
  20. Aug 29, 2008 at 2:23 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I've done the seat belt chime mod. My truck now chimes about 5 times when I start up to remind me to wear the seat belt, then stops, but the red light on the dash still blinks. I wear the seatbeltt 99.9% of the time, but the other
    .1% (like backing a boat down a ramp or driving around my plant site slowly while I have keep getting in and out), I don't. All the seat belt chime mod does is make your truck the same as allmost everything else on the road.
