Anyone recommend Fumoto drain valve?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BG04Taco, Dec 26, 2009.
  1. Dec 26, 2009 at 9:37 PM
    BG04Taco
    BG04Taco [OP] Well-Known Member
    Edmond, OKLA
    04 2.7 SR5 4X4
    ARE Camper, JL Audio, Line-X, Yakima roof rack, odyssey 1500, red line hood struts
    Ive heard good and bad things or any other recommendations for quick oil changes.
  2. Dec 27, 2009 at 5:09 AM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / ProComp 1069 wheels / 265/75-16 Michelin LTX tires
    I installed one after I bought my Tacoma a few months ago. If you get one, make sure it is the one with the hose attachment. I did a lot of searching here and other sites to find anyone that has had issues but everyone seemed to be happy.
    Pros: easy to install, easy to use, it sits high enough above the bottom of my skid plate that I am not worried about it getting hit off
    Cons: if you are looking for "faster" oil changes, this probably won't help. Due to the smaller valve, it flows about 1/2 as fast. It is still faster to get the old wrench out to pull the traditional plug and drain
    I have only used it for a couple of oil changes so far, so I am hoping others chime in with their thoughts for you
  3. Dec 27, 2009 at 5:26 AM
    smuook
    smuook Daily Driver "Plus"
    Frank
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
    The drain bolt doesn't seem to be the limiting issue with doing an oil change... it's that dang filter (at least on the 3.4). I don't see what this gets you.
  4. Dec 27, 2009 at 6:49 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I have one and I love it!!
    The first time I did my oil change on my 07 - the oil came out soooo damn fast, it splattered everywhere. I got the Fumoto and it's been great!!
    It take a little longer to drain.....which, I often start the drain process and I walk away and do other things while its draining. No tools needed....
    I don't offroad either...
    If you offroad, I wouldn't recommend it because it sticks down and you could knock it off on the terrain.
  5. Dec 27, 2009 at 6:54 AM
    Janster
    Jandy
    Lancaster, PA
    You don't need any tools.
    In terms of the 3.4L.... Take a 2 litre bottle and cut the bottom (or top) off to make yourself a 4" deep bowl (so to speak). Squeeze that up underneath the filter - then, unscrew the filter and allow the oil to drain into it. I'll even drop the filter in it....You'll have to carefully manuever the bowl (filled with oil/filter).
    Oh yeah...I hope you know its easier to take the wheel off also.
  6. Dec 27, 2009 at 7:27 AM
    smuook
    Frank
    Loganville, GA
    I appreciate the tip of using the 2 liter bottle. I have been using a plastic bag but I think I'll try your suggestion. I have access to a hydraulic lift and getting to the filter and drain bolt is not a problem. It's minimizing the mess of the filter for me.
    As far as the drain valve goes, I guess I'm just old fashioned and prefer the security and integrity of a drain bolt. ;)
  7. Dec 27, 2009 at 8:00 AM
    The Parts Whore
    The Parts Whore Slinging parts since '03
    I have it on my truck and would highly recommend it.
    However, its not meant for "quick" oil changes, but actually slower. I like it because of the fact that its less messy and you only have to worry about installing it correctly the first time. No need to take the drain bolt on and off everytime with the possibility of over-torquing/stripping the threads.
    Part number is F-103N. The "N" is for the nipple which you can attach a hose to reduce the chance of spilling. :)
  8. Dec 27, 2009 at 9:39 AM
    BG04Taco
    Edmond, OKLA
    04 2.7 SR5 4X4
    thanks everyone. I just wanted to find the cleanest ways to do a oil change . I also just read that there is a separate drain for the filter on the engine. If you can drain that little valve you can remove the filter with no mess. I haven't checked my truck for it yet though. Has anyone else seen the secondary valve?
    This might help some people out.
    http://www.tacomaworld.com/forum/technical-chat/11201-ultimate-oil-change-thread.html
  9. Dec 27, 2009 at 9:48 AM
    Janster
    Jandy
    Lancaster, PA
    That separate drain for the filter is only on the 2nd generation trucks.
  10. Dec 27, 2009 at 2:06 PM
    BG04Taco
    Edmond, OKLA
    04 2.7 SR5 4X4
  11. Feb 4, 2010 at 12:45 PM
    w3tw0rks
    w3tw0rks Well-Known Member
    Alvin
    San Jose, CA
    04 Xtracab 4x4
    BG04Taco - Did you ever get the "oil change wonder"? If so, how is it working out for you?
  12. Feb 4, 2010 at 1:07 PM
    BG04Taco
    Edmond, OKLA
    04 2.7 SR5 4X4
    No I did not there is only one company that made them and they no longer make them. I thought it was a good idea.
  13. Dec 18, 2010 at 11:11 AM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    My only worry would be there is no magnet. If you have metal shavings in your oil you are going to want to get to them before they "Get to you". Just change the plug gasket now and then. It's cheeper than an engine!:D
  14. Dec 18, 2010 at 12:34 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I'm with you on that one.
