Anyone running 255/85/r16's?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Swimmerboy2112, Jun 12, 2013.
  1. Jun 12, 2013 at 1:08 PM
    Swimmerboy2112
    Swimmerboy2112 [OP] Well-Known Member
    Brian
    Walnutport, PA
    02 TRD V6 5 Speed X-Cab
    Borla exhaust, K&N intake, ARB bumper, 16x8 Konig Countersteer Offroad wheels, 20% Tint
    I'd like to run this size tire on my 02 Taco. So I want to see some pics, and what lift you used to fit these.
    -Brian
  2. Jun 12, 2013 at 3:41 PM
    puddle
    puddle Well-Known Member
    Kris
    ID
    2020 TRD OR
    Cool dealer placard
  3. Jun 12, 2013 at 3:45 PM
    Swimmerboy2112
    Brian
    Walnutport, PA
  4. Jun 13, 2013 at 9:35 AM
    lucky73
    lucky73 Limited
    requires axle work
  5. Jun 13, 2013 at 9:51 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    How's that? Lol
  6. Jun 13, 2013 at 10:52 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Are you saying that i'll need a lift, if so I already know that. But axle work? As in chromoly axle shafts or something like that, i'm going to have to disagree.
  7. Jun 13, 2013 at 11:05 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Yeah I was planning on doing the 5100's + Eibach springs up front and in the rear I was gonna throw in some new leaf springs (not sure which ones yet). For a 2" lift or so. The wheels I have are 16"x8", 0mm offset, and 4.5" backspacing.
    Edit: That truck looks pretty good, any more pics?
  8. Jun 13, 2013 at 11:11 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Yeah I have an ARB without a winch, and the 5100's are already on my truck hence the interest in the Eibachs.
  9. Jun 13, 2013 at 11:14 AM
    abunch
    abunch Well-Known Member
    Andrew
    Brooklyn
    04 Double Cab TRD
    icons, ucas, Deaver pack, DD, ARB, Warn 9k, 255-85 km2, rigid lights, yada, yada
    This is pretty much what you have to do:
    http://www.expeditionswest.com/equipment/tacoma/bfg_mt_km.html
    I still rub with stock wheels at full lock. Only really happens when parking. Planning on putting spacers on soon enough.
    You have to cut the pinch weld and cut some of the flares in back.
    I am running 883 springs out front with deavers in the back. I had to install timbrens, because I was getting too much rubbing when hauling a full load with passengers.
    This is full flex with no rubbing.
  10. Jun 13, 2013 at 11:15 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Yeah very true. I am good friends with someone who works at an offroad shop so that shouldn't be an issue.
    Thanks!
  11. Jun 13, 2013 at 11:18 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
  12. Jun 13, 2013 at 11:23 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Thank you for that link and all the info.
    The current wheels I have do stick out farther than the factory wheels so I should have that on my side.
    What are Timbrens? And where did you cut the back flares, any pics of that?
  13. Jun 13, 2013 at 11:24 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
  14. Jun 13, 2013 at 11:59 AM
    abunch
    Andrew
    Brooklyn
    04 Double Cab TRD
    Timbrens are oversized bumpstops. If your wheels stick out past your flares you might end up crunching the flares as you flex.
    I trimmed the the front side of flares where it wraps under the wheel well. I could get some pics for you. From my research it seems each persons cutting out back is a little different. This has to do with where you bed is positioned and what leaf springs you are running. Deavers relocate the axel to a center position, where as some brands do not.
  15. Jun 13, 2013 at 12:14 PM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Ah gotchya. I've read that the Deavers are the better spring because of that axle relocation. I'm still up in the air as far as what leaf springs i'm going to go with but i'm leaning more and more towards the Deavers.
    Awesome! Your truck looks really good.
  16. Jun 13, 2013 at 12:55 PM
    abunch
    Andrew
    Brooklyn
    04 Double Cab TRD
    FYI the deavers are really soft. If I could buy again I would get something stiffer or some custom deavers for an extra leaf.
  17. Jun 13, 2013 at 1:04 PM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Yeah that's how my 4Runner was, trying different combos of this that and the other thing to get it where I want. Instead of new wheel$ why not try spacers?
    Good to know as I do use my truck to haul my atv, dirt, etc
  18. Jun 13, 2013 at 1:18 PM
    Swimmerboy2112
    Brian
    Walnutport, PA
    That's a smart way to think.
  19. Jun 13, 2013 at 9:50 PM
    lucky73
    lucky73 Limited
    relocate the axel
  20. Jun 14, 2013 at 12:49 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I'm still debating on going with this size tire as well. It's between them or 285/75/16. I can't get the tire I want in 255/85 so it will be a tough decision.
