Anyone running 3rd gen TRD Pro skid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nick_Taco, Jan 2, 2018.
  1. Jan 2, 2018 at 1:41 PM
    Nick_Taco
    Nick_Taco [OP] Well-Known Member
    Nick
    Maryland
    2014 DCSB OR 4x4 Auto
  2. Jan 2, 2018 at 1:45 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    sounds like the TRD skid thats been an option since like day one of the 2nd gens. Nothing new, and not really much of a better skid, hangs down rather low.
    jpereira2 likes this.
  3. Jan 2, 2018 at 2:19 PM
    Nick_Taco
    Nick
    Maryland
    It does seem to hang a little low but it is 1/4" which I'm sure is thicker than the 2nd gen skid.
    I don't do as much hard off roading as I used to and I don't really want the weight of a steel plate. I also like not having to worry about rust with aluminum.
  4. Jan 2, 2018 at 3:27 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Most run 3/16 which is slightly thinner than 1/4. I have seen the 1/4 offroad skids on a few third gens at work and they are designed quite well, but a third gen skid for a second gen i got nothing
  5. Jan 2, 2018 at 3:45 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
  6. Jan 2, 2018 at 4:10 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Armed in Utah[QUOTED] likes this.
  7. Jan 2, 2018 at 5:45 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    3/16 yes but in steel, he is talking about aluminum. There are a few companies that make 1/4 steel but they are super heavy. Most aluminum Off Road skies are 1/4 so this should be good for light off roading.
  8. Jan 2, 2018 at 5:52 PM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    The 2nd gen skid fits 3rd gens so I would bet it works the other way too. But honestly for the cost you could go with an aluminum skid from @Pelfreybilt, @Mobtown Offroad, etc.. for less money. It will also be better suited for off-roading, and capable of adding additional skids down the road.
  9. Jan 2, 2018 at 5:58 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I recall seeing 3rd Gen Tacomas installing the 2nd Gen skids when I had a 3rd Gen and browsed the forum. I would think it works the other way around, however I'd be interested if the oil drain opening lines up. It would just be silly if not.
  10. Jan 3, 2018 at 3:44 AM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Our 3rd and 2nd gen skids are interchangeable. The only difference being the oil filter access on the third gen skid plate. If you put a second gen skid plate on a third gen truck, you'll have to drop the skid to remove the oil filter. Not a huge deal for some but if I had a steel skid plate no way would I want to drop a 68lb piece of steel every 5k.
    Nick_Taco[OP] likes this.
  11. Jan 3, 2018 at 2:22 PM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    I was told that the TRD 3rd gen skid is not interchangeable and will not fit the 2nd gens by a dealer/vendor.
  12. Apr 26, 2018 at 6:08 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    ThatguyJZ[QUOTED] likes this.
