Anyone tried the Acetone for gas miliage?
Discussion in 'Performance and Tuning' started by DanGer, Feb 5, 2009.
  1. Feb 5, 2009 at 12:02 PM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    (we've completely DERAILED this thread)
    ooops.
  2. Feb 5, 2009 at 12:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    yeah, I missed that. :(
  3. Feb 5, 2009 at 12:21 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Not surprisingly... but I'm usually more involved... :laugh:
  4. Feb 5, 2009 at 12:24 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Mythbusters tested it and their mileage went down.
    Here's a way to test it without risking your vehicle and it's paint:
    Try it in a gas-powered generator. The engine speed is constant so there's not any variability due to driver influence or road conditions. Measure the time it takes the generator to run out of gas. Do a couple of runs as a control with plain gasoline to measure how long it takes the generator to run out. You'll want a couple of samples of each to average it out due to slight differences in the amount of gas loaded. Then, run a couple of acetone loads through it to see if there is any benefit (generator runs 30% longer). Then run a couple of regular gasoline loads through it and see if the generator still runs as efficiently (cleaned out). If it runs better after the acetone but drops down again when loaded with straight gas, then it's possible it's doing something to the gasoline. If it continues to run well with straight gasoline, it was probably a cleaning issue.
  5. Feb 5, 2009 at 12:43 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I ran it in my car for awhile & it avg'd about 60 miles more a tank (14 gallon tank) with it vs. without it. I live in a metro area where they fuck us 10% on ethanol. Talk about a myth bustin needed, ethanol does not help mpg, it helps food prices go up due to the pressures on corn supplies which also increases food prices for livestock then the prices at the grocery store go up. Let me see, more mileage without it so the gas doesn't go as fast vs. more frequent fillups with ethanol added = no more bad fumes for the atmosphere so it's just propaganda to get all of us to reach farther into our pockets more often due to supply issues with ethanol on top of supply issues of gasoline. Just more reasons for gas prices at the pump to be more unstable more often. Complete bullshit! Can't wait til we move to our new house because ethanol free gas is 7 miles down the road in a county that's 2 counties away from the metro county which means they don't put ethanol in the gas there. I basically stopped using acetone due to the risk to the paint gettin in there & the hassle of having it available when filling up, just wasn't worth it.
  6. Feb 5, 2009 at 1:12 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Ethanol - Coming to a station near you! :)
    sounds like you got some issues with Ethanol and I don't blame you :p
  7. Feb 5, 2009 at 6:52 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    I saw you start sliding around the turn and was like "Sweet Brian drifted around a turn!" then I saw you over correct and start going the other way and just started thinking, Oh Shit
  8. Feb 5, 2009 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :rofl:
  9. Feb 5, 2009 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good point.
  10. Feb 6, 2009 at 4:49 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Check out the link i posted originally. It says a guy tried soaking the various o rings, etc in jars of gas, and acetone mixtures. If I read it correctly, the acetone DID cause the parts to swell slightly but within standard measures.
  11. Feb 6, 2009 at 4:55 PM
    DanGer
    as an update, I purchased a bottle of pure acetone (no dilution or any other solvents) today from home depot and as soon as drive home I will try it out on a tank and compare it to my normal mileage when I drive home.
  12. Feb 6, 2009 at 4:58 PM
    DanGer
    if it does work i'm planning on buying a few fuel supplement/octane booster bottles and refilling them with the right amount of acetone. On this note, does anyone know if fuel supplements/octane booster are as corrosive as acetone and will allow protection to store it in?
  13. Feb 6, 2009 at 5:22 PM
    Taco's for All
    Taco's for All Well-Known Member
    Lake George, NY
    2019 Tacoma TRD Off Road Double Cab
    Nothing at the moment
    I tried this a few years back when my daily driver with a V8 gas hog. I didn't notice much......if any difference. There are a few websites that are VERY convincing with this topic, but again, I tried it and I got the big FAIL!
  14. Feb 6, 2009 at 5:52 PM
    Evil Monkey
    Robert
    Escondido, CA
  15. Mar 6, 2009 at 1:04 AM
    #35
    DanGer
    Ok to try and revive this dead thread, i was planning one testing it on my ride home tomorrow for spring break. Earlier this week with all the snow I scrapped the idea cuz of cold. But now It back into the 60s so I'm going to give it a whirl. I am also hauling 5 extra alloy rims, one fit with a tire. I'm running it against my old average of 22.4 mpg on my return trip for fall break. Not sure if the rims loaded up with hurt my mpg more but we'll see!
  16. Mar 6, 2009 at 5:47 AM
    #36
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    x2
    does not work
  17. Mar 6, 2009 at 8:37 PM
    #37
    DanGer
    So i decided EFF it, I'm going to test it myself. I got INSANE mileage on my trip home. I am at 1/4 of a tank and over 370 miles. I'll have to wait to fill up to get specific numbers but I will keep you posted
  18. Mar 6, 2009 at 10:09 PM
    #38
    Evil Monkey
    Robert
    Escondido, CA
    Well, if you're at 1/4 tank (15.75 gallons used) at 370 miles that would make your MPG about 23.5 mpg. Not exactly earth shattering for a 4 cylinder.
    I've read of some getting 30-32 mpg:
    http://www.tacomaworld.com/forum/4-cylinder/13149-30mpgs-i4-auto.html
    How much acetone did you put in?
  19. Mar 7, 2009 at 10:24 PM
    #39
    DanGer
    Now I'm at about 1/8 with 397.5 miles. I put in 3.8 ounces of acetone when I filled up 13.4 gallons of gas. I'll prob fill up tomorrow and get some concrete figures
  20. Mar 12, 2009 at 10:52 PM
    #40
    DanGer
    Ok I filled at 424.4 putting in 17.160 gallons equaling 24.7 mpg. Not unheard of for 4 bangers but unheard of for MY four banger. Ran one take with just plain premium and got less than 22mpg, next tank was seafoam and got same mileage. Just throwing my figures out there and I got about 10% better mileage with acetone. Take it or leave it!
