Anytime Front and Rear Camera Mod
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Logistics91, Apr 3, 2018.
  1. Jun 26, 2018 at 8:34 AM
    #561
    Logistics91
    Logistics91 [OP] Well-Known Member
    JJ
    2017 Quicksand Tacoma TRD OR
    The site is currently down for some maintenance and updates. My web guy has assured me that it will be up in the next day or so.
    A 3rd camera is possible. I have already tested it. Expect to see it on the site as well. I don't install the nav override, but if you would like me to tag the wire and include instructions on how this is done, I can do that.
  2. Jun 28, 2018 at 1:17 PM
    #562
    Zenraider
    Zenraider Member
    2017 taco TRD 4x4 w/jbl premium
    Vanilla
    That works for me. I'm patiently waiting for the items to come up on the storefront
  3. Jun 29, 2018 at 12:06 AM
    #563
    NateWest
    NateWest Well-Known Member
    Nate
    Maple Valley WA
    2017 Super white DCSB TRDOR
    Buy this product the seller couldn't be more helpful. ask questions! watch the videos its simple
    Logistics91[OP] likes this.
  4. Jun 30, 2018 at 1:02 PM
    #564
    Humble Soul
    Humble Soul Well-Known Member
    Oʻahu, Hawaiʻi
    2018 TRD Sport 4x4 Cement
    Wanting to grab a set but says product unavailable ?
  5. Jun 30, 2018 at 1:59 PM
    #565
    Logistics91
    JJ
    Doing some maintenance on the site. I'll post here once it's back up.
  6. Jun 30, 2018 at 9:15 PM
    #566
    Slim_shadowz
    Slim_shadowz Well-Known Member
    17 Sport DCLB MGM 4x2
    Has anyone installed this switch for the nav over ride yet? If so did you just run it like you would a standard spst switch?
  7. Jul 1, 2018 at 7:45 AM
    #567
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    This is actually a SPDT, so you end up not using one of the terminals to get it to act like a SPST. I used a different brand a few pages back, that had 2 different switches in the same housing, one for camera and one for NAV. But, but the wiring is the same. I have attached a pic of how you would wire this switch. I have shown 2 options. First, so that the LED only comes on when you turn on the headlights and all the switch lights in the cab turn on. In this set up the LED is only so you can see the switch in the dark. I figure you will know immediately if NAV override is on and no need for an indicator light on your switch. Option 2, you could just leave off the LED power source and just wire in the NAV circuit. But the switch would always be dark, and depending on where you mount in, may be hard to find at night.
    Edit: you can move the upper NAV wire From NO to the NC depending on which way you want the button, (in or out), when activated
  8. Jul 1, 2018 at 3:54 PM
    #568
    Slim_shadowz
    Thank you very much!! I would have probably wired it wrong if you didn't show me the diagram.:bowdown:
  9. Jul 1, 2018 at 7:00 PM
    #569
    fatboyfirebass
    You really can't do want you want with that type of switch. But you can get close with this switch.
    https://www.amazon.com/uxcell-Mount...ncoding=UTF8&refRID=WQTFGR1GR1RX9XHSC114&th=1
    Then you need to add an external indicator LED, either pre-wired, https://www.amazon.com/120PCS-Color...rd_wg=7B2CO&psc=1&refRID=DPRH1MQWKH3XX593QMFK
    or hobby style with a housing
    https://www.amazon.com/dp/B01ER728F...NS&pd_rd_r=ETCTZ1ZZ5FX0X27H8J56&pd_rd_w=fiALa
    https://www.amazon.com/Uxcell-A1312...TF8&qid=1530490698&sr=8-7&keywords=LED+socket
    and then wire it like this
    EDIT: The Upper NAV wire should connect to NC1. I Have corrected the picture.
    Or you could go with a rocker from OTRATTW. They show it listed in the wiring section of the site, but I can't find the product listing. Here it is listed by another vendor as well.
    https://www.dirtyparts.com/store/detail.cfm/SWITCH-ON-ON-DPDT-BLU-BLU/pid-159248
    if you wire it like this:
    Edit: I originally posted the wrong switch picture here. The exiting NAV signal needs to attach to pin 1
    https://www.amazon.com/Add-Fuse-same-function-Bussmann/dp/B007FFG5YI
    The upper LED will illuminate with the dash lights etc. The bottom LED will Act as in "ON" indicator. You could then get a custom rocker switch from RockerSwitchPros like this.
    You may have to reverse which LED is which depending on how you want the switch to be back lit
  10. Jul 1, 2018 at 7:27 PM
    #570
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Tons of info to go over. Many thanks for taking the time to post it.
  11. Jul 1, 2018 at 7:33 PM
    #571
    fatboyfirebass
    I'm happy to help when I can.
  12. Jul 2, 2018 at 9:48 AM
    #572
    red yoda
    red yoda ASE Master Certified Technician
    brandon
    Mount pleasant,mi
    2018 Toyota Tacoma SR
    Logistics91, I sent you a message about a order
  13. Jul 2, 2018 at 9:48 AM
    #573
    Logistics91
    JJ
    Sent you a response.
  14. Jul 2, 2018 at 8:52 PM
    #574
    Cementoffroad
    Cementoffroad Well-Known Member
    Josh
    18 Cement OR
    Here is my finished setup in my truck. I couldn't get a better mounting angle while keeping the camera 100% protected behind the grill, hence a small portion at the top of my display still showing the grill. I'm happy with it.
    Many thanks to JJ for all the off hours/Sunday support.
  15. Jul 5, 2018 at 4:19 PM
    #575
    Jbailon
    Jbailon New Member
    Juan
    Tacoma 2016 trd sport 4x4
    Helo @Logistics91 can you send me install instruction y havent recive, thanks.
  16. Jul 5, 2018 at 4:32 PM
    #576
    Logistics91
    JJ
    Juan, it was sent to your email address. I'll resend it.
  17. Jul 5, 2018 at 6:25 PM
    #577
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Interested in the front kit. What kind of camera do I need to buy for it?
  18. Jul 6, 2018 at 9:19 AM
    #578
    okichewy1
    okichewy1 Just chuggin' along!
    Ken
    Kimberly, Idaho
    2018 DCSB TRD Sport Quicksand
    Ultra Flex bed cover, TRD PRO Grille, 32" LED light under grille, Pop n' Lock on tailgate, OCD organizer for center console and glove box, LED bed lights, OEM bed mat, black TACOMA tailgate letters, LED illumination light package, black vinyl overlays for badges, OEM bed step, plasti-dipped front valance and mirrors, 15% tinted windows and sun strip, vinyl letters on dash, vinyl letters on tailgate handle and door sill protectors, TRD Pro shift knob, home-link rear view mirror, mountain vinyl decal above Tacoma on door, FN FX pro wheels, AVS bug deflector, AVS in-channel window vents, front bed rail, red line hood struts, LED interior lights, TRD Pro skid plate, slim line front license plate holder, CaliRaised LED Ditch light brackets with LED lights, Bilstein 5100's, OME 888's, Dakar HD leaf springs, cubby covers, CaliRaised LED Fog light kit,
    Your links are dead. They go to nothing. Are you still selling these? Would like the front view kit for my 2018 truck.
  19. Jul 6, 2018 at 9:22 AM
    #579
    Logistics91
    JJ
    Website is currently down for maintenance and upgrades.
  20. Jul 6, 2018 at 11:04 PM
    #580
    Logistics91
    JJ
    It doesn’t need to be screwed to anything. You can zip tie to the harness or any other cable management that you use/have.
    CANYONERO likes this.
