Anytimebackupcamera.com Install- Front and Rear Cameras
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Papadave418, Sep 7, 2018.
  1. Feb 4, 2019 at 1:36 PM
    #481
    orion808
    orion808 Jack of all trades. Master of none.
    Florida
    2017 Inferno Tacoma Off-Road (Premium & Tech)
    Interior LEDs Hardwired DashCam/Extra USB Black "Tacoma" on tailgate Blackened Badges Nerf Bars Mud Guards Rear Diff. Breather Mod Plasti-dipped Grille Glovebox Vinyl LED Bed Lights LED soft glow flooring accent lights Custom switches Diamondback Tonneau 3rd Bed Rail Sill Protectors w/ Vinyl Tweeter Upgrades Tint windows Husky Floor Mats Molle Panel behind seats Speaker Upgrades Anytime Camera Mod w/ Secondary Rear Camera Plan: Clazzios 2-3" Lift
    Found my problem. I shorted a wire to my secondary rear camera's switch. Grounded it out even. All is well now. Finally had time to diagnose. Now I just need to properly mount the camera in the bed (under my Diamondback Tonneau Cover. I also want to put a waterproof box or hide it in the driver side cubby hole in the bed of the truck so that it can be disconnected easily when I need to remove the cover. I just need to educate myself on how to wire/solder audio cables so I can run it through an aftermarket plug instead of the standard yellow video cable plug.
    The aftermarket plug will have both the video signal and the power for the camera.
    Below are picks of the short and the secondary switch location. This mod functions normally if the secondary switch is in the off position, but if it is in the on position and the rear camera is selected from the DPDT switch that is installed for this mod, the secondary rear camera overrides the rear camera.
    I want the secondary rear camera installed far enough inside the bed that it can monitor any load I am carrying under the tonneau or for cases when I'm driving with the tailgate down.
  2. Feb 4, 2019 at 1:37 PM
    #482
    orion808
    Florida
    Yeah, he's pretty awesome. Replied quickly via email when I had setup questions as well. Seems like he's on his game with customer service.
    Pyrotech likes this.
  3. Feb 4, 2019 at 1:47 PM
    #483
    orion808
    Florida
    Here is a temporary schematic I sketched up. I'll write a more detailed version later with a prettier layout.
    Basically, I added another relay (purchasable from Brian at https://www.anytimebackupcamera.com/ ) . All the "G"s that are circled just mean the black from each device is grounded. And stuff like Y/R or O/B seen next to the video cables was my way of labeling them with color coded electrical tape. This is just in case I needed to ever disconnect them I'd know which cable went where.
    The rear camera is turned on "anytime" if there is power from the DPDT switch (Rear Camera Selected). If, however, the secondary SPST switch I installed is "On", power continues to the second relay and overrides the rear camera with the signal from the secondary rear camera.
    Hope that makes sense.
  4. Feb 5, 2019 at 9:51 AM
    #484
    ZKH
    ZKH Well-Known Member
    northern Kentucky
    2018 TRD-OR DCLB A/T 4x4 BBP Prem+Tech
  5. Feb 5, 2019 at 1:30 PM
    #485
    orion808
    Florida
    Looks like it would work just fine.
  6. Feb 6, 2019 at 6:56 AM
    #486
    ohioboater
    ohioboater Well-Known Member
    2017 DCLB 4x4 Sport
    For front end clearance, I like having the camera mounted high enough that a bit of the license plate bracket and bumper are visible at the bottom of the image, similar to the factory rear view. That way I can tell exactly when the nose of the vehicle is about to touch something or when it's exactly lined up with the parking space's front line. If you mount a camera to the license plate, you'd have to rely entirely on the camera's guide lines. Based on the one I used (not the same one as the one you link to), I would not trust its guide lines to be of any real use.
    bagleboy, Slashaar and ZKH[QUOTED] like this.
  7. Feb 6, 2019 at 7:09 AM
    #487
    ZKH
    northern Kentucky
    ohioboater, thanks for the feedback!
    ohioboater and Slashaar like this.
  8. Feb 7, 2019 at 7:55 PM
    #488
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Dude! This is badass! What cameras are you using for the front and secondary? I don't have a tonneau cover, but was thinking about maybe running a secondary camera on a plate mount. ‍
    r_to_the_k and Slashaar like this.
  9. Feb 7, 2019 at 8:03 PM
    #489
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I have mine set so the top of the front bumper is visible along the bottom of the screen just for that reason. The lines on the rear camera are just an inch or two outside the wheels but the the front camera being mounted lower the calibration would be different. I'd think it wouldn't be too hard to get a feel for them after seeing how they compare next to a curb.
    Slashaar likes this.
  10. Feb 7, 2019 at 9:09 PM
    #490
    orion808
    Florida
    I'm using the TopTier Pro listed at the bottom of the page in the links. Fair enough camera.
    Hard part is because i want the secondary rear camera to be temporary so i can remove when i remove the tonneau. Might be able to work on this some Sunday, but I'll be coming back from camping. Work and life getting in the way of mods...lol.
  11. Feb 15, 2019 at 2:35 PM
    #491
    orion808
    Florida
    I've finished my install...pics and install notes to come, but i need some opinions from owners of other cameras.
    My cameras can get whited out when they are in a darker area and looking out into a brighter. Or they just get overloaded from road glare.
    Any suggestions on a better quality camera that handles bright lights?
    Tested my setup today hauling a couple sheets of plywood. Nice piece of mind seing how it rode. I just couldn't see anything outside/ past the tailgate due to the glare.
    r_to_the_k and MGMSangTaco like this.
  12. Feb 25, 2019 at 5:43 PM
    #492
    ZKH
    northern Kentucky
    Just pre-ordered my anytime kit bundled with the switch and camera. Hope I'm happy with the camera. Still need to order the cubby switch panel from forty2skates via shapeways. Also need too find a plain switch the same size as anytime's front/rear switch to use as a navigation override.
    Papadave418[OP] likes this.
  13. Feb 25, 2019 at 6:00 PM
    #493
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Not trying to hijack thread... just wanted to provide an alternative install for those who are minimalist and don’t wish to add camera switches with mismatch light colors (or do extra work). I installed the car-solutions system, with a simple front camera that is totally plug and play. This system uses the mode button to activate (double tap), and the up/down arrow keys to select the desired camera... works great, no extra switches/buttons required.
    System installed https://car-solutions.com/en/rfcc-ttg2-car-camera-control-system-for-toyota-touch-2-entune.php
    Camera installed https://www.amazon.com/dp/B01LXJ66DW?ie=UTF8&psc=1
    Install pictures https://www.tacomaworld.com/threads...del-and-where-mounted-on-2018-limited.590221/
    Marius and Foolio_Jones like this.
  14. Feb 25, 2019 at 10:54 PM
    #494
    Papadave418
    Papadave418 [OP] Well-Known Member
    That’s a good solution. Nice write up. I looked at this type of option but I’ll tell you why I chose not to go with it. It’s a software based version that depends on the command module communicating with the head unit, whereas the anytime unit hijacks the actual feed and switches via a relay. Relays are reliable, cheap, and easy to swap out. I had an override unit for my Suburban LTZ and at another point a boxed command unit for my Mercedes E350’s fiber optic MOST system and both developed bugs when the dealership would service the car and update firmware on the head units. Both companies weren’t around a couple years later to update the unit, so I tend to avoid them now. Hopefully car solutions has a future track record that is helpful 5-10 years down the line. Thanks for sharing!
  15. Feb 25, 2019 at 11:00 PM
    #495
    Papadave418
    As a hobby I fly RC planes that move along at about 100-120mph and have FPVed (first person view) some of them. The cameras they use are awesome and can handle a much wider range of lights and colors, with TVL’s in the thousands depending on price. You could check out getfpv and find some decent options. They won’t be $13 though :)
    ponts and orion808[QUOTED] like this.
  16. Feb 27, 2019 at 12:44 AM
    #496
    TRDPROHI
    TRDPROHI Well-Known Member
    Maui, Hi
    Can anyone running an aftermarket rocker switch provide some insight please. With the factory style switchfrom anytimebackup camera people are reporting the rear camera flashes for a second when switching from “front” to“off”. Does this still occur with an aftermarket rocker switchlike AOB?
    Thanks
  17. Feb 27, 2019 at 4:35 AM
    #497
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Yes it happens, although i barely notice anymore. Something about the relay is not fast enough to switch back and forth. Normal and nothing to be concerned about
  18. Feb 27, 2019 at 5:22 AM
    #498
    Papadave418
    I agree, I don’t notice it either. And by flash we mean it shows an image and it’s gone very fast, probably cuz our retinas still have the image burned in :)
  19. Feb 27, 2019 at 8:50 AM
    #499
    bagleboy
    Scott
    Norcal, Santa Rosa
    Mine very briefly shows the feed from the rear view camera after switching off the front.
  20. Feb 27, 2019 at 11:39 AM
    #500
    sneakykiday28
    sneakykiday28 Well-Known Member
    2019 Cavalry Blue Tacoma SR5
    Why not just tuck a switch behind the radio that has been left on for the override?
