APR X-1 Launch Control
Discussion in 'Performance and Tuning' started by XrunnIT, Feb 15, 2009.
  1. Mar 28, 2010 at 1:41 AM
    XrunnIT
    XrunnIT [OP] Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Takes just a small investment of a supercharger and X-1... and you can do it allllll you want :D
  2. Apr 20, 2010 at 7:34 PM
    taco_man
    taco_man Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    can you run the x-1 even thought you arnt running boost??? and what did you mean the cam gears were a sensitive install?
  3. Apr 20, 2010 at 8:37 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    yes, you can run the x1 boosted or not. the cam gear install messes with timing, so if proper care isnt taken when installing them, there is a chance the motor can get fubar'd.
  4. Apr 21, 2010 at 5:33 AM
    taco_man
    Austin
    Houston
    09 texas edition
    anything i should put into consideration when installing the gears?
  5. Apr 21, 2010 at 5:52 PM
    taco_man
    Austin
    Houston
    09 texas edition
    do i need to run gauges with this???
  6. Apr 21, 2010 at 6:03 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Damn, thats like 0-100 in 11-12sec.
  7. Apr 21, 2010 at 7:09 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    0-60: 5.000 seconds
    0-100: 10.933 seconds
    Without the launch control I've pulled a few 4.x 0-60s. I never quite got it dialed in all the way.
  8. Apr 21, 2010 at 7:27 PM
    taco_man
    Austin
    Houston
    09 texas edition
    still need to know if i need gauges
  9. Apr 21, 2010 at 8:32 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Only if you want gauges. They aren't really needed, but they are very helpful.
  10. Apr 21, 2010 at 8:50 PM
    taco_man
    Austin
    Houston
    09 texas edition
    well i plan on running them when i get a little more dough in my pocket
  11. May 11, 2018 at 2:56 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    Hello, I just installed a URD MRK 2 supercharger on my 2006 4.0 v6 tacoma.
    I have the APR x-1 and APR site is down. Does anyone have APR phone number?
    I was able to use the way back time machine and download the software but not sure how to use it.
    anyone running an APR x1 can help me out?
    thanks !
  12. May 12, 2018 at 8:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Far and few between here, still have the X-1.
    You'd be lucky to get help from APR with that, since they have been out of the game for some time.
    Just saw your post of FB a few hours ago. Truck is mean man!
    What is it that you need to do on the X-1?
    @Lucario Runner
  13. May 12, 2018 at 9:00 AM
    lilgerber
    Aaron
    Fresno, CA
    I just want to get familiar with the unit and tuning. Make sure I have the correct tune installed. Seeing if anyone had David phone number or how to get ahold of him .
    Also are you boost guys running air/fuel ratio and boost gauges to make sure its not lean. I don't want to harm my motor .
    I feel like my 0-60 should be alot faster .
  14. May 12, 2018 at 9:05 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Does your CEL flash as a shift light?
  15. May 12, 2018 at 9:07 AM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  16. May 12, 2018 at 9:27 AM
    #36
    lilgerber
    Aaron
    Fresno, CA
    Yes the CEL flashes 3 times on start up and i noticed it when i hit 5k+ rpms. I'll have to look but I don't think it flashes every shift.
  17. May 12, 2018 at 9:47 AM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Means it is communicating on start-up. Then it should also flash when you hit redline.
  18. May 12, 2018 at 11:30 AM
    #38
    lilgerber
    Aaron
    Fresno, CA
    Yeah i see it redline then . Should i see it at every shift also? Im on page 7 of 211 on the SC thread.
    Do you know how to use the APR software ? Tonight I was thinking about hooking up my laptop to my X-1.
  19. May 12, 2018 at 12:54 PM
    #39
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I don't remember. Been 8 or so years.
  20. May 15, 2018 at 10:08 AM
    #40
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    mine just stays on all the time so I guess I'm constantly redlining her haha
