Are Retro Fit Projectors easy to install?
Discussion in 'Lighting' started by chris duby, Mar 31, 2011.
  1. Mar 31, 2011 at 7:09 AM
    chris duby
    chris duby [OP] This is where I write something clever
    Lake Jackson, TX
    2020 TRD OR Premium
    6" Lift, 22x12 Xtreme Force XF8 wheels, 33x12.50 Nitto Trail Grapplers...
    I'm looking at purchasing some new headlights pretty soon. At first I was looking at CCFL Halo Projectors with 6000K HID's. Then after reading a little more on here, I found that a lot of people are wanting the retro fit projectors. I was just wanting to know if the install is fairly easy. Before installing though, I plan on painting the inside of the headlight black to go with the black and white theme.
    After checking out http://www.theretrofitsource.com/index.php, I came up with the setup.
    Bi-Xenon FW-R Stage lll Kit
    Ballasts - Morimoto 3Five (35w)
    Bulbs - Morimoto 3Five 6000K D2S
    CCFL Angel Eyes - Yes
    Projectors - LHD
    Shrouds - E55-R
    Wire Harness - Relay: H4/9003
    Will this work, and how easy is the install? I just don't want to have to cut anything.
  2. Mar 31, 2011 at 7:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The process isn't overly difficult, it just takes a lot of patience. You're basically tearing apart your headlight assembly, mounting in a projector that wasn't meant to be there, aiming them up, wiring in the HID (should be plug and play) and remounting. The FX-R takes more work than the morimoto minis. The FX-R projectors are larger and require more trimming to make them fit. Here's a thread that shows some of the general steps (there are a lot more to it than what he shows).
    http://www.tacomaworld.com/forum/lighting/122725-my-fx-r-projector-retro.html
    Edit, here's a better thread.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/109997-hid-projector-retrofit.html
  3. Mar 31, 2011 at 7:31 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    The biggest deal with installing the FX-R is getting the rotational alignment correct. I have the Mini D2S kit. The D2S mounts through the hole from the factory bulb and uses lock rings so you don't have to worry about rotational alignment.
  4. Mar 31, 2011 at 12:10 PM
    chris duby
    Lake Jackson, TX
    2020 TRD OR Premium
    I really appreciate the information... still don't know if I could do it myself because I'm not really a DIY person. The only other option that I know is buying some after market CCFL Halo Projector lights and upgrading them with HID bulbs. Now, I could do that... I just don't know what the quality would be like.
  5. Mar 31, 2011 at 12:12 PM
    Bama_TACO
    Winfield, AL
    If you go that route you will be really disappointed in the output of the light. Some of those lights have really strange cutoff patterns. There are people on here that will do them for you, but it will cost you a couple hundred in labor.
