Automatic gate lock for ‘20
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Paul466, Jan 18, 2021.
  1. Jan 18, 2021 at 2:33 PM
    Paul466
    Paul466 [OP] Well-Known Member
    Hi, I have a ‘20 TRD off-road access cab w/technology package. I’m interested in installing a remote tailgate lock,after calling Toyota they said the lock kit comes with a harness that has to be routed length of the truck to the power source. I heard new Tacoma’s come with a plug ready in the gate for this accessory? Anyone deal with this? I’d appreciate any input.Thanks.
  2. Jan 18, 2021 at 2:41 PM
    jdl1681
    jdl1681 Active Member
    Nope you will need to route from passenger front kick panel to the tailgate. The instructions are very good and clear and its all plug and play. The bed lights are already pre-wired for 2020 and later
    Paul466[OP] likes this.
  3. Jan 18, 2021 at 3:12 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
  4. Jan 18, 2021 at 3:16 PM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    Yes, lots of zip ties but it is plug and play. You’ll need to remove the passenger side kick panel and sill plate as well as the tailgate inside cover.
  5. Jan 18, 2021 at 3:33 PM
    mkultra007
    mkultra007 Well-Known Member
    Mark
    2021 TRD OR DCLB
    Just got a quote for this from the Toyota dealer I purchased my 2021 TRD OR from. My street is on a 22% grade, and I very much don't want to be crawling around under the truck, even with it chocked and the front tires curbed. Having the dealer do it.
    $169.95 Part
    $195.00 Labor
    $14.45 Tax
    $382.40 Total
  6. Jan 18, 2021 at 3:35 PM
    BroncoAZ
    BroncoAZ Well-Known Member
    Cape Cod, MA
    2021 WhiteTacoma TRD Offroad
  7. Jan 18, 2021 at 3:35 PM
    tcjacado
    tcjacado Well-Known Member
  8. Jan 18, 2021 at 3:37 PM
    D500
    D500 Well-Known Member
    David
    SE Georgia
    With the truck on a lift, I'd say an hour or a bit more would do it. Put mine on sitting in the drive in less than 2 hours. There's not much to it.
  9. Jan 18, 2021 at 3:42 PM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Money ..if you got it ...the price is reasonable...ain’t got money ...sounds pricey...lol
    Sometimes it pays to have someone else do the work...if it goes wrong ...they have to correct it ( always go to legit companies)..
    Just my thoughts...
    Aloha,
  10. Jan 18, 2021 at 3:51 PM
    jdl1681
    As others said time vs money if you have an hour its an easy install. If you don't want to deal with it shell out the cash
    sbx22 and Paul466[OP] like this.
  11. Jan 18, 2021 at 4:32 PM
    adhumston
    adhumston Well-Known Member
    90 minutes for me to install in my garage. It took almost
    more time to figure out how to get the instructions onto my tablet!
    No lift for me, just a creeper and a magnetic light.
    The grommet needed to run up into he cab was the only thing that temporarily stumped me. I was initially looking at he wrong one (already in use)
  12. Jan 18, 2021 at 5:00 PM
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    I’m planning to do this soon. I’ve been looking at the instructions and it doesn’t look that bad. I don’t mind pulling stuff apart. I figure I learn more about the truck that way. Finding time to do it, though, is the hard part. So I can understand folks paying to have it installed at the dealership.
  13. Jan 18, 2021 at 5:32 PM
    jdl1681
    Seems to be the most common mistake. The one that is used just seems to be to far back for the install but other then that its one of the easiest accessories to install
  14. Jan 18, 2021 at 6:21 PM
    kndrd
    kndrd Active Member
    Hailey, ID
    2021 TRD Off Road DCLB
    I installed mine today and it took about 1 1/2 hours. No lift, no creeper (would have been nice), and I also had an issue finding right grommet to use. Overall, it was pretty easy to get done.
  15. Jan 18, 2021 at 6:24 PM
    cvsizemore
    cvsizemore Well-Known Member
    Charleston, SC
    I'm thinking about getting a camper shell with an automatic lock on it. Anyone running one similar with this tailgate lock as well? Shouldn't be an issue right?
  16. Nov 30, 2021 at 8:38 AM
    teresahuff
    teresahuff New Member
    There are a lot of gate openers you can choose from, and I suggest you go with the one that you like the most and is not that expensive if you are on a budget. The only thing I think you should not do is try and install it because you can damage your car by accident when doing so. I think you should just call a company like everlastgates.com and let them do all that work in just a few minutes. I don't think it will cost you a lot and I surely know that it will cost a lot less than a car repair. I hope I have helped you, and I hope you install that opener successfully.
