Automatic Sway Bar Disconnects
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drew02a, Aug 13, 2009.
How much would you pay for automatic sway bar disconnects?
  1. $1000+
    1.6%
  2. $750 - $1000
    2.2%
  3. $500 - $750
    4.0%
  4. $250 - $500
    19.2%
  5. < $250
    44.0%
  6. Not Interested
    29.0%
  1. Nov 24, 2012 at 7:27 AM
    #161
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  2. Jan 13, 2013 at 10:36 AM
    #162
    Manwithoutaplan
    ID
    just take it off your fine.
  3. Apr 30, 2013 at 1:46 PM
    #163
    eric3187
    eric3187 Well-Known Member
    i have a factory sway bar off my truck ill sell. if i can just bubble wrap it and tape the end links down, shouldnt be too hard to ship, provided UPS or FedEx takes it like that
  4. May 1, 2013 at 5:41 PM
    #164
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this. i ditched mine the weekend i got my truck. havent looked back
  5. Jun 22, 2013 at 10:23 PM
    #165
    ErocksTaco
    ErocksTaco Well-Known Member
    Eric
    Denver
    06 4x4 DCSB Sport Radiant Red
    OME 886 and rear Dakars Light Racing Upper Control Arms All pro U-bolt flip with Timbren Bump Stops CVJ Reman axles with off road boots Adventure Offroad Fab Sliders ARB Front Bumper Interior LEDs Weathertechs 2009+ taillights 2009+ headlights
    This automatic sway bar disconnect is a feature that is included from the factory on Wrangler Rubicons. If you talk to the guys that wheel their Rubicon's they don't like it because it doesn't completely disconnect the bar. I've always used quick disconnect links on the Jeeps that I owned and it was really easy to just get out of the vehicle and disconnect manually and they were cheap
  6. Jun 23, 2013 at 3:48 AM
    #166
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Myself and a good friend who has a lot of fab experience came up with a different idea of how to do a sway bar disconnect. It would work for sure. We just haven't tried to make it
  7. Jun 23, 2013 at 3:53 AM
    #167
    PAlittlematty
    Beech Creek, PA
    I miss my taco
    Yeah I'm sure we would. Pretty simple design actually. Maybe we can work on it over this coming winter.
  8. Jun 23, 2013 at 6:48 AM
    #168
    big sky
    big sky Well-Known Member
    Montana
    2012 TRD Sport DCSB 4x4
    very much agreed :)
  9. Jun 23, 2013 at 8:32 AM
    #169
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    are you planning on giving it a shot at fab'ing it?
  10. Jun 23, 2013 at 12:29 PM
    #170
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    My idea was to cut the sway in half, put a CrMo sleeve over the cut, weld one side, then drill through the sleeve and sway on the other side for a hardened pin to go through. Might need a plug or something if the sway bar is hollow, and maybe weld a ring on the inside and outside to keep them together, But it would be cheap and simple enough to pull the pin when you want to disco.
  11. Jun 23, 2013 at 12:53 PM
    #171
    PAlittlematty
    Beech Creek, PA
    I miss my taco
    That's not a terrible idea either actually
  12. Jun 23, 2013 at 1:15 PM
    #172
    Seer
    Seer Well-Known Member
    Tom
    Bayfield, CO
    13 Double Cab 4x4 stock
    You also have to keep re-attaching it back in place in mind. The detachable link setup for Jeeps can be really challenging. It often requires a hammer and very level ground with a much larger, tapered pin than the one that would work on the Taco's SB. It'd take some doing to get the bar aligned and the pin back into the bar when you're ready to take it home.
  13. Jun 23, 2013 at 1:50 PM
    #173
    Seer
    Tom
    Bayfield, CO
    Or do a manual version of the Rubi disco. Figure out how to hard core attach mongo plates to the ends of both sides of the cut bar. Then you could make the plates and pins as heavy duty as you'd like instead of having the pin size being limited by the diameter of the SB. Plates would make it easier to align when reattaching as you could see where both holes needed to be.
    Oh yeah, one other thought. The E-Disco only disconnects on one side while the other remains fixed to the jeep.
    Have you seen these dual rate SBs? http://www.teraflex.biz/jk-dual-rate-swaybar-4-6.html
    They have two torsion bars, one riding inside the other. Yo go from stock rate to lighter rate with the flip of a switch or lever. I've spent a great deal of time looking up at the bottom of my Jeep and no time looking up at my Taco so I don't really have an idea what might work under there.
  14. Jun 23, 2013 at 8:48 PM
    #174
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Remember guys, the tacoma sway bar isn't straight. There's nowhere you can cut it, capture the end, and let the ends rotate from one another while attached - least of all the middle.
  15. Jun 24, 2013 at 7:14 AM
    #175
    weazel
    weazel Well-Known Member
    What about a spring on the pin with a small cable with on ring on the end. Pull the cable to release the bar and have a place to hold the ring and release the ring to have the spring set the sway bar back in place. This could be put in the front of the truck with easy access for all.
  16. Jun 24, 2013 at 8:42 AM
    #176
    Seer
    Tom
    Bayfield, CO
    This makes it sound like the best route would be link disconnects at each wheel. I need to start doing some mods so I have a reason to crawl underneath there and look for myself.
  17. Jun 24, 2013 at 10:50 AM
    #177
    Seer
    Tom
    Bayfield, CO
    Haha! Like I said, I've really got to get on doing some modding on the Taco.
  18. Jun 24, 2013 at 6:53 PM
    #178
    bullaculla
    Da big big island!
    LOL, Hawaiian and rapid in the same sentence? :D
  19. Jun 25, 2013 at 5:24 PM
    #179
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    In my experience the Taco sway bar is pretty soft, at least on the TRD OR. I can insert/remove links by hand with only one corner of the vehicle jacked up.
  20. Jul 6, 2013 at 11:01 PM
    #180
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
