Auxbeam 32" 180W 5D led light bar review (bumper mounted)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rlx02, Feb 17, 2018.
  1. Feb 19, 2018 at 12:55 PM
    rlx02
    rlx02 [OP] ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    The light bar blows high beams out the water. The high beams do a decent job with flood but don't have the distance that the light bar has. My high beams are halogen though.
    Yeah the bracket cost seems to be just a 3rd gen tax. They are nice though with a good powder coat on them. I have a set of auxbeam pods as well and all the ditch light brackets cost more than the pods themselves lol.
    RobP62 and jerzsubbie[QUOTED] like this.
  2. Feb 19, 2018 at 12:57 PM
    rlx02
    Western WA
    I think those are the same ones.
    As for the wheels, all depends on how wide your wheels are too. Mine are 9", which is more than what you want but it was the only width they had in our bolt pattern/hub.
  3. Feb 19, 2018 at 12:57 PM
    Parker315
    Parker315 Modding on a Budget | TTC Member #0127
    Brett
    Cypress Texas
    17 Tacoma TRD Sport DCSB MGM
    TTC (Texas Toyota Coalition) Member #127
  4. Feb 19, 2018 at 12:59 PM
    Parker315
    Brett
    Cypress Texas
    I was gonna go with a 20" wheel with a 10" width and a -12 offset
  5. Feb 19, 2018 at 1:04 PM
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    Are your pods spot or flood? If spot,curious how they do compared to the lightbar.
  6. Feb 19, 2018 at 1:25 PM
    rlx02
    Western WA
    They are spot. I haven't got them mounted yet but I was going to angle them to put out more light where the the floods from the lightbar aren't as strong. I think they should be stronger considering they're 5watt LEDs and the light bar uses 3watt LEDs.
    These are the ones I have. I might do silicone on these ones since they will be subjected to the weather whereas my bumper bar isn't directly rained on.
    https://www.amazon.com/Auxbeam-PHIL...F8&qid=1519075479&sr=1-4&keywords=auxbeam+pod
    RobP62 likes this.
  7. Feb 19, 2018 at 1:31 PM
    jerzsubbie
    Davidson, NC
    ‘13 GX460
    If you don't mind, I'd love to see some comparison pics of the throw when you get them mounted!
    Also, check out the Auxbeam S2 LED bulbs for your highs, very impressive and only $30!
    rlx02[QUOTED][OP] likes this.
  8. Feb 19, 2018 at 1:35 PM
    rlx02
    Western WA
    I actually have a set of the auxbeam f16s waiting to be installed as well! I'll try to do a review of them by this weekend.
  9. May 11, 2018 at 12:21 PM
    JHsieh_3
    JHsieh_3 Well-Known Member
    Jeff
    City of Angels
    2018 Tacoma TRD Sport
    I have the same Auxbeam light bar that I just installed in my truck, however I wanted to ask you which colored wires connect with the CaliRaised LED bumper switch. For the switch, it came with 4 wires, however the auxbeam only has 3 wires after I cut off the connecter piece.
  10. May 11, 2018 at 4:54 PM
    Rooster OG
    Rooster OG Well-Known Member
    Tom
    Northern California
    Cement 2018 TRD Off Road M/T
    The switch has two LEDs in it that require separate power sources if you want them lit. There’s a light to illuminate the switch and one that lights up when it’s on. I used an add a fuse to the tail light fuse so the switch lights up when the lights are on. You don’t need to wire the illumination led if you don’t want.
    RobP62 likes this.
  11. May 11, 2018 at 7:36 PM
    JHsieh_3
    Jeff
    City of Angels
    Oh got it! Thank you
    RobP62 likes this.
  12. May 18, 2018 at 8:32 AM
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    Congrats on your purchase and install! It looks great!! I've had Auxbean products on my trucks for a couple years, I love them! Great product for the price! Haven't had any issues either. If you haven't already, take a look at these videos. https://www.youtube.com/results?search_query=auxbeam+torture+test
  13. Jun 20, 2018 at 8:03 AM
    rlx02
    Western WA
    Your videos are primarily the reason why I went with them! Good to see you on here.
  14. Jun 20, 2018 at 8:08 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I'll be finally mounting mine this weekend. I think I have all the parts! :yes:
    rlx02[OP] likes this.
  15. Jun 20, 2018 at 8:55 AM
    #35
    rlx02
    Western WA
    Did you mount your roof one yet?
    RobP62[QUOTED] likes this.
  16. Jun 20, 2018 at 9:17 AM
    #36
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    No, that one is going to require more work. I am installing quick disconnect weatherproof connectors at the light bar where it attaches to the cargo basket because I think I will need to remove it to park in the garage. I had the OEM roof rack mounting brackets but sent them back. I was afraid that the weight of the bar connected to those brackets just riveted into the plastic roof rack rails would be trouble. I had visions of me hitting a hard bump, the brackets failing and the light bar dangling along the side of the truck while I was rolling down the road.
    So I completely changed my mind, and will attach my Thule cargo basket to the roof rack cross bars and then the light bar to the cargo basket. It will be much more secure that way. The need to make the entire thing removable, waiting for parts, is what delayed things. I want it to be right and not just thrown up there. I even bought a soldering iron kit to do the wiring correctly.
    Once I am done I am sure the wait will be worth it.
    ToyoDrew and rlx02[QUOTED][OP] like this.
  17. Jun 20, 2018 at 9:40 AM
    #37
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    sweet looking wheel/tire/suspension set up, looks great..what are you running?
  18. Jun 20, 2018 at 11:07 AM
    #38
    rlx02
    Western WA
    Thanks! I'm running Icon stage 1 suspension, SPC UCA, 17x9 KMC XD Holeshot wheels and 285/70/17 Nitto Ridge Grapplers in C load.
    ToyoDrew and kgilly[QUOTED] like this.
  19. Jul 3, 2018 at 11:54 AM
    #39
    miky70blue
    miky70blue TOROTA
    TEXAS
    2018 Tacoma TRD Sport BLACK 5100 / 887 OME 33" KO2
    Did you cut the grill part where you installed the LED bar between bumper and front grill or not? It's because I'll receive mine this Saturday and want to know if i have or need to cut that little grill part.
    RobP62 likes this.
  20. Jul 3, 2018 at 2:57 PM
    #40
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hey Mike, who are you asking?
