AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Oct 8, 2014 at 1:59 PM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Yeah whenever I turn mine off (all the time) it still feels like there is something still going on. Im not a fan of it and I belive thats the reason I crashed my truck
  2. Oct 8, 2014 at 2:03 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    well ive been problem free since i did the mod almost 3 years ago.. idk why all of a sudden today it kicked in..
  3. Oct 8, 2014 at 2:04 PM
    snowtank
    Andrew
    Arizona
    Lead foot and you saw the chance for a nice fossil and forgot about the super charger.
  4. Oct 8, 2014 at 2:14 PM
    HectoRome
    HectoRome Playing Scientist In The PNW
    07 PreRunner SR5 TRD Off-Road Debadged, Icon Stuffs, MaxTrac Spindles, Dirt King LCAs, Archive Garage Shackle Flip
    59926P ICON 2.5 Remote Reservoir Front Coil Over Shocks 56103 Icon Rear Hydraulic Bump Stop Kit K53163 Icon RXT Leaf Springs Kit 58730 Icon 2.5 Front Remote Reservoir Coil overs 59926P Icon 2.5 RXT OMEGA Remote Reservoir By-Pass Shocks 58550 Icon Billet Aluminum Upper Control Arms Dirt King Steel Lower Control, 1” Uni-ball Joints Archive Garage Rear Leaf Spring Shackle Flip Kit TRD Cat Back Exhaust TRD High Flow Air Filter Kenwood Receiver + JL Audio Speakers Extended Stainless Steel Front Brake Lines Extended Stainless Steel Rear Brake Lines Electronic Locking Rear Differential Rigid LED Driving Lights LED Bar in Bumper Top Windshield LED Bar Custom TACOMA Raptor Grill w/ LED Running Lights METHOD Standard Matte Black Wheels
    ECU must have registered one or both of your front wheels had stopped or too slow for the speed ( like you're in a spin or black ice or snow ) and is tied into the ABS sensor at the wheels.
    You'd need to disable the section of the Anti-Lock Brake feature that receives input from the sensors to fully disable the ECU. If the ECU constantly receives the signal it is looking for it will think all inputs are within range. Do you know a tuner who could crack into your ECU to disable it completely ?
  5. Oct 8, 2014 at 2:18 PM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
  6. Oct 8, 2014 at 2:22 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Went off the road at sycamore yesterday from that damn ABS kicking in......right at the entrance on that last curve coming out. Was in 2wd with a slight drift and fucker kicked in and caused me to head directly offroad and into the brush downhill. Luckily I was able to pump the brakes and regain some control at the end. Scared the fuck out of me and a buddy.
  7. Oct 8, 2014 at 2:24 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Hmmm.. This is a popular corner for pucker moments.
    Time for abs kill switch mod!
  8. Oct 8, 2014 at 2:26 PM
    Aw9d
    Aw9d That one guy
    ABS is the devil. I want to do ABS kill switch mod.
  9. Oct 8, 2014 at 2:30 PM
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    I just pulled my fuse
  10. Oct 8, 2014 at 2:30 PM
    Papa Taco
    Jared
    Socal
    that abs bs almost killed me a couple of times
  11. Oct 8, 2014 at 2:31 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Of all people I would figure you to have this done with all of the electrical work you've done on yours
  12. Oct 8, 2014 at 2:33 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Thats probably the first mod I'm going to do when I get a new truck if it has abs
  13. Oct 8, 2014 at 2:42 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    So I know nothing about electrical and still confuses me looking at the write up:confused:
    Does it work the same by just pulling that fuse temporarily?
    Does 4hi disable it or only 4lo locked? I don't notice it in 4hi but maybe that's because the trucks more controlled and less squirmy?
  14. Oct 8, 2014 at 2:49 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
    I prefer the switch because I still want ABS on the street. There are a few write-ups with pictures out there.
  15. Oct 8, 2014 at 2:54 PM
    HectoRome
    Josh,
    Is this the mod you did back in the day ?
    http://www.tacomaworld.com/forum/2n...kill-switch-mod-05-offroad-easy-way-pics.html
    If so and you've experienced this mod working correctly and as it sits it is not working today could it be that your ground connection might need cleaning as there might be too much resistance and not earthing properly ? ? ? That or possibly road vibration has caused one of your other connections to not contact properly. Provided of course you have the E-Locker otherwise I'll go away now . . .
  16. Oct 8, 2014 at 2:57 PM
    Papa Taco
    Jared
    Socal
    you can pull the fuse and it will turn on your abs light. It won't effect 4 hi or 4 lo in anyway. some people prefer to be able to turn it on and off when switching from street to offroad or what have you. I personally don't like it at all so I am fine with not having the fuse in ever.
  17. Oct 8, 2014 at 2:59 PM
    Papa Taco
    Jared
    Socal
    I almost went off a mountain road twice because of my abs so I pulled over removed the fuse then and there and haven't had it back in since
  18. Oct 8, 2014 at 3:05 PM
    HectoRome
    To Simplify Things . . .
  19. Oct 8, 2014 at 3:27 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
    There are a few different versions of this mod depending on model and year. So make sure you get that part right before you go and start pulling shit apart.
  20. Oct 8, 2014 at 3:28 PM
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    Question, how do you check that 4wd is working on a truck?
Thread Status:
