Battary light on
Discussion in '1st Gen. Tacomas (1995-2004)' started by onthebeach1, Feb 27, 2016.
  1. Feb 27, 2016 at 2:48 AM
    onthebeach1
    onthebeach1 [OP] Member
    2004 Black Tacoma TRD
    Charging system works fine but I can't turn the light off,any thoughts?
  2. Feb 27, 2016 at 11:19 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Are you sure its working fine? Id get the battery load tested at Autozone or some other parts store.
  3. Feb 27, 2016 at 11:30 AM
    wilcam47
    Will
    Bourbon state
  4. Feb 27, 2016 at 1:16 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Take a volt meter and test the cable on the alternator to see if its putting out at least 13.8 volts if not replace it
  5. Feb 27, 2016 at 7:04 PM
    onthebeach1
    Battery checks out fine and the alternator is putting out 13.9 volts but the check battery light is still on?? Any other idea's.
  6. Feb 27, 2016 at 7:18 PM
    mlcc
    Oregon
    We'll there's got to be a loose connection some where or else it wouldn't be on
  7. Feb 27, 2016 at 7:50 PM
    onthebeach1
    I know,just thought i'd ask???
  8. Feb 27, 2016 at 8:48 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    find a near dead battery that will start your truck, put it in and see what the output voltage is. should be over 14
  9. Feb 27, 2016 at 9:53 PM
    onthebeach1
    Found the problem, it was a broken wire on the alternator pig-tail connection. This was found under the wire sheething. If anyone has this problem, check there first.
    Thanks everyone, especially codeseven.
  10. Feb 27, 2016 at 9:55 PM
    CodeSeven
    Serge.
    Coachella Valley
    400x400px-LL-e95604cb_Happy-oh-stop-it-y_fe3cec4b4139c5d566ddef5c702646ca8fc8adf5.jpg
    tcBob likes this.
