bearings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by willard417, Apr 14, 2010.
  1. Apr 14, 2010 at 1:19 AM
    willard417
    willard417 [OP] Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    anyone change their bearings yet. My truck is making the noise of a card in a bicycle wheel and i'm thinking its the bearings. the noise goes away when i turn right though.
  2. Apr 14, 2010 at 3:53 AM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    Sounds like a classic wheel bearing symptom, but you might want to rule our a rubbing dust/heat shield or failing CV joint first. Both have the potential to creating a rubbing or clicking sound when turning in one direction but not the other.
    My '05 tacoma is on all original bearings and joints. Now, my '99 saab is on its 3rd replacement bearing!
  3. Apr 14, 2010 at 5:19 AM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    I think the bearings come in a sealed housing and are not serviceable. I asked Chris but he wasn't sure. Interested to hear what you find out.
  4. Apr 14, 2010 at 5:30 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    Many people have replaced their bearings. Its tough to press the bearings in/out of the hub so most places sell the bearing and hub already assembeled.
    I just purchased 2 hub/bearing assembelies from the Autozone for about $100 each.
  5. Apr 14, 2010 at 7:07 AM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    WOW. Toyota in Calgary charged me $700 for ONE hub bearing assembly, then another $400 to install it. Was only just out of warranty too.... I hate toyota more and more every day :mad:
  6. Apr 14, 2010 at 7:47 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    yeah I changed mne out at 40k. Bought the part at pep boys. Never buy from the dealer!
  7. Apr 14, 2010 at 8:53 PM
    willard417
    Luke
    beaver county, PA
    how would i go about checking the cv joint
  8. Apr 14, 2010 at 9:34 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    just slide under your truck and look for the black, rubber, accordian looking things in your wheel. It's connected to your wheel. If the fins on that are touching, then its not a good angle.
  9. Apr 14, 2010 at 9:49 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
  10. Apr 14, 2010 at 11:31 PM
    willard417
    Luke
    beaver county, PA
    Well i have the 3" OME on so i know they're at a bad angle. but i just put it on 2000 Miles ago. I just don't want to change the bearings if they're not bad.
    Where do i purchase just the bearings because i think the auto parts stores only carry the whole assembly.
  11. Apr 14, 2010 at 11:41 PM
    willard417
    Luke
    beaver county, PA
    thanks everyone for your help
  12. Apr 16, 2010 at 6:48 PM
    alsmith0317
    alsmith0317 Member
    Alan
    Kyle,Texas
    06 Tacoma Dbl 4x4
    Has anyone changed rear wheel bearings and how difficult is it?
  13. Apr 18, 2010 at 6:34 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    not necesarily... when the wheel bearing has just a slight hum you might not feel any slack when jacking it up. ive got 9k on the odo and my drver side wheel bearing is bad. no slop but bearing feels dry. might be a defective seaql and some muddy water got in there to hurry the wear process :mad:
  14. Mar 20, 2011 at 11:37 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Same here on my front left. When I go around sharp right handers the noise goes away. I'm getting a loud humming noise from the front left. I can feel the vibration on the floor at highway speeds.
  15. Mar 21, 2011 at 6:43 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Not sure if people know but if you tighten bearing when is becoming loose it will pro-long it. With almost 40K my bearing started feeling loose after the winter so as soon as its warm enough I will tighten them.
  16. Nov 7, 2012 at 11:17 PM
    Darryl
    Darryl Member
    '06 Double Cab SR5 4x4
    air freshener
    ?????? how do you "tighten the bearing"??? :confused:
  17. Nov 7, 2012 at 11:47 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    He's saying pop the dust cap off the hub/bearing on the front, pull the cotter pin and re-toque up the 35mm (36?) nut on the end of the cv shaft coming through the spindle/hub/bearing/knuckle. I'm not sure you need to but re-torquing it to factory specs won't hurt anything at least.
  18. Nov 8, 2012 at 8:50 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    This only works on taper roller bearings. Ours are sealed, pressed-in bearings, and are non-serviceable. There is nothing to tighten.
  19. Nov 8, 2012 at 8:57 AM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Ours ARE tapered roller bearings man. Just unitized. The pre-load is set by the torque on the cv axle nut. You can re-torque it.
  20. Nov 8, 2012 at 9:45 AM
    cdoucet
    cdoucet Member
