Bed lights that use bed outlet?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner11, Sep 24, 2015.
  1. Sep 24, 2015 at 6:16 PM
    prerunner11
    prerunner11 [OP] Well-Known Member
    MD
    2011 Magnetic Grey Prerunner Dbl Cab Sport
    Softopper
    I'm looking for lights that utilize the bed outlet so I don't have to wire anything into my truck.
    Does anyone have any recommendations for some? I'm looking to illuminate the bed and possibly around the truck.
  2. Sep 24, 2015 at 6:23 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
  3. Sep 24, 2015 at 6:25 PM
    prerunner11
    MD
    Softopper
    Portable sun...never considered that lol
    HondaGM likes this.
  4. Sep 24, 2015 at 6:25 PM
    AwkwardLobster
    AwkwardLobster Well-Known Member
    Las Vegas, NV
    '14 Mag Gray DCSB TRD OR
    Are you looking for something in particular? If you're just looking for a light that plugs in, try looking at the your local hardware store for some work lights. LED christmas lights rated for outdoor use is a pretty cheap option.
    HondaGM and Justus like this.
  5. Sep 24, 2015 at 6:26 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    HondaGM likes this.
  6. Sep 24, 2015 at 6:26 PM
    prerunner11
    MD
    Softopper
    Yea a flood light would be preferable. Christmas lights don't seem bright enough.
    HondaGM likes this.
  7. Sep 24, 2015 at 6:29 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Rope light can be pretty bright
    HondaGM likes this.
  8. Sep 24, 2015 at 6:30 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    The link I provided isn't for Christmas lights. They're CREE LEDs. A 40" section is over 700 Lumen. One of those on each side would light things up quite nicely...
  9. Sep 24, 2015 at 6:32 PM
    prerunner11
    MD
    Softopper
    Awesome. I will check them out then. Appreciate the help!
    HondaGM likes this.
  10. Sep 24, 2015 at 6:43 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    No prob. Good luck!
    HondaGM likes this.
  11. Sep 24, 2015 at 8:31 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I did something like that to illuminate the area around the truck or work on the tailgate and it works well. Works okay for lighting the bed too but its overkill for light output and its a bit unwieldily for everyday use. I may build another bracket that will allow it to safely hang down for short trips and still be pivoted upright to use.
    https://www.tacomaworld.com/threads...-plus-tie-down-and-fishing-rod-holder.366047/
    HondaGM likes this.
  12. Sep 25, 2015 at 4:10 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    This is the easiest solution. I did something similar (but mounted to my cap).
    https://www.tacomaworld.com/threads/lets-see-your-frugal-diy-mods.304174/page-61
    #1220
    HondaGM likes this.
  13. Sep 25, 2015 at 4:56 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    HondaGM likes this.
  14. Sep 25, 2015 at 6:11 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Didn't see that. But, I wasn't looking THAT hard. First thing that popped up on Google...
    HondaGM likes this.
  15. Mar 4, 2025 at 12:57 PM
    hinmo24t
    hinmo24t MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    BUMP i was thinking of 110v strip lights or something for the bed (tonneau cover here, its dark obviously) QUESTION if i leave the light plugged into the outlet, they lights will only go on when i turn the keys? or is that outlet live all the time?
    maybe ill keep running my velcrod aaa battery cheap light that came with the cover instead
    thanks
    HondaGM likes this.
  16. Mar 4, 2025 at 1:54 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    You have to have the keys in, truck on and button pushed. Engine running if you want to use over 100 watts. There is a "400w anytime mod" but the truck still needs the keys turned on.
    hinmo24t[QUOTED] and HondaGM like this.
