Biggest Tire size in factory spare?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WisTaco, Nov 29, 2013.
  1. Nov 29, 2013 at 4:19 PM
    WisTaco
    WisTaco [OP] Bowhunter -)))----->
    Wisconsin
    Murdered 08
    TRD coi,TRD exhaust, Leer cap,WT floormats, Ironman Lift, LR UCA's, Ultra Rogue wheels, 255/75/17's. DYI mods 4x4 Illum switch & BLHM.
    I'm just wondering, I am currently going to install 32's and was wondering if I can match this for a spare in the factory location underneath.
    Thx for your input
  2. Nov 29, 2013 at 4:23 PM
    Jakers83
    Jakers83 Well-Known Member
    Jake
    Denver
    2.7 base.
    OME lift. Tires and wanting more
    I have no clue but want to know as well.
  3. Nov 29, 2013 at 4:32 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    265/70/17 or 265/75/16 is the biggest you can fit without bending or cutting the tabs.
  4. Nov 29, 2013 at 4:37 PM
    WisTaco
    Wisconsin
    Murdered 08
    265/70/17 isn't that a 31.5 inch tire? Also if bending tabs it will fit bigger? It wont affect axle articulation will it.
    Thx
  5. Nov 29, 2013 at 4:49 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    a little over. 31.6" or so. Are you using a 15" wheel? I don't think that fits a 2nd gen. Closes to 32" would be 275's and that would put you a little over 32". With 285's it's really close to the axle. I'm guessing as long as it doesn't touch you should be fine unless you're doing some serious flexing.
  6. Nov 29, 2013 at 4:53 PM
    WisTaco
    Wisconsin
    Murdered 08
    Tire size I'm doing is 255/75/17 Destination MT's studded. I do live in snow country for 4 solid months and skinnier is better in snow. I travel down logging roads and there not always in the best of shape.
    Spose best thing to do is just try to fit it up.
    Thx
  7. Nov 29, 2013 at 4:56 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    It also depends on the tires. MT's have more thread but I think that should fit without bending the tabs.
    BTW, welcome to TW.
  8. Nov 29, 2013 at 4:57 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I fit my 285-75-16 under the truck. No modifications to make it fit. At first it fit a little loose, so I flipped it so that the valve stem was facing down, deflated it, hoisted it up all the way, then inflated it to max sidewall psi. It fits snug now.
  9. Nov 29, 2013 at 5:04 PM
    WisTaco
    Wisconsin
    Murdered 08
    That is a good idea, every once in a while I can hear a rattle down there then I know the spare needs more air.
    And THX driver for the welcome!
  10. Nov 29, 2013 at 5:09 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
  11. Nov 29, 2013 at 5:14 PM
    WisTaco
    Wisconsin
    Murdered 08
  12. Nov 29, 2013 at 5:20 PM
    Canazes9
    David
    Texas
    I've been pleased w/ their performance so far. Obviously I don't get much winter driving in my area, but I did have a chance to try them in icy conditions very recently and they acquitted themselves quite nicely in both my truck and in 265/70R17 on my wife's 4Runner:
    http://www.tacomaworld.com/forum/off-roading-trails/304306-big-bend-adventure.html
    I am NOT advocating them for a dedicated winter tire, but I was impressed with their performance none the less....
    David
  13. Nov 30, 2013 at 11:07 AM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    I had no problem fitting BFG MT 255-75-17 under mine, on a stock TRD Sport rim.
  14. Nov 30, 2013 at 11:17 AM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    You might want to drop that spare down and flip it/rotate it once in a while. I'm betting with that size your pressing up hard against the tabs and eventually you'll wear permanent intentations into the sidewalls... especially if your taking them up to the max sidewall psi.
  15. Nov 30, 2013 at 11:42 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Something to consider
  16. Nov 30, 2013 at 11:48 AM
    Dangermouse
    Dangermouse Well-Known Member
    RG
    Texas
    2013 Reg Cab 4x4
    Got a 255/75 17 on a FJ steel wheel and it fits perfectly up in there.
  17. Dec 1, 2013 at 4:58 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Im running the same tyre as a spare for my 275 70 17s. Overall same diameter. Dont know you will get much anything bigger to fit that that.
  18. Dec 1, 2013 at 6:28 PM
    WisTaco
    Wisconsin
    Murdered 08
    Well my guess would be if you have no issues doing it with the FJ wheel. I will be fine using the stock tacoma steelie with that tire.
  19. Dec 1, 2013 at 6:32 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I fit a 285/70/17 by bending the tabs with a big hammer. There's just barely enough clearance for the axle. You just have to hold the tire back towards the tow hitch when raising so that it clears. I don't have a pic of the axle clearance.
  20. Dec 1, 2013 at 6:35 PM
    NelsonTacoma
    Tucson, AZ
