billy's up front, 5100 adjustable shocks
Discussion in 'Suspension' started by zero niner, Sep 2, 2008.
  1. Sep 2, 2008 at 11:51 AM
    zero niner
    zero niner [OP] romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    Hello,
    For my new 09 Prerunner DC SB, I've decided to go and get the 5100's on all four corners, thanks to the advice on this forum. I've measured the front and back heights and there is a 2" difference (rear being higher) from wheel to top of wheel well. So I'm going to just have the front set to 1.75", besides an alignment, what else do I need to have done? Thanks in advance.
    Rob
  2. Sep 2, 2008 at 11:56 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    do an alignment, and you will be good to go!!!! i love my billy 5100's!!! awesome ride to them!!
  3. Sep 2, 2008 at 6:51 PM
    jaycoll2000
    jaycoll2000 Active Member
    Arizona
    07 4x4 Double Cab, TRD OFF ROAD, TOWING PKG
    Some would recomend a diff drop. Others say you don't need it if you are going up 3" or less.
  4. Sep 2, 2008 at 7:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    he doesnt need a diff drop for a prerunner.
  5. Sep 2, 2008 at 11:45 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Right right! Without the front diff, I avoid some added expenses! And thanks to your encouragement, I'll be ordering these spring from Wheelers this week! Then it'll be new tires and rims... Then the exhaust, when does it all stop...???
    Rob
  6. Sep 2, 2008 at 11:53 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Yeah you will like how your truck sits i love mine just as well.
  7. Sep 3, 2008 at 12:17 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey man...get the 5100's from ebay for cheaper thru downsouthmotorsports.......sonny is great to work with. make a reasonable offer on the shocks, and i guarantee you he'll deal!!!! just a heads up!!:)
  8. Sep 3, 2008 at 1:32 AM
    Hwy61
    Hwy61 Active Member
    08 DC TRD Sport
    im doing the same thing. my quesation would be, what are the largest size tires fit on factory rims the can be run with minimal contact on the 1.85" setting
  9. Sep 3, 2008 at 9:04 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you have the 16's.....265/75/16 is about the biggest you can go without rubbing, otherwise, you' need a 3 inch lift to fit something like 285's, and you'd probably still need to loose the front flaps and doa bit of trimming for no rubbing with 285's.
  10. Sep 3, 2008 at 9:18 AM
    106Tacoma
    106Tacoma Well-Known Member
    Debadged 06 Black Sand Pearl 4x4 Every option.
    just orderd mine from downsouthmotorsports on ebay, going to have the dealer install them when they do my tsb for the rear suspension. Wont have to pay for an alingment then. Cant wait to drive my truck with these. I hear nothing but good things.
  11. Sep 3, 2008 at 9:22 AM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Any one have before and after pics.. I am curious about the height of the truck change.
    -Sam
  12. Sep 3, 2008 at 9:32 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  13. Sep 3, 2008 at 9:56 AM
    106Tacoma
    Ill post before and after pics. Tsb and 5100 install.
  14. Sep 3, 2008 at 10:00 AM
    SamSter0077
    Katy, TX
  15. Sep 3, 2008 at 10:01 AM
    SamSter0077
    Katy, TX
    Thanks 106 Tacoma!
    seen the TSB difference, got it done on my sr5.. I'm curious about these 5100's though..
    -Sam
  16. Sep 3, 2008 at 10:20 AM
    106Tacoma
    As soon as i get the 5100's the dealer is installing them and my springs. Ill post many pics.
  17. Sep 3, 2008 at 3:23 PM
    DFPTaco
    DFPTaco It's TACO time!
    Josh
    Woodland Park, CO
    14 DC SB SC TRD SPORT
    Rear diff breather relocate, BLHM, Scanguage II, Toytec Ultimate Lift set at 3" w/AAL, sway bar relocate, front diff drop, WeatherTech mats, TRD cat back exhaust, TRD Supercharger, KMC Enduros, 285/75R16, and full size spare.
    I have the 5100's right now and they are GREAT. Nice look as is, but I want 285s and therefore need the full 3". I am trying to decide between the toytec coilover conversion or just the toytec spring lift. Any input?
  18. Sep 3, 2008 at 3:29 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    since you already have the 5100's....i think i'd go for the coilover conversion kit. they look like they would be awesome, and way better than a coil spacer, as i think you can adjust with the coil conversion. just my thought tho.
  19. Sep 3, 2008 at 7:03 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Sounds like the 5100's are the way to go! I'm waiting to here back on the add-a-leafs for the rear as I don't want to do a block and also don't want to raise it more than an inch. We'll see if I can find a 1" lift with a add-a-leaf out there... Good to see so many responses!
    Rob
  20. Sep 3, 2008 at 9:01 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Sam, Look in my gallery. Before & after pics of tsb & 5100's set at 1.75. ps.The second setting is .85. :D
