Bilstein 5100 .85 Before/After Picture Request
Discussion in '2nd Gen. Tacomas (2005-2015)' started by horstm87, Apr 20, 2016.
  1. Dec 2, 2019 at 5:31 PM
    #81
    Notch46
    Notch46 Well-Known Member
    2015 Tacoma DCSB
    Method NV 305 rims, 265/70/17 BFG KO2's, Access tonneau cover, Juscustoms splash shields, Tint.
    How much lift did you get with the .85 setting?
  2. Dec 2, 2019 at 7:02 PM
    #82
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Same question as Notch here, plus I'm assuming you're still on the stock TRD OR coil springs in the front?
  3. Dec 3, 2019 at 6:49 AM
    #83
    drewbert41
    drewbert41 Well-Known Member
    Champaign, IL
    05 Silver DCSB 4x4 TRD
    People say 1.5 inches. I don't rub anymore so its its good enough for me. I could definitely tell and feel a difference when I picked it up. I have the TSB on the rear. Now I have a normal amount of rake. Stock coils.
  4. Dec 3, 2019 at 7:15 AM
    #84
    Notch46
    2015 Tacoma DCSB
    So 1.5" hmm?? I was hoping for like 1". When I did the 5100 set at .85 on my 2016 4 runner I got 1" of lift. Was hoping it would be around the same with my 2015 Tacoma.
  5. Dec 3, 2019 at 8:02 AM
    #85
    burrito782
    08 TRD Off Road
    Seems the 2nd (.85) groove setting puts these trucks just slightly lower than the 2nd gen TRD Pro & TX Baja which are lifted 1.75" in the front and pretty level. Might even be a little more ideal as from what I can tell any little bit of load you put in the back of their bed causes the rear ends to squat.
  6. Dec 3, 2019 at 10:29 AM
    #86
    Notch46
    2015 Tacoma DCSB
    I have a SR5 sport. Right now I have about 1-1.25" rake. I do have a 4'x5'x.75 heavy ass rubber mat in the bed. That has to be making it squat a little. That's why I was hoping for just 1" up front. Oh well I'll just install the 5100s @ .85 and see what it looks like. If it has a little cali lean I'll raise the rear up.
  7. Dec 10, 2019 at 4:32 PM
    #87
    Notch46
    2015 Tacoma DCSB
    Just finished installing the 5100's set at .85 and I'm happy to report it gave me 1" of lift in the front. I'm now level front to back. This is with a 4ft x 5ft x 3/4" thick heavy ass rubber horse stall mat in the bed and the gas tank at 3/4 full. I'll have to get some pics later.
  8. Dec 11, 2019 at 4:48 AM
    #88
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    I’m getting ready to have my stock 2005 TRD Sport coils replaced with a brand new 2019 TRD Sport coils that were removed prior to a lift. Also have 5100s and I’m looking forward to being level again since the frame replacement with the added leaf pack.
  9. Dec 11, 2019 at 9:24 AM
    #89
    burrito782
    08 TRD Off Road
    When you guys installed the stock coils on your 5100s were the coils positioned/clocked with the lower end of the coils facing the rear of the vehicle like the Toyota factory service manual specifies?
  10. Mar 18, 2020 at 10:44 AM
    #90
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    hows it ride with the 5100s set at .85 any issues with realignment?
  11. Mar 18, 2020 at 11:13 AM
    #91
    Anthony7516
    Anthony7516 I can not get a picture to up load here
    Queens ,NY
    14, Limited
    I put in 5100 billy's also and coopers AT3 4s much improved ride. The tires even mellowed out
    Micbt25 likes this.
  12. Mar 18, 2020 at 8:43 PM
    #92
    JMoney
    JMoney Well-Known Member
    Josh
    San Antonio
    2010 Black TRD Off road DCSB
    None, rode it like that for a year and a half. I am still using the 5100s now but with eibach coils.
    Micbt25[QUOTED] likes this.
  13. Jun 21, 2021 at 6:00 PM
    #93
    BustinJass17
    BustinJass17 Well-Known Member
    Justin
    Maryland
    2010 Tacoma TRD off road, DCSB, silver streak mica.
    Work in progress.
    I'm looking at a similar setup. I'm browsing the toytec website and I can't tell if the Bilstein 5100 kit is the 2.5 eibach coil or a 1.5. do you, or anyone, happen to know the model numbers? Or, a similar site that has the Bilstein kit.
  14. Apr 3, 2022 at 7:04 AM
    #94
    Blether
    Blether Well-Known Member
    2014 Tacoma TRD DC
    Bringing this thread back :) I'm clearly a newb to this: is it possible to ONLY replace the OEM shocks with Bilstein 5100's (B8?) for all four wheels without replacing anything else (coils / leafs etc)?
    Aim: a stiffer ride and lift the front end slightly
    Want to avoid: bro lean, any other technical issues with the suspension
    Any thoughts out there?
  15. Apr 3, 2022 at 9:41 AM
    #95
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Yes you can just replace the OEM shocks with Bilsteins. You have no adjustability with the rear (obviously, not a coil spring over the shock) like you do with the front (0", .85", 1.5", 2"). For the fronts, if you adjust it to 0" or the .85" setting you'll still have a great comfortable ride. I started with just Bilsteins on all four corners and had the fronts set to .85" and it rode basically like stock. I've since gone with OME 883's and a AAL and put my front shocks back to the 0". Ride is superb.
    Edit: I forgot to add that the .85" will basically level out the front, maybe like still the ever slightest rake.
    burrito782 and Blether[QUOTED] like this.
  16. Apr 3, 2022 at 10:03 AM
    #96
    Blether
    2014 Tacoma TRD DC
    Awesome - many thanks for the advice!
  17. Apr 3, 2022 at 5:00 PM
    #97
    burrito782
    08 TRD Off Road
    Basically what @gkomo said. Although I'll add one thing you need to take into account is the condition of your current rear leafs. If they are old/tired your rear might be drooping a noticeable amount to the point that you'll be bro leaning when set to 0.85 (2nd groove) in the front. You may want to take some measurements of the front and rear and report back. That is, on each wheel measure the vertical distance from the center of the wheel hub up to the fender (if unclear see this post for reference: https://www.tacomaworld.com/threads/hub-to-fender-measurement-on-stock-2016.405255/#post-11350704). Generally speaking, for the stock TRDs there is about a ~2" rake (~20" front / ~22" rear).
