Bilsteins
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oat, Nov 2, 2011.
  1. Nov 2, 2011 at 5:00 PM
    Oat
    Oat [OP] Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    So i got a leveling kit right now but im wondering if i were to use 5100's to lift the front up could i take the leveling kit out, because essentially wouldn't that level it out? the kit is 2"
    Also, difference between 5100's 5125's 5150's?
  2. Nov 2, 2011 at 5:04 PM
    scocar
    scocar hypotenoper
    Close. The front 5100s can be set to zero lift, 1.25, or 2.5
    I think the basic diff between the models is extension/compression length. Not sure on actual numbers.
  3. Nov 2, 2011 at 5:05 PM
    Oat
    Florida
    2001 Prerunner
    So if i set it at 2.5 would it eventually settle close to 2"?
  4. Nov 2, 2011 at 6:34 PM
    scocar
    scocar hypotenoper
    It's going to depend almost entirely on the state of your coils, and this will be subjective for any older or modded truck. If they are stock, and probably worn-out, progressive coils, there won't be any settling.
  5. Nov 2, 2011 at 6:36 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    the 5150's are a long rear resi shock, and the 5125's are longer than the 5100s IIRC
  6. Nov 2, 2011 at 8:34 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  7. Nov 2, 2011 at 11:13 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    5125s basically just come in a lot more lengths. Including longer and shorter the rear 5100s.
    5150s just have the resivor for better cooling and are available with one other valving setup.
    Otherwise all of these billy shocks have the same valving.
  8. Nov 4, 2011 at 6:54 PM
    Oat
    Florida
    2001 Prerunner
    Ok guys, tell me if this makes sense or what i should do.
    I have spacers to level out the front which i want to get rid of. I was thinking Front 1500's at 2.5 and 5125's on the rear, but i dont know what options you can set the 5125's at.
    Also would front coils need to be replaced?
  9. Nov 4, 2011 at 6:58 PM
    Oat
    Florida
    2001 Prerunner
    Ok, so options to level the truck out besides spacers?
  10. Nov 4, 2011 at 7:05 PM
    Oat
    Florida
    2001 Prerunner
    Well i have a prerunner, so its already "high" enough for me, i just want to level the front out without the spacers.
  11. Nov 4, 2011 at 8:45 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    What is your budget?
    You can set bilstein 5100's up front w/ stock coils at either stock height, 1'', or 2.5'' (according to DSM)
    To me it seems like 2'' is a bit much to level out a stock truck, do you have pictures of how your truck sits now? In my mind it seems like setting the billies to 1'' should be enough to just level it out. But I guess every truck is different depending on the condition of the current suspension components.
    You may be able to set the billies to 2.5'' and maybe your stock coils are sagging enough so that it puts it where you want. But that is a gamble, and setting the billies to 2.5 on stock coils will make the front suspension really stiff.
    If you have a little more money to spend you can run OME struts and OME 881 coils which would lift your front end right at 2'', and your front end would be nice and cushy.
    Good luck!
  12. Nov 4, 2011 at 9:57 PM
    Norton
    No, scocar is correct. The reason you don't hear about many of us using other than a zero setting is because most of us have paired them with aftermarket coils (e.g., Eibachs or OMEs). When installed this way, the springs do the lifting and do not require a pre-loading.
  13. Nov 4, 2011 at 10:17 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    What size spacer do you have now? Does your truck sit the way you want it now?
  14. Nov 4, 2011 at 11:12 PM
    TacoMX
    Jonathan
    Deltona, Florida
    OP says 2'' leveling spacer
  15. Nov 5, 2011 at 12:48 AM
    scocar
    scocar hypotenoper
    Yup. In fact, the 5100 perches are not designed to take the additional preload of any setting higher than zero with the stronger aftermarket coils like Eibachs an OMEs. They were essentially designed for the stock coils, which have a much lower (weaker) spring rate.
    OP, BTW, it seems that you think shocks can be used to change the lift in the rear, but they cannot. With the leaf springs, all you can do is use blocks (poor choice because they increase axle wrap) add-a-leaf (lifts and stiffens ride, but only on leafs that are not worn out/sagging already), shackles (wear out the leafs prematurely), or aftermarket leaf pack, which his the optimal choice, and provides many height options. Whatever type of lift you do in the rear, you need to measure max droop and compression, and get a shock that works fo rthis applciation without bottoming out or topping out.
  16. Nov 5, 2011 at 8:28 AM
    Oat
    Florida
    2001 Prerunner
    Can you tell me more about the OME struts and coils, interested in that.
  17. Nov 5, 2011 at 9:23 AM
    scocar
    scocar hypotenoper
    You havent really told us what is going on at the back end of yoru truck. Is it stock, or does it already have block or something?
    I am picturing rgiht now that you have bro lean, with the back stock, and a 2-in lift in the front, making the front about an inch higher than ther back. Did I miss something?
    I suggest you check out Wheeler's Offroad web site. They offer the basics on the OME setups front and rear.
    Also, someone mentioned the OME 881 setup as "cushy." I would never call it cushy. It is pretty firm, but will soak up the bumps.
  18. Nov 5, 2011 at 9:38 AM
    Oat
    Florida
    2001 Prerunner
    Back is stock.
  19. Nov 5, 2011 at 11:48 AM
    TacoMX
    Jonathan
    Deltona, Florida
    when I said cushy It was in comparison to spacers or billies w/ stock coils on a lifted notch.
  20. Nov 5, 2011 at 11:49 AM
    TacoMX
    Jonathan
    Deltona, Florida
    Like i said before, I think a 2'' lift up front is a bit much for a stock rear end. That would put you a little nose high like scocar said.
    What is your budget? what do you want the truck to look like when done (level, lifted, stock etc..)
