Blendmount Scangauge mount installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpaceMonkey, Apr 9, 2010.
  1. Apr 9, 2010 at 8:47 PM
    SpaceMonkey
    SpaceMonkey [OP] Well-Known Member
    Houston, Tx
    06 PreRunner
    My OBDII splitter cable and blendmount scangauge mount arrived so I installed both. The blendmount is nice and I can now have both scangauge and PLX gauge up and running simultaneously. Sweet!
    The old scangauge location was on top of the steering column but I have this now in that location
  2. Apr 9, 2010 at 8:50 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
  3. Apr 9, 2010 at 9:49 PM
    wizo
    wizo Well-Known Member
    Port St. John, FL
    09 PreRunner 2.7L
    2.5" Walker Evans C/O's, All Pro UCA's,
    How did you route the cable for the scanguage? I moved mine to the steering column but it blocks my view of the odometer and idiot lights. I am considering the blendmount but unsure of how to route the cable.
  4. Apr 9, 2010 at 11:52 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    There's a write up here somewhere. Search for it for With detailed pics. I can't bc I'm on my iPhone. The short of it is u pop off the screw covers off the handle. Unscrew the 2 screws holding the handle. Pop off handle and trim piece. Route cable btwn headliner and roof it's real easy. Then drop the cable down the gap btwn console and wall ( kinda hard to explain without pics) then plug in obd2 port and reinstall everything.
  5. Apr 10, 2010 at 12:13 AM
    wizo
    Port St. John, FL
    09 PreRunner 2.7L
  6. Apr 10, 2010 at 2:17 AM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    is that speaker on your pillar a factory sound sytem upgrade or custom fabbed?
  7. Apr 10, 2010 at 2:26 AM
    Pyriteship
    Pyriteship Well-Known Member
    Bill
    Massachusetts, USA
    10 Access Cab SR5 in Pyrite
    Nice placement. How is that spot for "ergonomics"?
  8. Apr 10, 2010 at 4:32 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    Custom fab'd tweeter pods. ;)
    It brings the sound imaging up and helps center it.
  9. Apr 10, 2010 at 4:33 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    I will have to get used to moving my eyes up to do spot checks of the SG but it's not bad.
  10. Apr 10, 2010 at 7:26 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Ignorance strikes again. What's a PLX gauge ?[​IMG] I have a scangauge so I got a clue on that one. Thanks
  11. Apr 10, 2010 at 7:33 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    PLX is the vendor and they make a really nice set of gauges. The one I bought was the DM-100 OBD which means it has the standard OBD features plus you can add additional sensors to it. For example, I could install boost, AFR, EGT, etc sensors and then you can monitor them all from that one gauge.
    The reason why I also wanted to run my Scangauge was it has the xgauge feature which the DM-100 OBD does not so now I can read HP, MAF, AFR, read miles until empty, etc.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/83677-installed-plx-gauge.html
    http://www.plxdevices.com/multigauges.html
  12. Apr 10, 2010 at 7:34 AM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    If there is a gauge installed in the right steering column pod, will you still be able to reset the trip computer? Curious because I'm thinking about going this route as well.
    -Thanks!
  13. Apr 10, 2010 at 7:40 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    ^ Yes you can. There is room. I am planning to add a separate boost gauge there.
  14. Apr 10, 2010 at 10:41 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    ^ I think you're right in that it's calculated. From what I've read, it's pretty close.
  15. Apr 10, 2010 at 12:27 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    This site continues to amaze me. Didn't know you could split the OBD Port.
    Nice Job
  16. Apr 11, 2010 at 7:01 AM
    george3
    New Jersey
    Thanks. I'm slightly less ignorant. Everyone on TW seemed 2 B using Scangauge. Everything I've done is off TW posts, so I went with Scangauge. I'll have to study more on the PLX 2 C Y I need 1. Looks great. Thanks for the links. Curious George
  17. Apr 12, 2010 at 7:33 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just a slight bit o' thread jacking, but can you summarize the differences between the PLX and the Scangauge? I was considering the PLX as it does look better, but it's not clear to me what all one can do that the other cannot.
  18. Apr 12, 2010 at 8:42 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Looks great, I thought about the blendmount but I didn't want to look up at the rear view everytime. On the steering column its perfect.
  19. Apr 12, 2010 at 1:13 PM
    george3
    New Jersey
    X 2 on that. Thanks.
