Blue Sea aux fuse block install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tooblutacoma06, Jan 14, 2010.
  1. Feb 15, 2013 at 7:10 AM
    #41
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
    Ha, I just ordered one of these the other day(the smaller version though). They are great, I had one in both of my wranglers for aux lighting.
    You have a nice setup, solid work.
  2. Feb 21, 2013 at 9:57 PM
    #42
    tooblutacoma06
    tooblutacoma06 [OP] Member
    Kellon
    Houston
    Thanks everyone for the comments. The panel design is slowly evolving and becoming a little more streamlined than my prototype (see for sale thread progress here:custom auxiliary fuse panel FS thread)
    Just to update... I have had mine installed for over 3 years without a single electrical problem or failure of the components. I really like the Blue Sea stuff, it handles some abuse. The mount is still in excellent condition along with the powder coating.
    There should be some other installs floating around out there but I think the guys/gals are just too shy to post pics... :)
  3. Feb 22, 2013 at 6:12 AM
    #43
    cvisinho
    Rhode Island
    Having a mounting plate fabbed up out of .080 aluminum today at work for test fitting. Just a rectangle that will mount in the same bolt holes on the side.
  4. May 6, 2013 at 9:46 AM
    #44
    Dubs Chops
    Dubs Chops Well-Known Member
    Inola
    is this powered all the time or ignition switched?
  5. May 6, 2013 at 5:01 PM
    #45
    tooblutacoma06
    Kellon
    Houston
    Fuse box is powered all the time just like the battery but all accessories are switched.
  6. Jul 4, 2013 at 9:25 AM
    #46
    youngblood
    youngblood Well-Known Member
    Chattanooga TN
    07 SR5 4x4 DC longggg bed
    None (yet)
    Sweet setup! Question: Did you make your own wires? I like the protectors and colors. Nice. Did you purchase a kit? Any resource links you can throw our way?
    Thanks,
    Tim
  7. Aug 6, 2013 at 4:42 PM
    #47
    rigmasterk
    rigmasterk New Member
    phenix city, alabama
    4x4 SR5 pyrite Mica
    bestop, black nerf bars, plastidipped all chrome, diff breather relocated, aux fuse box, air compressor, 1500 watt inverter, led bed lights, ywm.
    anyone know what size bolts that are used to secure the mount to the trucks factory screw slots?
  8. Aug 6, 2013 at 5:09 PM
    #48
    Valsmere
    Valsmere Well-Known Member
    Brian
    New Jersey
    EXPENSIVE
    tail gate lock, rear view mirror bracket, hood hinge brackets, and the list grows.
    M8x1.25 I am pretty sure.
    hoverlover and ChadsPride like this.
  9. Aug 7, 2013 at 4:13 PM
    #49
    rigmasterk
    4x4 SR5 pyrite Mica
    Awesome thanks! My shitty bracket ive had installed is gonna get replaced as soon as the budget says Im good.
  10. Aug 7, 2013 at 6:53 PM
    #50
    Valsmere
    Brian
    New Jersey
    EXPENSIVE
    Cool that Buddy!
  11. Aug 22, 2013 at 3:53 PM
    #51
    tooblutacoma06
    Kellon
    Houston
    Sorry for the really late responses guys. I've been MIA lately with business and family trips.
    Thanks! I did put together my own wires. The wire is 4 AWG Lightning Audio and the covering is called expandable sleeving. I crimped on the terminals and used heat-shrink tubing over the ends. Keep in mind that adding the expandable mesh will make the wire less flexible, if that would be a problem for you. It gives a much nicer look than ole wire loom though.
    I didn't buy a kit, just bought individual components online, mostly eBay. Waytek Wire (waytekwire.com) and Parts Express are good sources for other miscellaneous wiring stuff.
    That is correct :thumbsup:
    #51
  12. Sep 8, 2013 at 7:58 PM
    #52
    ConnorBryan
    ConnorBryan New Member
    06 TRD prerunner
    Has anyone installed a master switch to the block that can be accessed in the cab. Idk if that would be redundant because of the switches on your components but it's an idea I had, any thoughts?
  13. Dec 5, 2013 at 11:01 PM
    #53
    FLtaco24
    FLtaco24 Just a man and his truck
    JJ
    Daytona Beach/South FL
    09 PreRunner SR5
    Stock for now
  14. Dec 5, 2013 at 11:13 PM
    #54
    skygear
    skygear                    
    You could get one of the blue sea isolators/ battery switch. They have a charging relay for dual batterys and then they have a battery shut off solenoid.
    Ahhh, here it is. Remote Battery Switch PN 7700 http://www.bluesea.com/products/7700/ML-RBS_Remote_Battery_Switch_with_Manual_Control_-_12V_DC_500A
    I was looking at these. Thinking of putting one in and then installing the switch under the dash or next to the hood latch release or something. Out of the way for emergency or maintenance use only.
  15. Jul 10, 2014 at 2:41 PM
    #55
    TRDh4vok
    TRDh4vok Well-Known Member
    Gil
    Palm Beach County
    '09 TRD PreRunner Sport
    -4" MaxTrac Spindle lift -5100 RCD Bilstein's -1/2" Strut Spacer driver's side (Taco Lean fix) -1/4" Strut Spacer passenger side (Taco Lean fix) -4" Tapered Blocks -Extended length U bolts -Front Skid Plate -Exhaust Tip -Tube Steps - Silver -Bed Extender -LEER Tonneau Cover -Rampage Roof Cab Lights -Rampage Tailgate Light Bar Six Function SUPERBRITE with Reverse Lights, Running Lights, Brake lights, Emergency Hazard and L & R turn signals -exLED Toyota Tacoma Custom interior LED Light Kit -PIAA Xtreme White Plus head lights and fog lights -NITTO Terra Grapplers 285-70-17 -30" Avec CR-Series Led Light Bar in bumper grill -Two 6.5" Led light bar's attached to the A pillars -Hood hinge bracket mounts from Famous Fabrications -Exhaust muffler Aero Turbine AT2525XL -OEM Roof Racks -OTTRAW Rocker switch -Stant locking gas cap -Large T emblem and mid mount bracket from Diaz Fabrications
  16. Jul 10, 2014 at 2:54 PM
    #56
    CQB 1911
    CQB 1911 Well-Known Member
    Jesse
    AZ.
    2010 TRD OR AC
    I drew this up in Visio then converted it to a CAD .dwg file. I sent this to a local fab shop and they cut and bent the bracket for me. 50 bucks. It fits my 2010 with ATRAC.
  17. Aug 1, 2014 at 9:39 AM
    #57
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    Whats the main purpose of the added breaker?
  18. Aug 1, 2014 at 9:55 AM
    #58
    skygear
    skygear                    
    Don't catch you truck on fire
    bajatacoguy likes this.
  19. Aug 1, 2014 at 10:02 AM
    #59
    J88logue
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    figured it was so you can shut off power to your acc. fuse block when you want to lol
  20. Aug 1, 2014 at 12:52 PM
    #60
    skygear
    skygear                    
    Thanks Jesse.
