Bolt on Wheel Bearing replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ffemt2987, Jan 25, 2012.
  1. Jan 25, 2012 at 5:27 PM
    ffemt2987
    ffemt2987 [OP] Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    I have searched and have not been able to find anything on this. I am starting to get signs of bad wheel bearings and am trying to find the easiest DIY fix. I checked out parts for pricing etc at Advance Auto and they sell a replacement bearing / hub that the guy said is a bolt on that won't require pressing. They run $105 with a 3 year warranty. Has anyone used these? If so, what other parts or tools are required? Thanks in advance.
  2. Jan 25, 2012 at 5:29 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    I always thought replacements required a bearing press.
  3. Jan 25, 2012 at 5:35 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  4. Jan 25, 2012 at 6:03 PM
    ffemt2987
    Austin
    Golden
  5. Jan 25, 2012 at 6:05 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    yes it is bolt on
  6. Jan 25, 2012 at 6:08 PM
    ffemt2987
    Austin
    Golden
    Thanks! Now the question of why nobody ever goes that route since the price isn't any more than the toyota part?
  7. Jan 25, 2012 at 6:11 PM
    Yoytoda
    Roland
    completely stock
    because getting a replacement press in bearing from toyota will far out last an autozone shit bearing.
    If you have lift and low offset on the rims with oversize tires you put a lot of stress on the wheelbearing. the autozone ones will only last 6 months
  8. Jan 25, 2012 at 6:13 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I had my 05 Tacoma front left bearing replaced @ 170,000 miles. Found the bearing on an ebay store, Detroit axle for around $40. Had a local shop press the bearing & replace it for $130. I tried to do it myself, but was unable to break loose the hub nut. And I do not have an impact wrench, so I had to pay a shop to do it.
  9. Jan 25, 2012 at 6:13 PM
    ffemt2987
    Austin
    Golden
    gotcha. I guess if they stand behind the 3 year warranty then it would be a matter of labor. I'll take it into consideration. Thanks again
  10. Jan 25, 2012 at 6:15 PM
    Yoytoda
    Roland
    completely stock
    ive dealt with that in the past and it gets annoying to change a wheel bearing every oil change lol!
  11. Jan 25, 2012 at 6:17 PM
    XXXX
    sKiP
    05 Prius
    First if you want an accurate answer post the part number you are questioning.
    The hub is bolt on.....
    It just needs a bearing pressed into it before bolting it.
    I just did a search and Advanced has no offerings of wheel bearings and a hub for $105 nor have I ever heard of it being offered already pressed together. It's possible but not probable that 7 years after production someone says "lets make one".
    The only thing even close is the hub for $101 and that's a rip off
    http://shop.advanceautoparts.com/we...ssembly-Moog_18440257-P_184_R|GRPWHELAMS_____
    Rock auto has them for $79 (same hub)
  12. Jan 25, 2012 at 6:19 PM
    Yoytoda
    Roland
    completely stock
    http://www.autozone.com/autozone/pa...jxbaxZ6o3qx?itemIdentifier=209988_3214_0_2805
    wheel bearing module
  13. Jan 25, 2012 at 6:31 PM
    XXXX
    sKiP
    05 Prius
    So your telling me it's a bearing and hub pressed together for $65 (price I found online)?
    Ill jump for joy if it's right........
    .........but it seems to good to be true + I have yet to see this posted in any other forum.
    I'm 99.9% sure this is just the bearing.
    I complied a ton of info on this whole subject just a couple months ago ---->> http://www.tacomaworld.com/forum/2n...eplacement-part-s-general-bs.html#post3278586
  14. Jan 25, 2012 at 6:31 PM
    ffemt2987
    Austin
    Golden
  15. Jan 25, 2012 at 6:35 PM
    Yoytoda
    Roland
    completely stock
    the link posted for the MOOG ones are better but Toyota is great stuff
    In my opinion, stock is always better when dealing with drive train parts like wheel bearing and cv axles
  16. Jan 25, 2012 at 6:37 PM
    XXXX
    sKiP
    05 Prius
    see this pic
    does it look familiar?
    this is the bearing sitting on my desk with NO hub
    this is the bearing and hub pressed together
    no go look at the link from Autozone......
    its just a overpriced bearing you can get anywhere for $30 cheaper
    like I said you need a press
  17. Jan 25, 2012 at 6:37 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    man scoring hub for $ 65 would be golden. I would cut that bearing off with chainsaw if somebody sold me brand new wheel hub for $65 :eek:
  18. Jan 25, 2012 at 6:38 PM
    XXXX
    sKiP
    05 Prius
    ahhhh.........thank you...please help me show these two the light :D
  19. Jan 25, 2012 at 6:38 PM
    Yoytoda
    Roland
    completely stock
    thats right
    even the toyota one is only $130
    http://www.villagetoyotaparts.com/s...y_TrimLevel=0&ukey_modelRange=0&searchString=
    EDIT: nevermind your right the hub needs to be pressed out and in. but the bearing doesnt have to be pressed into the retainer
  20. Jan 25, 2012 at 6:39 PM
    ffemt2987
    Austin
    Golden
    I wish Toyota ones lasted longer... 70,000 miles isn't too good for being the best option.
