BOSS suspension or TOYTEC ultimate
Discussion in 'Suspension' started by ArMarine04, Oct 31, 2013.
BOSS suspension kit or TOYTEC ultimate lift kit
Poll closed Dec 15, 2013.
  1. BOSS suspension
    34.4%
  2. TOYTEC ULK
    65.6%
  1. Dec 25, 2013 at 9:16 AM
    #61
    dxpsman
    dxpsman Well-Known Member
    Brandon
    Oceanside, CA
    14 TRD Sport PreRunner
    AFE MACH Force-Xp 3" Cat-Back Stainless Steel Exhaust System w/Black Tips, Complete OME 3" lift, debadged, Body Armor 4x4 side steps.
    My sincere advice is to stay away from the Falken Wild Peak/Rocky Mountain. The siping only goes down about 4/32" and disappears making the tire look bald after 5-10k miles. Some wet traction is lost, but the main drawback of this is largely aesthetic. Just a heads-up...
  2. Dec 25, 2013 at 9:00 PM
    #62
    ArMarine04
    ArMarine04 [OP] Well-Known Member
    Alan
    Beaufort, SC
    Any advice on a good a/t under 200 per tire?
  3. Dec 25, 2013 at 9:02 PM
    #63
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    What size do you want?
  4. Dec 25, 2013 at 9:05 PM
    #64
    ArMarine04
    Alan
    Beaufort, SC
    285/75/16
  5. Dec 25, 2013 at 9:13 PM
    #65
    95 taco
    95 taco Battle Born
  6. Dec 25, 2013 at 9:17 PM
    #66
    ArMarine04
    Alan
    Beaufort, SC
    Appreciate the heads up man, I'll consider it!
  7. Dec 26, 2013 at 7:06 AM
    #67
    dxpsman
    Brandon
    Oceanside, CA
    Cooper Discoverer ATP. As far as hybrid tires go, this is absolutely going to deliver the most bang for your buck in that size. Note that this tire is in the process of being phased out and replaced by the Discoverer AT3 (which is what my Taco will be graced with once the lift is installed), so check on both when you actually buy, as both are available. With either, you're going to get above average offroad performance with very good ride quality on-road. Depending on driving habits, they're also relatively long-lasting compared to other A/T (General Grabber A/T2, Falkens, anything made by Nitto).
  8. Jan 1, 2014 at 2:47 PM
    #68
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Mine was nose high too. Adjustment was easy, thread down .25" for a .5" drop I believe. I took before and after measurements and did some driving to let it settle too. Still high after driving.
  9. Jun 23, 2014 at 10:23 AM
    #69
    Snoozer
    Snoozer Member
    Colorado
    12 Tacoma OffRoad
    How about an updated review? :D Still happy with your BOSS kit?
  10. Jun 24, 2014 at 4:56 AM
    #70
    ArMarine04
    Alan
    Beaufort, SC
    Sure thing man! I've got about 4-5 thousand miles on it since install city and ALOT of highway miles still haven't really off roaded it yet though except for some rough dry dirt road if you call that off roading (my stock tires are too wore out for that!)
    So far I'm quite happy with the ride and under Normal driving condition I find it hard to tell the difference from stock but at lower speeds you can really feel the stiffness especially going over speed bump type obsticles faster than they are intended to go over. And on that note, the rough dirt roads I mentioned above, trying to go fast on said road it got a little rough so I wouldn't recommend them for any crazy high speed desert driving like the folks out west do!
    The front end wasn't adjusted at all upon install but over the course of driving it since it's installed I've noticed the springs have settled a little bit and I need to adjust them up some to set it back level but that's expected with any lift I'm sure. Oh and the Dakars squeak a little but we already know that!
    I don't have anything but the stock suspension to compare it too but overall I'm quite happy with the quality of the lift and would reccomend it to anyone looking for a quality comfortable lift. I opted for all the add ons the lift included like the Dakars and UCAs so whether you got just the standard options for 11-12 hundred bucks or spend a little over two thousand on all the bells and whistles the kit offers I'd say it's money well spent!
  11. Jun 25, 2014 at 5:47 AM
    #71
    Snoozer
    Snoozer Member
    Colorado
    12 Tacoma OffRoad
    :cheers:
    That's good info. Thanks.
  12. Jun 30, 2014 at 6:37 AM
    #72
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    thanks op. I have had the boss front coils for awhile now waiting on rear leafs to put every thing on. I was unsure of it but its good to read you how much you like them. truck will see about the same road conditions as yours.
  13. Aug 13, 2014 at 4:33 PM
    #73
    guitar2323
    guitar2323 Well-Known Member
    clint
    saratoga springs new york
    2013 access cab TX Pro
    Is it difficult to adjust the Boss coilovers?
  14. Aug 14, 2014 at 3:55 AM
    #74
    ArMarine04
    Alan
    Beaufort, SC
    I finally adjusted them for the first time a couple weeks ago. after I measured and got the truck in the air, I found I needed to drop the sway bar so I could get the wrench in and actually be able to turn it and I first it was a bitch and I literally couldn't turn it at all just using the provided wrench but after I slipped about a four foot pipe over the end and got some good leverage it made it exponentially easier, granted because of the limited space I had to turn the wrench I could only really get about a 1/8 turn in at a time but slowly and surely it got there. Once I figured out the best way to do it wasn't difficult at all.
    I need to go adjust them again because all I did was get the "taco lean" out of it been driving it around to see how it will sit back down and now I need to get it level with the rear.
    hope that helped!!
  15. Nov 3, 2014 at 1:44 PM
    #75
    TacoShane13
    TacoShane13 Member
    Texas
    13 Tacoma
    OP is the lift you are running the Eibach all around? About to order the Boss suspension with add a leaf/Chaos UCAs and wanted to know if you had the 5100s or the Eibachs. How do you like the suspension overall? Saw some back and forth between Toytec and Icons...have heard great things about Toytec and haven't really looked into Icons.
  16. Nov 3, 2014 at 6:00 PM
    #76
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    I didn't realize Eibach made shocks.
  17. Nov 3, 2014 at 7:38 PM
    #77
    TacoShane13
    TacoShane13 Member
    Texas
    13 Tacoma
    Nope, talked to the guys over at Toytec VIA phonecall and they said it is now Eibachs all around with the Boss suspension, no longer 5100s/Eibach combo (I think they said you have the option to run 5100s with the ultimate lift kit but Boss is running all Eibach).
  18. Nov 4, 2014 at 6:28 AM
    #78
    ace96
    Western KY
    Thanks for clearing that up. I edited my post....:rolleyes:
  19. Nov 4, 2014 at 6:41 AM
    #79
    TacoShane13
    TacoShane13 Member
    Texas
    13 Tacoma
    I'm going to call again today just to make sure it is Eibachs all around, but I'm like 90% sure that is what they said-Ill give an update once I do. I'm hoping it will be a good suspension for what I do. I don't beat the piss out of the truck at all..in fact, it's 14 months old this month and I have only put 5300 miles on it :thumbsup: haha. I travel a lot for work so its a garage queen most of the time. Basically I want something that when I do drive it, I want to know that if I wanted to offroad a little, I could. I come from the other side of things where lowering your vehicle is the thing to do. Eibach coils have always had a good rep on that side of the business so I don't see why going higher would make much of a difference in quality. Any input from anyone running this lift would be great. Ive heard more good then bad so I think I'm going to go with it but I just want to see what other thoughts are!
  20. Nov 4, 2014 at 7:01 AM
    #80
    Stuligan
    Stuligan Well-Known Member
    Ontario, Canada
    05 TRD OR 4L V6 6spd
    Billy 5100 level lift (0.85" front) White/Amber DRL/Signal Kit GTA Car kit for AUX/IPod Satoshi Grill 2x 20" LED Light bars behind grill HID headlights LED Taillgihts LED interior lights.
    I've got the boss kit with the 10 leaf pack and total choas UCA's waiting for me to pull the trigger, how has it been so far? Any issues with it that we should be aware of?
    I'm getting the frame replacement done in December, and I'm hoping to do the lift after that.
