Brake Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by hardtaco, Dec 20, 2008.
  1. Dec 20, 2008 at 5:51 AM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    I have an 04 Double Cab PreRunner V-6 and I am having issues with my brake light on the dash coming on at times. I have recently replaced my front brake pads, rear shoes have around 70% of meat left, and we have adjusted the parking brake cable to provide between 10-12 clicks on the lever when pulled out per repair manual directions. I have also checked my brake fluid resevoir, and it's fine. Usually in the morning, after releasing my parking brake lever, the indicator on the dash will stay lit for a few minutes. I have also noticed it light up if I really stand on the brakes to stop quickly in traffic. I am wondering if I may have a faulty sensor somewhere in the brake system. I would say my brakes are mechanically sound, but this light on the dash is driving me BONKERS!!! HELP!!!
  2. Dec 20, 2008 at 5:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Fill the brake fluid to the "Full" line.
  3. Dec 20, 2008 at 6:11 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    It's there.
  4. Dec 20, 2008 at 6:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure what else it could be. Seems you covered everything.....???
    GQ7227 likes this.
  5. Dec 20, 2008 at 6:42 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
  6. Dec 20, 2008 at 7:28 AM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    I recently had the same problem... for me it turned out to be a stretched parking brake cable. I was going to fix it but since I have an auto and never really use the parking brake i figured i would just leave it. If you do use your parking brakeyou should probably get it replaced since you may run into it sticking a bit while your driving. Mine is off and stays off.
  7. Dec 20, 2008 at 12:17 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    yeah I would say check the switch that operates for the parking brake.. my one truck had the little pin that hits it bend (how I have no clue) so I adjusted the switch out little farther
  8. Jan 25, 2009 at 7:48 PM
    Rosco75
    Rosco75 Well-Known Member
    Clavet Sk
    2001 Tacoma SR5 TRD
    3 inch skyjacker lift, k&n FIPK, 33inch procomp mud terrain tires
    Hey the guy I bought my truck from showed me a trick with E-brakes. Get under your truck with some Anti-Sieze. Pull the boot that covers the E-brake L-arm out with a screwdriver nice and easy, blob some of the compound into the boot. Work it by hand for a bit till it feels loose, then the pin inside the boot that allows that L-arm to move will be lubed and protected from any more rust, repeat every fall before the salt truck comes out, works for me, no adverse affects! If that arm sticks, your brake (warning) light will stay on.
  9. Nov 15, 2020 at 1:19 PM
    surefoot
    surefoot Member
    carl
    1998 forest green taco 4x4 2.7 218k
    235/75r15 deep rain tires. chrome brush guard
    thank you ROSCO 75. read a post, roll in reverse and pull e brake out of the dash like rapid fire. when it tightens up you've adjusted your brakes. what he did not mention was the gap you have created between the shoes and the slave cylinder. proudly pulled back into the yard and almost took out the shed. pumped the ped slowly and it fixed the problem. oh look the lights on. don,t reply i,ll be greasing my L arm, thanks
  10. Nov 15, 2020 at 1:45 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    Tw historical archives ftw
