Brake tick ..... not from applying brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WebberLander, Sep 4, 2014.
  1. Sep 4, 2014 at 11:18 AM
    WebberLander
    WebberLander [OP] Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Hey Gang,
    I searched and found a lot of info on the notorious tick/click sound some of us hear when we apply the brakes, but that is not my issue here just to be clear. I replaced my rotors and pads up front before the wife took a road trip to New Mexico and Colorado. I got my parts from a local parts store and and didn't buy from Toyota just to be clear. She never complained on the trip of the sound and I didn't start noticing it until a week after she returned. Brakes feel fine; no warping/shuttering, and the truck stops straight.
    How to replicate the sound
    Simply driving down the road the sound starts up around 20 - 25 mph and the ticking gets faster and faster as I gain speed. Its only happening on the Passenger Side as well. As soon as I touch the brakes, the sound stops entirely.
    From my searches I found:
    http://www.tacomaworld.com/forum/technical-chat/17261-strange-clunking-sound-front-end.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/138971-front-passenger-brake-clicking.html
    and this one that is similar to my issue:
    http://www.tacomaworld.com/forum/wheels-tires/8727-ticking-noise-drivers-front-wheel.html
    I took off the passenger wheel this past weekend to inspect everything ensuring it wasn't a wheel bearing, CV boot etc. All the above is fine. The clips on the calipers are in tact and the spring clip is as well. I pried on the rotor a bit with my hands just to see if it was loose or if something wasn't tightened down properly, but didn't notice any issues.
    However, the one thing I did notice was the bore on the rotors as there is just a little bit of play with the wheel off. I can move the rotor clockwise or counter-clock wise just a little bit and thought that might have something to do with it? On other cars I've done I have not noticed as much "play" with a rotor so this is my thinking on this.....
    I put the wheel back on, got out my torque wrench and ensured the lugs were torqued to spec. Took the truck for a drive and before I even got off my neighborhood street I could hear the ticking again from the passenger side.
    Its driving me NUTS!!!! Anybody offer some help on what I can do or check to get rid of this issue?
    :help: !!!!
  2. Sep 4, 2014 at 11:28 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    You ever jack up the truck and spin the wheel you think is making the noise?
  3. Sep 5, 2014 at 2:35 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That clockwise and counter clockwise movement of the rotor is normal.
  4. Sep 5, 2014 at 4:06 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Make sure you have everything bolted tight and all pins are in place
  5. Sep 5, 2014 at 8:45 AM
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Will do fellas; thanks for the responses.
    I didn't spin the wheel&tire while I had it jacked up; that's a good idea to see if i can replicate the sound.
    Will report back if I find anything.
  6. Sep 5, 2014 at 9:02 AM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Have you checked the tire for rocks in the tread or a nail??
  7. Sep 5, 2014 at 11:11 AM
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Yes in fact that was my first assumption, but while the wheel and tire was off the truck I looked and didn't find anything. Also as I mentioned in my OP, the sound stops with the slightest touch to the brake peddle......
