Brake Upgrade: StopTech Rotors + TRD Performance Pads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Dec 12, 2017.
  1. Mar 8, 2023 at 3:38 PM
    #1201
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    You can't miss with OEM. Just my humble opinion though.
    WilliamJames likes this.
  2. Mar 8, 2023 at 3:49 PM
    #1202
    lbhsbz
    lbhsbz Well-Known Member
    Here's the problem with aftermarket shoes...
    They're never arc'd correctly. They're close, but not right. With a drum brake system, we want the contact to be in the center 2/3 of the lining...not the top, not the bottom. Eventually things wear in and we have 100% contact, but that's not what we want initially unless it's perfect, which it won't be. If the leading edge of the top shoe contacts first, we'll have excessive bite and that doesn't work. A lot of the friction linings used on aftermarket stuff has pretty low friction levels so it contributes more to taking up space and giving a decent brake pedal than it does stopping the truck. Nobody notices because the rears don't do much most of the time. It's rare to have a parking brake work as good with aftermarket linings in the back than with OEM linings. The cost difference isn't worth taking the chance IMO.
    Drums are a problem because they're reverse engineered. When reverse engineering something, holes get toleranced bigger and things that go through holes get toleranced smaller. This is true of the drum center pilot hole. Its rare to find an aftermarket drum that centers on the axle pilot as nicely as an OEM drum. Toyota knows their toleranced dimension on the axle pilot and created their drum prints accordingly. The aftermarket has no idea....so we just measure up a few OE sample drums and call out the smallest dimension +0.1mm
    Stick with OE
    GilbertOz likes this.
  3. Mar 13, 2023 at 12:48 PM
    #1203
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Need to retract this! DO NOT order from Mbenzgram!! Had to file a claim with my CC company after those scumbags charged (they did that immediately) and then ghosted me.
    Honestly, not too upset I can get those stoptech rotors discussed in the OP; probably not worth the huge premium over OEM type.
    BOMBS, Norton and MGMDesertTaco like this.
  4. Mar 13, 2023 at 1:07 PM
    #1204
    MGMDesertTaco
    They sent me an invalid coupon code. I think I'm going with Wilwood's BBK instead.
    https://www.wilwood.com/BrakeKits/B...oyota&model=Tacoma&option=4+x+4+(6+Lug+Wheel)
  5. Mar 13, 2023 at 1:14 PM
    #1205
    lbhsbz
  6. Mar 13, 2023 at 1:26 PM
    #1206
    TireFire
    Olympic Peninsula
    3JOH22A likes this.
  7. Mar 13, 2023 at 1:39 PM
    #1207
    MGMDesertTaco
  8. Mar 13, 2023 at 1:42 PM
    #1208
    TireFire
    Olympic Peninsula
    MGMDesertTaco[QUOTED] likes this.
  9. Mar 13, 2023 at 1:47 PM
    #1209
    bryanh69
    bryanh69 Well-Known Member
    2015 MGM Toyota Tacoma TRD OR
    I wish I had remembered that when I was buying wheels....
    TireFire[QUOTED] likes this.
  10. Mar 13, 2023 at 1:47 PM
    #1210
    lbhsbz
    If you've got your heart set on going bigger....I'd go with that setup in the link. But...if you haven't had problems burning through pads or cracking rotors, the stock sized stuff is fine. Upgrade the pads, fix what's wrong with it, they'll work great.
    the Wilwood setup....they're increasing the effective radius by 4mm (basically nothing) and going to a slightly smaller total piston surface area. There's no reason (on paper) why the wilwood stuff should perform even as good as the stock stuff.
  11. Apr 16, 2023 at 1:07 PM
    #1211
    Rbcb01
    Rbcb01 Active Member
    2017 TRD Offroad
    Ibhsbz how do I get information on this pad rotor combo you are talking about on here
  12. Apr 17, 2023 at 5:14 AM
    #1212
    bryanh69
    click the link in his post...
    you will need 17 inch rims.
  13. Apr 24, 2023 at 5:19 PM
    #1213
    iiggii
    iiggii Well-Known Member
    jeff
    2010 tacoma access
    lift n radio
    y
    es gonna do this.;
  14. May 2, 2023 at 8:09 AM
    #1214
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  15. May 2, 2023 at 8:12 AM
    #1215
    lbhsbz
  16. May 2, 2023 at 8:38 AM
    #1216
    TireFire
    Olympic Peninsula
    But it ships FREE !!
    LOL!
  17. May 2, 2023 at 8:40 AM
    #1217
    lbhsbz
    meh, mine go out with a FREE bag of M&Ms (when there's room in the box).
  18. May 2, 2023 at 8:41 AM
    #1218
    TireFire
    Olympic Peninsula
    I was being sarcastic.
  19. May 2, 2023 at 9:16 AM
    #1219
    lbhsbz
    me too...forgot the smiley
  20. May 3, 2023 at 7:10 AM
    #1220
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    Then you definitely don't want to see their big brake upgrade
    3JOH22A and TacoEspecial like this.
