Broken Skid Plate Bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jds0912, Aug 30, 2011.
  1. Aug 30, 2011 at 6:49 AM
    jds0912
    jds0912 [OP] Well-Known Member
    Justin
    Baltimore, MD
    2007 Tacoma TRD Off Road
    Some shit I got on craigslist
    So after getting my truck stuck a while ago (http://www.tacomaworld.com/forum/of...stuck-tacomas-lets-see-em-45.html#post3460665) I noticed I had a couple leaks from the front dif. oil seals. To go about replacing these I had to remove the skids. Upon doing so, I noticed that both of the welds were broken on the nuts that the front two skid bolts screw into, requiring me to cut them off. Also two bolts on the 3rd skid (trans skid?) broke off inside of the cross-member while extracting them!
    My question is, assuming I can drill these bolts out (any ideas on doing this), are there any replacement bolts I can use that arent so frail -where can I get them??
    Has anyone had broken skid bolts(I know the welds breaking on the front has happened to several people)?
    /replaced my oil seals fine (no leaks now), but want to get that third skid on for some wheeling this weekend :D.
  2. Aug 30, 2011 at 7:25 AM
    07NavyTaco
    07NavyTaco Well-Known Member
    Josh
    North Chicago
    07 SR5, short bed, 4x4, bilstein 5100s
    billy 5100s @ 1.75, black grill and lower valence, tinted windows
    good excuse for an upgrade. :D
  3. Aug 30, 2011 at 8:17 AM
    jds0912
    Justin
    Baltimore, MD
    If I bought a new skid it wouldnt really solve the problems I am facing at the moment. I wouldnt mind getting one, but my question was are there some better bolts to use, becuase the current ones suck balls. If I got the aftermarket one it would look like this:
  4. Aug 30, 2011 at 10:08 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    they make bolt extractor tools and they can be rented from autozone/advanced auto.
  5. Aug 30, 2011 at 10:13 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    I had one of the smaller diameter bolts that secure the rear mount on a front skid break off once. It broke off flush with the frame. I took a random nut I had laying around and welded them together, then used a large wrench and backed it out. It was pretty tricky to get the weld good enough to hold, if I remember it took 2 or 3 tries before it was strong enough to back the remnants out. You just have to be careful not to weld everything to the frame as well.
  6. Aug 30, 2011 at 11:36 AM
    jds0912
    Justin
    Baltimore, MD
    Yeah I wish I could weld; gonna take a class or something one of these days!
    So far what I have done is drill a hole in the remnants of the bolt and used an extractor bit to try to take it out. No luck yet, will try again once I can recharge my dewalt battery (no power still due to the hurricane)
  7. Aug 30, 2011 at 11:41 AM
    Nigel Croker
    Nigel Croker Member
    Treasure Coast of Florida
    06 Prerunner SR5
    Your screwed....TRADE IT IN.......:D
  8. Aug 30, 2011 at 12:04 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    If you can't extract it, drill it out and tap some new thread.
  9. Aug 30, 2011 at 12:05 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    you can get some good quality hardware from an actual hardware shop. But really the issue is more that the skid plate is meant for skids, not resting your truck on :D
  10. Aug 30, 2011 at 1:12 PM
    jds0912
    Justin
    Baltimore, MD
    I wish the damage was from wheeling. The bolts came off when I was loosening them with a socket wrench to take of the skid. Cheap ass bolts are cheap!
  11. Aug 30, 2011 at 2:19 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    rusted? right size socket? go get some good stuff, ace has never let me down.
