Bubbles in the coolant recovery bottle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tom Ferreira, Oct 14, 2019.
  1. Oct 14, 2019 at 10:49 AM
    Tom Ferreira
    Tom Ferreira [OP] Member
    Tom
    2005 access cab, 4 cyl, auto trans
    none
    I'm having a problem with air bubbles in the coolant recovery bottle. When I shut of the engine when its hot I could here an audible BLIP, BILP, BLIP coming from under the hood. Opened the hood and noticed tiny bubbles coming into the recovery bottle from the overflow hose. I noticed the coolant getting lower in the bottle over a week or two.
    Yesterday I poured in a bottle of Bars stop leak. Waiting to see what's going to happen. The truck has 217k on it. Anyone else having an issue like this?
    Hobbs likes this.
  2. Oct 14, 2019 at 11:24 AM
    adubkins
    adubkins New Member
    Aaron
    Central Texas
    '05 AC 4x4 4.0 Auto TRD Off-Road
    CAI, Exh. Cam Gears, CSF Rad., AFE Headers w/2.5" Exh., 2" Toytec Bilstein, 265/75/16 Mickey T's.
    Sounds as though the Head gasket has given up on you my friend. Is the expansion tank dirty as well? Might be exhaust gas leaking into the coolant via failed head gasket.
    My '05 4.0 is doing the same thing. I'm gearing up to tear it apart and replace the head gaskets (along with just about everything else that has to come off) within the next couple of weeks.
    I've seen a couple 4cyl threads on here replacing the head gasket but did not look into those too much as I was hunting for a 6 cyl write up.
    https://www.tacomaworld.com/threads/2006-4-0-v6-head-gasket-overheating-rebuild.609265/
    grizquad likes this.
  3. Oct 14, 2019 at 11:32 AM
    eon_blue
    Azusa, CA
    edit - didn't see that OP has a 4 cyl
  4. Oct 14, 2019 at 11:37 AM
    Blain
    Blain I ain't got time to bleed
    Tx
    2.7's had the same issue?
    eon_blue likes this.
  5. Oct 14, 2019 at 11:40 AM
    eon_blue
    Azusa, CA
    Good call I didn't see that under his avatar. To my knowledge they did not
  6. Oct 14, 2019 at 11:42 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    FLUSH THE STOP LEAK OUT IMMEDIATELY!!!
    Pull the tstat housing, pull the tstat out and flush the truck, PLEASE... that stop leak stuff just gums up EVERYTHING.
    Its likely as simple as a worn out radiator cap.
    whatstcp likes this.
  7. Oct 14, 2019 at 3:30 PM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    I used to do many head gaskets in small Diesel engines. Snap On had a solution and suction device that would turn the solution a different color if you were getting exhaust gasses in the radiator. Among several other things to check, this was a quick painless check that worked.
  8. Oct 14, 2019 at 3:43 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    I would stay away from the Bars Stop Leak until you know what is going on with your engine.
    It is not unusual for coolant to be pushed into the overflow bottle soon after shut down. The engine goes into hot soak and briefly increases in temperature.
    I recommend closely monitoring your coolant level going forward. Be sure to check it on a regular basis, and account for engine temp's when checking levels (always check it near the same temp). If you are losing coolant, pressure check the system and repair any leaks.
    If it were my truck, I would replace the radiator cap and thermostat.
    If you tighten these things up and are still losing coolant, check for exhaust gasses in the coolant (reveals head gasket leak). it is easy to check with the following kit:
  9. Oct 14, 2019 at 5:11 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    You said you had noticed coolant level getting low over a few weeks. That's a sign, bad rad cap poss but not likely. Have you seen any visible signs of coolant leaking? No, ohh oh, head gasket.
