Buyer beware: Magnaflow 17115
Discussion in '2nd Gen. Tacomas (2005-2015)' started by That Dude Tim, Mar 17, 2011.
  1. Mar 17, 2011 at 5:23 PM
    That Dude Tim
    That Dude Tim [OP] Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    Just got my Magnaflow exhaust "Pro Off-Road" product num. 17115. Magnaflow website didn't specify any bed length. My truck is a 2011 Double Cab with long bed. The kit mounts to the y-pipe flange and goes to the first muffler hanger, their muffler, then the tip to the last muffler hanger (exits in front of spare tire). The kit says it fits extended cab/crew cab 2.7/4.0, doesn't specify a bed length. Luckily I work at a toyota dealer and confirmed my assumptions, the kit fits only extended cab/ crew cab(double cab) tacomas with the short bed. The mid pipe is short 13in if you hang it in the hanger and measure the gap to the y-pipe flange.
  2. Mar 17, 2011 at 10:39 PM
    1bads11
    1bads11 Member
    Canada
    11 TRD Sport
    K&N CAI, Magnaflow
    I found out the hard way as well but resolved it quickly to fit. Took it to a muffler shop and they welded on a 13 inch piece to extend it for $100. Sounds great. It can be quiet below 2500rpm so when starting in the morning it doesn't wake up the neighbors but when you go above it watch it. Sounds way better than the Borla I had on my last Tacoma.
  3. Apr 27, 2011 at 2:30 PM
    Kauaitoyota
    Kauaitoyota Member
    2005 TRD sport
    3" Pro Comp lift 265 70 R17 MK2
    Will the Magnaflow 17115 fit the extended cab 4x4 sport? Im on the verge of buying, but the website doesnt state it clearly that it WILL fit an extended cab.
    it says extended-crew cab short bed.... now unless im totally clueless isnt it either (Extended cab OR Crew cab?)
    this is from the Magnaflow Website-
    (V6 4.0L; Extended-Crew Cab/Short Bed
    Off Road Pro Series; 5 x 14in. Muffler; 2.5in. Tubing; 3.0in. Turn Down; TURN DOWN IN FRONT OF REAR TIRE)
    Please help!
    Thank you
  4. Apr 27, 2011 at 4:17 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    It would probably be safe to assume that the extended cab and the double cab short bed are close if not the same length.
  5. Apr 30, 2011 at 11:21 AM
    Kauaitoyota
    Kauaitoyota Member
    2005 TRD sport
    Thank you for your help!
