Buying New Brake Parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Donny Nutz, Aug 25, 2020.
  1. Aug 25, 2020 at 8:17 AM
    Donny Nutz
    Donny Nutz [OP] Member
    Donny
    Nuthanialitz
    2012 V6 Offroad.
    I'm going to buy new brake pads and rotors for a DIY replace on the front brakes soon.
    I've seen on this forum that many people insist OEM is the only way to go for this. Just curious as to why this is. Is it simply a longevity thing?
  2. Aug 25, 2020 at 8:36 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    When you go aftermarket, you find a huge range of options. Anything that's cheap is probably a POS. That's why people recommend sticking with OEM.
    But there are aftermarket options that are on par with OEM, but you usually have to pay close to OEM prices for them. Hard to go wrong with OEM, and that has a known quality.
    wags and Donny Nutz[OP] like this.
  3. Aug 25, 2020 at 9:10 AM
    LordOfTheFlies
    LordOfTheFlies Well-Known Member
    2014 Tacoma TRD Sport 6 spd Access
    Bought the truck used in March 2020 with 96k and the brakes were almost done on the front. Here is my thread on what I went with.
    I find them way better than stock. More bite, less dust, no squealing at all. Been running this combo with a full bed of firewood and have been extremely pleased.
    Hawk LTS pads + Brembo rotors.
    EdgemanVA and Donny Nutz[OP] like this.
  4. Aug 25, 2020 at 9:20 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    For me, I get 100k out of front pads. For the money, it's a no brainier.
    Stay away from those lifetime warranty pads. Unless you enjoy doing brakes every 18-24 months. Ya, they give you new pads, but you'll be replacing rotors on your dime.
    Donny Nutz[OP] likes this.
  5. Aug 25, 2020 at 9:34 AM
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    I put Hawk HPS pads and Brembo rotors on the front of my Acura TSX. Great stopping power, but they are a little "dusty."
    https://www.hawkperformance.com/hps
  6. Aug 25, 2020 at 9:38 AM
    Donny Nutz
    Donny
    Nuthanialitz
    Also for you OEM guys, do you find you end up needing replacements for all the assembly springs and whatnot too? I've noticed that lots of aftermarket option come in kits with replacements for these, but parts.toyota.com doesn't seem to have a similar option other than buying each piece separately.
  7. Aug 25, 2020 at 9:52 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    When I last spoke with my dealer they don't regularly change out springs or shims unless there is a problem with the OME parts...I'm sticking with OME pads and be done with it....Good luck - keep us posted
  8. Aug 25, 2020 at 12:30 PM
    LordOfTheFlies
    Change your guide pins. I don't think any pads come with those. Mine were bent and were a bear to tap out. Make your life easier and just order them now.
    Tacotj likes this.
  9. Aug 25, 2020 at 12:40 PM
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
  10. Aug 25, 2020 at 12:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    OEM, Advics, or Akabono are my recommend brands for quality.
    They seem to last and have less brake noise or fitment issues.
    That being said, I went with Advanced Auto Premium. No issues in 70k+.
    I did replace all brake parts when doing the pads.
    If I do brakes for other people,
    I still recommend the ones above, as they almost always work with no issues.
    (Advics, OEM, or Akebono)
    Capespencer68 likes this.
  11. Aug 26, 2020 at 5:53 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I just bought OEM pads, rotors , new pins and the cotter pins for 181.13 (including 6% tax) not expensive imo . The cotter pins are like .25¢ and the pins are like 3 or 4 $ if I remember correctly I got part numbers too if you need them .
  12. Aug 26, 2020 at 5:55 PM
    TnShooter
    Deogee
    STOCK
  13. Aug 26, 2020 at 6:05 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    some things U simply dont scrimp on
    OEM while very pricey................U know what U r getting
    consistent driving habits get U relatively same results .............same mileage .........same performance
    many OEM products are ' matched ' result being they arent sketchy
    on the aftermarket side IF U had the luxury of laying out pads from Napa.....rock....oreilyly etc
    U would SEE Actual flintstone differences
    some will get U out of a shop.......get U an inspection sticker
    Will NOT Stop On A DIME !!
  14. Aug 26, 2020 at 6:21 PM
    Rsmallw2
    Rsmallw2 Well-Known Member
    Michigan
    06 Tacoma PreRunner V6
    Brembo rotors and Akebono pads from rock auto is a great combination for stopping power and longevity.
  15. Aug 26, 2020 at 8:52 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Because factory parts work best.
  16. Aug 27, 2020 at 4:56 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    The lemmings on TW use the logic that: "it came from the factory this way, lasted this long, so it must be good" - ........"Because factory parts work best"......and while that's correct, there are many after market alternatives (some already referenced) to OEM. There ARE some value and performance alternatives to OE that don't sacrifice safety or performance. Do some additional research. Check other automotive forums. Then,if you can't figure it out, just stay with OEM.
