Calling all Virginians (Tidewater area)
Discussion in 'Virginia' started by Alaskaflyer, Dec 26, 2008.
  1. Mar 18, 2013 at 7:40 AM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
  2. Mar 18, 2013 at 7:47 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Ill be helping Paul on his truck this weekend (Saturday). I think Burry will be hosting but I dont want to speak for him.
    I think we need to get a mod day together. I did my AAL's by myself and leafs should be easier, but I wouldnt recomend it. An extra hand will go a long way.
  3. Mar 18, 2013 at 7:53 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Bump for anyone interested in sliders. $165-185 with free shipping (if we have enough orders).
  4. Mar 18, 2013 at 8:02 AM
    Enders Taco
    Enders Taco Well-Known Member
    Ben
    Hampton Roads VA
    DCSB 4x4 6SP
    All Pro APEX Front Bumper, All Pro Sliders, Icon Coilovers with rear shocks and add a leaf pack, URD short shifter, Pioneer X930BT Nav with Polk speakers
    Lets see, 12, 17, 19, and 22(maybe 21) MM sockets, 19 mm wrench, breaker bar, recommend a tube for the wrench as the 19mm nut near my gas tank was the only one that was stubborn, 12mm Flare Wrench for the brake lines, grease for the bushings on the springs, small thing of brake fluid unless you plan on replacing your brake fluid completely.
    Two jack stands, and a floor jack with wheels will make lining the axle back up MUCH easier. Removing the top braket on the brake lines makes that much easier. You must remove the shackle where it attaches to the frame, so hit that bolt early on. On the driver side, this required me to lower my spare tire. The new leafs are easier to install if you unbolt the shock. My icons are now my limiting factor to droop.
    Two of us, in the cold and slightly raining conditions took 5 hours for lines and leafs. If you are doing both, do the drivers side first. Pull the tire, brake lines, leaf pack in that order. Install new brake lines, new leaf pack with double wrapped end going to fixed point (forward), attach u bolts then bleed brakes on drivers side. Having done a set, I could probably knock it out within 2-3 hours.
    I has blisters on my hands from removing them then reinstalling them. The nuts get hot as fuck too.
  5. Mar 18, 2013 at 8:26 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    I didn't get blisters but we used a little WD-40 and took breaks to keep them cool.
  6. Mar 18, 2013 at 8:27 AM
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Would be real nice if they cut us a break with 5 orders. If we can't get to 5, see if they'll at least give us a discount, maybe 10% or something ???
  7. Mar 18, 2013 at 8:42 AM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    Knapp caint this weekend daughters birthday first weekend in april
  8. Mar 18, 2013 at 8:46 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
  9. Mar 18, 2013 at 8:49 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    He hasnt responded to my original PM but when he does, we'll see... More ppl sign up the better.
    :confused: Egrish prease.
    I can host. Plenty of space but limited in tools.
  10. Mar 18, 2013 at 8:49 AM
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    you got a little more than a blister :D
  11. Mar 18, 2013 at 8:54 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    I saw some guys talking about air tanks.
    Here is my ViAIR 2.5 gallon tank under the bed
    the whole thing hangs about 1" below the frame rails and its right behind teh center of the axle. you would have much bigger problems if you bounced it off of something.
    I also had another design for the crossmember that would hold the entire weight of the truck if needed.
    Justin
  12. Mar 18, 2013 at 8:58 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    That wasn't U-Bolt related. That was dropping the whole axle on your finger related.
  13. Mar 18, 2013 at 9:12 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Just spent 260 at amsoil :eek:
  14. Mar 18, 2013 at 9:20 AM
    YotaMatt
    West Point VA
    It was only one side :rolleyes:
  15. Mar 18, 2013 at 9:24 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  16. Mar 18, 2013 at 9:29 AM
    Burgman
    Stephen
    Ric VA
    Note to self dont work on trucks with these guys:p
  17. Mar 18, 2013 at 9:31 AM
    Burgman
    Stephen
    Ric VA
  18. Mar 18, 2013 at 10:14 AM
    Enders Taco
    Ben
    Hampton Roads VA
    DCSB 4x4 6SP
    I need to hire your services :D
    The only spot that I know I'm rubbing right now is the body mounts. Let me know what I need to do to make it worth your time please.
  19. Mar 18, 2013 at 10:19 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Pay him monies :p
  20. Mar 18, 2013 at 10:21 AM
    Burgman
    Stephen
    Ric VA
    He also accepts other services... dont ask how i know but have u seen my sweet ass tire carrier
