Camera mod switch for console?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Relik, Nov 10, 2010.
  1. Nov 10, 2010 at 10:05 AM
    Relik
    Relik [OP] Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Hey guys,
    I want to do the camera mod that allows for the any time camera option, but the mods all done that i can find on here are for a switch uptop the mirror.
    Anyone know if the same wires go under the console or if another way to use a switch other than above? It'd be nice to use one of the blank switches next to the 12V outlets.
    Thanks
  2. Nov 10, 2010 at 10:18 AM
    Relik
    Eddy
    Thousand Oaks, CA
    Right, but i would think it'd be a pain to run it from uptop down, especially if those same wires already do run down by the console, or behind the dash etc....
  3. Nov 10, 2010 at 10:29 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    I believe the wiring harness for that comes under the dash by one of the posts (driver side?).....under door threshold back along the driver's side of the vehicle. Try following it back up from the tailgate connector and you will probably find out which way it runs.
  4. Nov 10, 2010 at 1:01 PM
    jivewalker
    jivewalker me gusta pechos firmes
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS
    I like this idea a lot. Subb'd :)
  5. Nov 10, 2010 at 3:57 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    the power wire is behind the drivers knee, i tapped into it for my reverse camera turn on with my old headunit. I would assume you could rig a switch and tap into it so when you supplied the wire with power it would trigger the rearview display.
    shouldn't hurt to try it since it is already setup for a +12v input.
  6. Nov 10, 2010 at 4:12 PM
    Relik
    Eddy
    Thousand Oaks, CA
    What do you mean? The seat is behind the knee ;) Do you mean in the console next to where you're right knee rests? or in the dash about where you're knee is?
    Thx
  7. Nov 10, 2010 at 4:15 PM
    gringo77
    gringo77 Member
    Braselton Ga
    2011 DC LB TRD Sport
    sub'd as well. interested in outcome
  8. Nov 10, 2010 at 4:18 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Well obviously it wouldn't be in the seat :), in the dash at the drivers knee is the area it is, pull off the panel and its behind there.
    I have the link with pictures somewhere.
    Edit: Found'em :
    http://www.tacomaworld.com/forum/audio-video/19553-2009-nav-install-hook-up-back-up-camera.html
    http://www.tacomaworld.com/forum/audio-video/30889-oem-camera-connection-below-dash.html
  9. Nov 10, 2010 at 4:19 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    yes, this also.....the screen isn't made for long time viewing. Good for checking on a trailer, but other than that it has no real advantage.
  10. Nov 11, 2010 at 8:57 AM
    jivewalker
    Jack MeHoff
    Chucktown
  11. Nov 11, 2010 at 11:50 AM
    spearhead
    spearhead Taco Supremist
    Winston Salem NC
    09 4DR Mag Grey 4WD Sport
    TRD CAI Eibach Springs 5100s all around Front set to .85 Toytec AAL
    I wrestled with this one for 10 forevers. Save yourself some grief and go aftermarket. Screen size, accessibility, and custom switch options will make you glad you did.
  12. Nov 11, 2010 at 11:53 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    Your pioneer doesn't have a reversed image camera?
  13. Nov 11, 2010 at 12:02 PM
    spearhead
    Winston Salem NC
    It does, but it also accepts any camera with the same RCA in as the one I got with it, so I assume that always displays as a general disclaimer.
    The camera actually has its own remote where you can adjust the image/add grid lines for parking/etc. I have it mounted between the camera switch and the Aux input-just too dark of a pic.
