Camping
Discussion in 'Sports, Hobbies & Interests' started by plaindan, Mar 31, 2008.
  1. Mar 31, 2008 at 9:52 AM
    plaindan
    plaindan [OP] New Member
    I was wondering if any body pulls a camper with there tacoma? If you do what size is it and what is the weight of the camper you pull? thanks
  2. Mar 31, 2008 at 12:07 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    2006 Jayco Jayfeather 197. 21', single axle, 3550 lbs wet and ready to camp.
  3. Mar 31, 2008 at 4:00 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I wish, I am looking for an Airstream but the dealer went bellyup.
  4. Apr 4, 2008 at 10:35 AM
    ninja_taco
    ninja_taco Well-Known Member
    Nick
    Louisiana
    '10 Prerunner
    Vanillarama Pinetree Scent
    do yall think a my reg cab 4 cyl. 4x4 could pull a pop up? i know im rated at 3500 lbs. so i guess i may have just answered my own question as long as the camper is rated under 3500
  5. Apr 4, 2008 at 10:51 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    If you stay in the flat areas, you could probably even go higher than the 3500 lbs. I bet that rating is limited due to the requirement to occasionally tow uphill.
  6. Apr 4, 2008 at 10:52 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I've even seen a tacoma around town that has a full camper shell in the bed. It's pretty cool looking, but I don't have the need for that sort of thing.
  7. Apr 4, 2008 at 11:35 AM
    maverick491
    South Jersey
    As long as the camper is less than 3500 lbs you should be good to go. DO NOT excede the tow rating, they are there for a reason.
    Check the Tacoma Towing Bible stickied at the top of the technical section for anything else you might need to know about towing safely.
  8. Apr 5, 2008 at 5:34 AM
    plaindan
    Maverick491 If I found a camper that is in the pulling capasity, yet the hitch weight is 715 lbs. yet the rating for my truck is only 650 lbs. Is there any thing I can do to increase my hitch weight rateing?
    plaindan
  9. Apr 5, 2008 at 6:03 AM
    maverick491
    South Jersey
    Generally, the Deep Cycle battery is mounted on the tongue, depending on if the camper in question uses a single or dual battery set-up, you could save 50-100 lbs of tongue weight by re-locating the batterie(s) to a secure location inside the coach, preferably directly over the axle(s). If you would be un-comfortable with the wiring involved in doing that, most RV dealers would not charge a rediculous amount to do that re-location.
    If the camper in question uses a dual 20lb propane bottle set-up, you could switch that to a single 30 lb bottle or even to a single 20lb bottle and save between 10 and 20 lbs on the tongue weight there also.
    Electric tongue jack also weighs more than a manual crank jack, so if it has that option you could also swap that out.
    Now just to clarify, are you reading your weight ratings from the cabinate door of the actual unit you are looking at or from a brochure? And are you reading the un-loaded vehicle weight or the GVWR of the trailer?
    The reason I ask is it is really un-likely that a trailer would be built with a tongue weight of 715 lbs, but a GVWR of 6500lbs or less. If it is built like that, it is technically not built correctly, and I'd caution you to consider a different trailer. Most manufacturers build to the accepted standard of tongue weight being 10% of total weight.
    All that said, if you re-locate the battery(s) then it should keep your tongue weight close enough to the accepted weight requirement that a good quality Weight Distribution hitch and Dual cam sway controll should enable you to tow it safely.
  10. Apr 5, 2008 at 6:08 PM
    plaindan
    Thanks for your help. The GVWR for the trailer is 7715 lbs. but figured that with the dry weight only being 3920 lbs. I could take what i wanted with me and still stay under the 6500 lbs. It isn't a regular travel trailer it is a toy hauler and even with the weight of two big ATVs i still have right at a thousand lbs. for the other stuff. Thanks
    plaindan
  11. Apr 12, 2008 at 4:55 PM
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
    one more quick question, not sure if this is even the right thread to post in but where would be the best place to purchase a hitch? i don't mind ordering off the internet.
  12. Apr 12, 2008 at 5:30 PM
    maverick491
    South Jersey
    Hitches and wiring for non-tow package equipped trucks are covered in the Tacoma Towing Bible chapter nine.
    Linked below.
    http://www.tacomaworld.com/forum/technical-chat/4031-tacoma-towing-bible.html#post35027
    Here's another place to buy hitches on-line (though I'd advise against the Curt brand hitch in the following link).
    http://www.etrailer.com/hitch-2007_Toyota_Tacoma+Pickup.htm
  13. Apr 12, 2008 at 11:02 PM
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
  14. Dec 27, 2011 at 12:05 AM
    stojanovich
    stojanovich New Member
    tony
    BC
    02 tacoma 4door SR5
    Load buddies
    I've got a nice camper that fits nicely in the back of my 2x4 taco quad cab - my problem is the front hold downs. i cannot mount abelly bar on account of the gas tank and I can't see another way tp hold it down at the front.
    any ideas/
  15. Jan 19, 2012 at 9:21 PM
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
    I'm planning to build a small camper and I'm adding the extra d-rings to the front of bed. I'm going to have access doors from inside the camper to the space in front of the wheel wells so I can attach tie downs to the d-rings. The method in the link here mounts the d-rings to the frame so they'd be solid place to mount he camper tie downs. Got pics of your camper?
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/28533-installed-d-rings-bed-pics.html
