Can I use this oil filter?
Discussion in '3rd Gen. Tacomas (2016+)' started by fiftyxp, Mar 19, 2019.
  1. Mar 19, 2019 at 9:26 AM
    fiftyxp
    fiftyxp [OP] Well-Known Member
    2017 trd offroad 4x4
  2. Mar 19, 2019 at 9:27 AM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    Yes you can.
    fiftyxp [OP] likes this.
  3. Mar 19, 2019 at 9:28 AM
    fiftyxp
  4. Mar 19, 2019 at 9:28 AM
    VE7OSR
    VE7OSR Well-Known Member
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Why? get the best filter - Toyota OEM. Buy several at once, so you are always ready to change oil at your convenience.
    cwdog, over60 and TnTuna like this.
  5. Mar 19, 2019 at 9:32 AM
    fiftyxp
    link?
    do you mean the one that that just its in the housing? idk im not a fan of that one it just doesnt seem right. or is there another?
  6. Mar 19, 2019 at 9:37 AM
    VE7OSR
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  7. Mar 19, 2019 at 9:43 AM
    fiftyxp
    VE7OSR likes this.
