Can Tacoma 3rd gen take integrated/aftermarket brake controller
Discussion in 'Towing' started by fgeorge097, May 30, 2018.
  1. May 30, 2018 at 12:00 PM
    fgeorge097
    fgeorge097 [OP] Well-Known Member
    Northeast
    2018 OR AT
    Clearly a total newb here,
    But I want to be sure a tacoma 3rd gen V6 can be equipped with some aftermarket trailer brake controller.
    Thank you.
    Trucknorris likes this.
  2. May 30, 2018 at 12:27 PM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    I have a 2nd gen, but I am pretty sure that the 3rd gen has the pigtail in the glove compartment to attach to a brake controller. The other end (at least with 2nd gens) attach to a plug on the left side of the driver under the dash. Hard to see because it is wrapped up with a bunch of other wires.
  3. May 30, 2018 at 1:37 PM
    k1w1t1m
    k1w1t1m Active Member
    Tim
    '17 Quicksand DCSB OR
    If your truck has the tow package then there should be a connector behind the kick panel by the drivers left foot. You will need to buy the controller and adapter cable. I think the late model Tundra cable is the correct one. Once you have the adapter cable it's just plug and play.
  4. May 31, 2018 at 12:48 PM
    Indy
    Indy Master of all I survey.
    I can put a brake controller on a 60s Volkswagen bug. I can do it on a Harley motorcycle. So yeah, you can do it on your taco.
  5. Jun 1, 2018 at 8:51 AM
    n1as
    n1as Well-Known Member
    2016 Tacoma DCSB TRD OR
    If you have the tow package you will have a connector under the dash. If not you will have to splice into truck wiring and run wires front to back.
  6. Jun 12, 2018 at 5:29 AM
    Spillproof
    Spillproof Well-Known Member
    Ken
    Nova Scotia
    2018 Inferno AC OR
    I did this last week on my 2018 OR. It has the towing package, so has a 7pin/4pin combo plug already installed on the rear bumper. All I needed was the the harness for the controller that works with the pre-wired factory plug. Mine was actually marked for Tundra. It is literally plug and play. Removing and replacing the kick plate covering the plug was the hardest part, and even that was simple.
  7. Jun 13, 2018 at 5:18 AM
    atrain23
    atrain23 Well-Known Member
    Alex
    New Hampshire
    2016 Tacoma SR5 DCSB V6
    TRD off-road wheels
    I just put one in my 2016 really easy. Just have to find a good place to mount it. I want to put in the cubby left of the wheel.
  8. Jun 19, 2018 at 10:23 PM
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2017 Toyota Tacoma TRD OR DCLB
    PNW Adventures on Kings, SCS F5 on BFG KM3 315/75/16
    Can anyone recommend a brand and corresponding harness? TIA
  9. Jun 20, 2018 at 3:21 AM
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    Tekonsha P3 with wiring adapter part 3017. Plugs right into the connector in the harness. Easy peasy.
  10. Jun 20, 2018 at 4:49 AM
    Spillproof
    Ken
    Nova Scotia
    2018 Inferno AC OR
    I went to a local supplier and bought this:
    https://www.curtmfg.com/part/51110
    $55 canuck bucks. It works fine and I can spend my money elsewhere. The P3's around here cost $150 and up.
    Hambone437 and PNWTacoma like this.
  11. Jun 20, 2018 at 11:28 AM
    PNWTacoma
    Paul
    Thank you both for your responses. I'll check my local Rack store and maybe even Uhaul before I order online.
  12. Jun 20, 2018 at 11:29 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Actually. I installed exactly that last night.
    PNWTacoma likes this.
  13. Jun 20, 2018 at 11:32 AM
    PNWTacoma
    Paul
    I know it's early, but any feedback on the unit yet?
  14. Jun 20, 2018 at 11:33 AM
    Herniator
    Edmonton
    It has power. But haven’t got the trailer yet. I’ll make a post after I actually use it. Lol
  15. Jun 20, 2018 at 1:07 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Txexplorer and PNWTacoma like this.
  16. Jun 20, 2018 at 1:36 PM
    Herniator
    Edmonton
  17. Jun 20, 2018 at 1:50 PM
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
  18. Aug 13, 2018 at 1:20 PM
    janis5151
    janis5151 Member
    Where did you all end up mounting the P3 contoller?
  19. Aug 14, 2018 at 12:46 PM
    PNWTacoma
    Paul
    I mounted mine beneath the left console, below the cubby section, directly to the lower dash.
  20. Jan 30, 2019 at 7:07 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    How's this controller working out? any installed pics?
