Can't get my 285's balanced. Should I try beads or a different shop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BraskaTaco, Aug 27, 2017.
  1. Sep 22, 2017 at 5:45 PM
    #41
    Devin06taco
    Devin06taco Active Member
    Devin
    2009 white RED Offroad
    3 inch rough country lift. 285/70/17 Toyo MT. Fuel hostage wheels More to come
    18 oz is a tire problem!. Look for a shop to road force balance
  2. Sep 22, 2017 at 6:46 PM
    #42
    Rthompson02
    Rthompson02 Well-Known Member
    NW Florida
    2015 AC with a Hand Shaker
    3 inch leveling kit.
    Are the wheels hub centric
    Are the wheels lug centric
    This is something you might find can cause a ride disturbance if the wheels aren't 100% snug
    You should inquire or check them yourself. If they are not hub centric then you will need an adapter to snug them up.
    So the wrong lug nuts can cause a disturbance as well.check figment and replace if necessary.
    The tire shop can use an adapter that bolts up to the lug hole instead of the hub opening. Many custom or aftermarket wheels require such an adapter.
    BraskaTaco[OP] likes this.
  3. Sep 22, 2017 at 6:50 PM
    #43
    Rthompson02
    NW Florida
    By the way, if the tires keep requiring a lot of weight, take them to the Michelin/Bfg authorized dealer and see about getting a warranty adjustment.
    Also I would be curious to know what air pressure you are running
    And last.... how wide are the wheels? They need to be within the tire manufacturers guidelines
  4. Sep 22, 2017 at 7:00 PM
    #44
    BraskaTaco
    BraskaTaco [OP] Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Sorry, I didn't update the thread since last weekend's update before heading to Discount. They got them straight. The two shops before just stunk. They said they balanced out and are within spec. Shake seems to be mostly gone.. still some slight occasional vibes on certain surfaces or grades, but I'll chalk that up to the E rating. Lesson learned, drive out of the way to go straight to a Discount Tire next time!
  5. Sep 22, 2017 at 7:02 PM
    #45
    Rthompson02
    NW Florida
    good to go!
  6. Sep 22, 2017 at 7:08 PM
    #46
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    I appreciate the help :hattip:
  7. Sep 25, 2017 at 1:19 PM
    #47
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I know 3 out of 4 of my tires needed a good about of weight. I'll have to see how much when I get home.
  8. Sep 25, 2017 at 7:33 PM
    #48
    Devin06taco
    Devin
    Anything more than maybe 8oz at the very most is a tire or wheel problem. Or who ever is balancing isn't doing it correctly. A road force can determine if its the tire or not. Then you can eliminate other options
  9. Sep 25, 2017 at 8:56 PM
    #49
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    i use beads successfully on my beadlocks. They get beat up pretty hard and stay balanced as a dd.
  10. Dec 2, 2017 at 1:57 PM
    #50
    replica9000
    2019 T4R ORP
    Been meaning to post this for a while now. One of my Method wheels must not of balanced well
  11. Dec 2, 2017 at 2:09 PM
    #51
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    That’s ridiculous, that much weight changed the GVW of the truck! ....just kidding.
    replica9000[QUOTED] likes this.
  12. Jan 6, 2018 at 1:38 PM
    #52
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Damn, I had my front wheels off for the cab chop and now the shake is back. It got progressively worse today, which makes me think it might be my lugs as someone pointed out before.
    These are what I’m running: https://www.summitracing.com/parts/gor-21138etbc
    I’m pulled over as I post this because the shake was so bad I wanted to check to make sure my lugs were still tightened :eek:
  13. Jan 6, 2018 at 5:34 PM
    #53
    Creese92
    Creese92 Member
    Mechanicsburg PA
    2006 White Tacoma TRD
    How were the lugs tightened? I’m running Methog 310’s with the same style lugs. I had the same problem after installing them with 265’s. Put them back on the balancer and the roads forced and balanced good. Found that if you tighten one lug at a time it will not be centered. Run the lugs in a little at a time and it will center the wheel. You can't run a hub centric ring on these wheels as there is not enough room but is not centered on the hub.
  14. Jan 6, 2018 at 6:36 PM
    #54
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Thank you, that's good to know. A shop did the chop so they likely torqued them down all the way individually. I'll take them off tomorrow and tighten a bit at a time and see where it gets me..
  15. Jan 6, 2018 at 6:45 PM
    #55
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
  16. Jan 6, 2018 at 7:26 PM
    #56
    Creese92
    Creese92 Member
    Mechanicsburg PA
  17. Jan 6, 2018 at 9:39 PM
    #57
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    I've had perfectly balanced wheels feel unbalanced many times due to how they were bolted onto the truck. If I torque them using a star pattern to 30, then 60, then final torque, they are fine. If I let a tire monkey (I used to be one) with an impact gun mount them, the truck drives like a shopping cart with a fucked up wheel.
  18. Jan 6, 2018 at 10:49 PM
    #58
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    This is definitely my problem!
    Pigpen[QUOTED] likes this.
  19. Jan 7, 2018 at 7:56 AM
    #59
    Pigpen
    Northwest Montana
    I really think this is the issue with most "unbalanced wheel" issues on Tacomas.
  20. Jan 7, 2018 at 9:18 AM
    #60
    jca
    jca Well-Known Member
    Wanna add to this...as a former tech, after a proper balancing, I've always had good results when torquing each lug to around 30 lb ft, then lowering the lift enough where the tires are just touching the ground, then torquing to spec. The techs who just blast the lugs on with the impact usually were the ones who had customers coming back for vibration issues. Even with a torque stick on a gun, the trigger can't be pulled too long, or one runs the risk of messing things up.
