CB keeps blowing fuses. HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CayucosTacoma, Jun 18, 2012.
  1. Jun 18, 2012 at 12:56 PM
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Dont know where to put this because there is no eletrical section
    So i picked up a uniden CB(same internals as a cobra 29) and I did this.
    http://www.tacomaworld.com/forum/audio-video/49635-cb-radio-cobra-29-mod-mount-center-console.html
    the cb i bought came with a cigarette lighter and i plugged into it after i finished and it worked. I then tried to hard wire it to the battery and i ,fixed up the positive and negative leads the first time and blew the fuse. I then replaced the fuse and double checked the leads and still kept blowing fuses. 5 fuses later and still blowing fuses. No shorts(triple checked that) and no clue what is wrong.
    Anyone help?
  2. Jun 18, 2012 at 1:02 PM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    If you are blowing a fuse, you have a short. Time to bust out the multimeter and track it down.
    What size fuse are you using ? And how did you wire it to the battery ?
  3. Jun 18, 2012 at 1:06 PM
    CayucosTacoma
    2004 Double Cab 4x4
    I thought so too so i pulled all the wire from the grommet in the fire wall and checked all the wiring for signs of scrapes holes etc, then went straight to the battery over my hood. Maybe inside the CB somewhere?
    and the fuse with the CB didnt say how big it was so i started with 15 then 20. Just two crimp connections straight to the battery. One on positive one on negative.
    And i guess if this helps the fuse blows immediately
  4. Jun 18, 2012 at 1:11 PM
    CayucosTacoma
    2004 Double Cab 4x4
    I think i am going to try and reconnect from the ciggarette lighter and then if that works ill move onto a fuse in the cab. I just need to find one that is always hot
  5. Jun 18, 2012 at 1:14 PM
    CayucosTacoma
    2004 Double Cab 4x4
  6. Jun 18, 2012 at 1:18 PM
    CayucosTacoma
    2004 Double Cab 4x4
    anyone else before i run to autozone?
  7. Jun 18, 2012 at 1:32 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    An easy mistake is getting the two wires + - crossed. This will connect the wire from the positive battery directly to ground.
  8. Jun 18, 2012 at 1:38 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
  9. Jun 18, 2012 at 2:38 PM
    CayucosTacoma
    2004 Double Cab 4x4
  10. Jun 18, 2012 at 5:32 PM
    JKD
    JKD Well-Known Member
    15 and 20 amp fuses are way oversized for a CB.
  11. Jun 18, 2012 at 5:42 PM
    Monkeyboy
    Grand Junction, CO
    2012 AC TRD Sport
    On the plus side, if he uses a large enough fuse, he will find the short where the smoke is.
  12. Jun 18, 2012 at 6:19 PM
    CayucosTacoma
    2004 Double Cab 4x4
    yeah realized that went to 4 amps.
    UPDATE: so i went back and just hooked it to the original ciggarete lighter and now that is blowing fuses too
  13. Jun 18, 2012 at 6:55 PM
    Monkeyboy
    Grand Junction, CO
    2012 AC TRD Sport
    I bet you accidentally reversed the wires earlier and blew the zener (polarity reversal) diode.
    If you know how to use a multimeter you can open the case yourself and see. Otherwise, you gotta take it to a CB shop.
  14. Jun 18, 2012 at 7:03 PM
    CayucosTacoma
    2004 Double Cab 4x4
    yeah i just looked and the diodes were split in half :mad:
    so anyone know where i can buy these? radio shack?
  15. Jun 18, 2012 at 7:20 PM
    CayucosTacoma
    2004 Double Cab 4x4
  16. Jun 21, 2012 at 1:57 PM
    CayucosTacoma
    2004 Double Cab 4x4
    hell yeah! so after messing with it i finally got it to work. was the polarity diode. This is why i love this website so much help!
  17. Jun 22, 2012 at 1:02 AM
    CayucosTacoma
    2004 Double Cab 4x4
  18. Jun 22, 2012 at 7:08 AM
    Monkeyboy
    Grand Junction, CO
    2012 AC TRD Sport
  19. Jun 22, 2012 at 10:11 AM
    CayucosTacoma
    2004 Double Cab 4x4
    ill recheck my ground. And yes it works
  20. Jun 22, 2012 at 5:44 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Did you try a new mic yet? My money is on the mic. Cobras need a working mic plugged in to operate. Also make sure the mic is wired for a Cobra. Just the fact that it's a 4 pin doesn't mean it's wired for a Cobra.
