CD Player ERROR 3!
Discussion in 'Audio & Video' started by jltldz, Oct 8, 2007.
  1. Oct 8, 2007 at 4:34 PM
    jltldz
    jltldz [OP] New Member
    Siver 4x4
    Just slightly larger tire. Nokian Vativa 26570R17. Awsome tire far better than the stock ones.
    My CD player just quit working it flashes ERROR 3. The book says take out the CDs and put them back in. It still didn't fix it. Anyone else have this problem? If so what did it take to fix it?
  2. Oct 9, 2007 at 3:53 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Usually this means that the CD is unreadable. Have you tried another CD?
  3. Oct 9, 2007 at 1:44 PM
    jltldz
    Siver 4x4
    Yes, it won't play any of my CDs
  4. Oct 9, 2007 at 1:58 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    If it covered under warranty, I'd bring it in.
    If not, I would try to unplug the battery for a few minutes and let the radio reset itself. If that doesn't work, try to use a cleaning disk to clean off the laser eye.
  5. Oct 9, 2007 at 3:12 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    Yep, that is the route I would go.
  6. Apr 17, 2015 at 6:16 AM
    Mercer86
    Mercer86 New Member
    Monroe Wa
    09 Toyota Tacoma TRD
    Has anyone figured this out yet? My cd player started this today and wont let me eject any of my cd's and it will flash Error 3 then shut off. :mad::mad:
  7. Apr 17, 2015 at 6:28 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    I found this on another site. Not sure if the codes are the same for Scion and Toyota. These were codes listed for a Scion.
    ERROR CODE DESCRIPTIONS:
    Error 1: Dirty Disc/Cannot Read Disc (Clean CD as needed and try again.)
    Error 3: Mechanical Malfunction (Replace CD Player.)
    Error 4: CD Player Overcurrent (Allow CD player to cool and try again.)
    I'll keep my eye open though. Great choice for a gif! :thumbsup:
  8. Apr 17, 2015 at 6:37 AM
    Toyotacrawler
    Cusseta/Opelika AL
    I just found this....
    "Error 3 means that there's a mechanical problem with the cd loading system. Now what you have tried is the only method to repair however I would suggest you disconnect the battery's negative battery terminal overnight and connect it back in the morning, see if this causes the cd changer to eject all discs. If it doesn't then the problem is not a glitch and it's an actual problem and the only remedy to this problem is to replace the unit since it's an internal failure. If you know a really good radio repair shop then they can fix it, your other option would be to contact your local toyota dealership and they will take your old unit and give you a remanufactured unit at a much lower cost than a brand new unit, If you have CDs inside the unit that you hand in, they will be returned to you once the unit goes to the remanufacturing facility, they will mail the cds to the dealership and the dealership will contact you."
  9. Apr 17, 2015 at 8:33 AM
    Mercer86
    Mercer86 New Member
    Monroe Wa
    Thank you, I'll try that out tonight.
  10. Dec 22, 2017 at 1:57 PM
    jetron
    jetron Member
    Ron
    2010 Tacoma I4
    As posted here https://www.tacomaworld.com/threads/2010-tacoma-cd-player-wont-load.525113/#post-16728860 my 2010 Taco CD player showed a flashing LOAD whenever I would insert a CD, and eventually gave an Error 1 message. Obviously not all my discs are dirty (kept in a clean CD wallet), and I even tried a CD head cleaner with no change in the results. One fellow posted a suggested replacement with a Blaupunkt unit, which I opted for, as OEM replacements from Toyota run about $1000, and many used units were around $200. The Blaupunkt unit had more features, was cheaper, and so made more sense.
    Toyotacrawler[QUOTED] likes this.
