Changing a tire out on the trail
Discussion in 'Off-Roading & Trails' started by DocD, Dec 11, 2020.
  1. Dec 11, 2020 at 11:25 AM
    DocD
    DocD [OP] Well-Known Member
    Mn./SoCal
    09 access cab
    I am a fairly recent resident of SoCal, (I'm in my mid 70's) My truck is a 2009 Toyota Tacoma Access cab 4x4, I have discovered that I really enjoy the desert and although I am not a true Off-Roader I do enjoy exploring all the Roads, Trails, paths, the desert has to offer, The other day while on one of these "Trails" It dawned on me as to what I would do if I had a flat tire!! keep in mind my truck is always with good Tires & maintenance is always up to date, However "Crap" happens. So my question to you off roaders is What is a favored "jack" for someone in my position, I am thinking bottle jack, my concern with that is the lift height, & the anchor points. Thanks to any and all advise!!
  2. Dec 11, 2020 at 11:26 AM
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    I just wanna say good on you for still getting out in your mid 70s
    C41n, tacotoe, rob1208 and 12 others like this.
  3. Dec 11, 2020 at 11:31 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would get a small compressor that hooks to the battery and a plug patch kit, a few pieces of wood to put under the jack if your in the dirt for stability. A 25” breaker bar and socket for the lugs is also a good idea.
  4. Dec 11, 2020 at 11:32 AM
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    Welcome to California! There are some great trails and roads around that offer some beautiful scenery. If you're not already using it, give the All Trails app / website a try, dip your toes in some of what it has to offer.
    As for jacks, there have been a few threads on this, and I think post #2 here sums it up pretty well: https://www.tacomaworld.com/threads/best-off-road-jack.604080/
    C41n, T-yoda, tacotoe and 1 other person like this.
  5. Dec 11, 2020 at 11:36 AM
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
    tacotoe, DocD[OP] and mud like this.
  6. Dec 11, 2020 at 11:57 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    A large floor jack would probably be your best bet. They are the most stable option and probably the best for someone your age (also, total props for still getting out there at it).
    A 12v compressor, tire plugs, and a cordless impact wrench would also be great tools to have with you.
    A set of traction boards (https://www.amazon.com/Escaper-Traction-Off-Road-Extraction-20333/dp/B00AV2HONS) would also be worth considering since you are in soft sand a lot and digging out at age 70 isn't the most desirable activity in the world.
    DocD[OP], tacotoe and mud like this.
  7. Dec 11, 2020 at 12:02 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've kept a small compressor and a set of plugs/tools to plug my own tires for years. I have a kit in every vehicle in the driveway, even the ATV. In the last 20+ years I've plugged at least 20 tires without even taking them off the vehicle. Not all on my vehicles, I've saved others stranded on the side of a road or trail several times.
    In that time I've only had to resort to using my spare one time. I had a hole too big to plug and the tire couldn't be saved. There have been 2 other other times where the tire couldn't be saved, but the plug held long enough for me to get home and to a tire store. It is a lot faster, easier, and safer to just plug it yourself with the tire on the truck than resort to using the spare.
    But if all else fails I do have a bottle jack and a 4 way lug wrench in all my vehicles.
    And since going to E rated tires I've not had a single punctured tire. At least for now, I know it can still happen, but the heavier duty tires do reduce the risk.
    tacotoe likes this.
  8. Dec 11, 2020 at 12:06 PM
    DocD
    Mn./SoCal
    09 access cab
    Thanks for all the great advise!! That ProEagle is quite a Jack!! I don't think I will be going that route (although it would be nice) I do have an old sears 2 1/2 ton, but it is so darn heavy, I am going to go down to Harbor Freight and take a look as to what they have, I am going to take a close look at a scissors jack, If all else fails i will put that sears jack and a plywood pad, Thanks again, Mynameismudflap= Yes i do have the All-rails app, & have used it a lot, Hiking is another fav hobby of mine.
    tacotoe and spitdog like this.
  9. Dec 11, 2020 at 12:07 PM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    While I do have the luxury of steel bumpers and sliders to allow me to use a hi-lift jack if I am in a situation where it is hard to get under the truck, I do carry a bottle jack, a 4x4, and a couple of 2x4's, to use depending on the terrain. I don't trust the hi-lift for a tire change unless there isn't an alternative. If you have a plug kit and an air pump, that would probably be the easiest way to go.
  10. Dec 11, 2020 at 12:08 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    You can also look around at junkyards for one of the older Chevy scissor jacks. Pretty sturdy for a scissor as the have a large base and are made for 1/2 T trucks.
    The bottle jack is terrible for any vehicle off-road, even dirt road as it's hard to find a llevel surface anywhere near where you're at.
    tacotoe, Durango95 and DocD[OP] like this.
  11. Dec 11, 2020 at 12:09 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    In addition; get familiar with the jack and attachments that are stored underneath the rear passenger seat. Break all that stuff out and you could even lower that spare down in the comfort of your driveway. I keep a small floor jack and a 4 way lug nut tool, and short 4x4 block handy.
    Gunshot-6A and DocD[OP] like this.
  12. Dec 11, 2020 at 12:11 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    Tire plugs are nice !! And having a matching spare!
    tacotoe and DocD[OP] like this.
  13. Dec 11, 2020 at 12:20 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    The factory screw-style bottle jacks are looked down upon around here, but it has worked well enough for me the one or two times Ive needed to use it. No extra weight or storage considerations as it is already built into the truck. Plus you need to get that kit out anyway in the event of a flat to lower the spare.
    One consideration to make with that is its small base. I always pack two 2x10x16 boards and a few 4x4s as well. 2x10s serve as the wide stable base, and one layer of 4x4s can be added for extra height if needed. Even with a full flat you can still crawl along, so if the terrain is uneven enough to make the above seem unreasonable, then move ahead slowly until its flatter.
    Also, make sure you have wheel lock keys for your lug nuts (if equipt) AND make sure the spare tire hoist mechanism is in working order and not rusted. Both of those are bad things to discover missing / broken when you need them.
  14. Dec 12, 2020 at 7:23 AM
    DocD
    Mn./SoCal
    09 access cab
    Again. Thanks for all the Good advise!!, When I venture in the desert I always try and follow a somewhat decent path/trail/road so a lot of this advise is very welcome!!, & really got me thinking, I have sold most of my bikes, but still have a lot of "Stuff" so i went digging, & found some useful things, Tire patch, small air compressor, etc: I am not using the truck for anything but transportation so , I am going to load, that floor jack and a piece of plywood, and put together a kit, My Spare (Thanks BalutTaco) is not the same size, although i think good enough to get me home. I am however going to look at a good scissor jack. Again Thanks to all for taking the time to post!!![​IMG]
  15. Dec 12, 2020 at 7:38 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    I hope when I'm mid 70s I can still pick up my floor jack that's identical to that one. Haha, they make smaller ones that come in a handy hard plastic case, think I have 3.
    mud and DocD[OP] like this.
  16. Jan 12, 2021 at 12:41 PM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    The OEM bottle jack is fine. I made a large foot by glueing 4 sheets of 3/4" plywood, about 9"x14". Raises the back and provides a larger platform so it doesnt sink in sand or mud
    tacotoe likes this.
  17. Jan 12, 2021 at 2:11 PM
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    One suggestion I will make, having spent much of my early life running around and hunting all over the Mojave with my dad, and then in later years hunting big game in several western states: If possible, get a 2nd spare for your truck and carry it whenever you go off roading. And the other suggestions above are good as well. But if you have just the one spare, and it gets punctured, then you either have to leave and head back to civilization to get that one fixed, or run the risk of getting another flat out in the sticks, which would be Game Over.
    tacotoe and Vmax88 like this.
  18. Jan 12, 2021 at 11:42 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    The old scissor jack can get sand in the threads and become hard/impossible to turn.
    Bottle jacks are better in that respect but require a high minimum clearance. A floor jack is a pain to move on soft soil. Hi Lifts get tippy and need either steel bumpers or accessories.
    So what do I have in my Jeep (I’ve been running the socal deserts for 4 decades)?
    A bottle jack, a small floor jack and a hi lift. Why? Because you never know which will work best in the current circumstances.
    I’m just a couple of years behind the OP. I ran alone up until last year. Pressure from my kids finally got me to take someone else along. Admitting you’re getting older and not as strong as you once were sucks. But it happens.
  19. Jan 13, 2021 at 12:45 AM
    Vmax88
    Vmax88 Well-Known Member
    Clint
    Joshua, TX
    20 MGM DCSB TRD Off Road 4X4
    I agree with the 2nd spare, I go to the Padre Island National Seashore & running in the deep sand you run over all kinds of stuff you don't know is there.
    I carry a compressor & plug kit which almost always gets me by but if not I have a small aluminum floor jack, oe jack, Hylift with wheel adapter & wood blocks. More then once plugged a sidewall puncture to get off the beach & change the tire at the hotel.
    tacotoe likes this.
  20. Jan 14, 2021 at 11:33 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    All systems have advantages and disadvantages.
    First, carry some tire plugs and a compressor. Often times that's all you need.
    There are 5 main options, as I see it.
    ALL of them it's best to be on flat ground, but some work better than others when it's not flat, but suffice to say, you should do what is possible to move to flat ground to change a tire or do any other work no matter what jack you have.
    Your stock bottle jack will more than likely work just fine in many situations, as long as you're on flat ground and have stock sized tires. I would suggest some type of plate that fits under the jack to help support it on uneven ground and to help keep the jack from toppling over. There are commercial ones, or you can just use a couple pieces of wood or a steel plate, too.
    The next step is a hydraulic bottle jack. It's effectively the same as the stock jack, just "better". Basically the same thing applies as it does with the stock jack. They're compact, lightweight, and easy to move around. If you don't have large tires, they generally work very well. Again, you may want to have a plate or some type of support for uneven ground.
    Then there are floor jacks. These are going to be bigger and more cumbersome, but are more steady on relatively uneven ground. The problem here is storage and lifting them. I'm only 41, and that's not an exciting premise to me, lol.
    Next are airbags. These are bags that you usually use the exhaust to inflate (or maybe an air compressor). You stick the bag under the frame or suspension, and it lifts up the truck. These can be fairly expensive and cumbersome, but I don't have any personal experience with them.
    Lastly are the hi-lift jacks (farm jack). These are pretty universal and can do a lot more than just jack up a tire. They can even be used as a winch to get you out of a jam. The problem is they can be non-intuitive to use, and are highly dangerous is misused (that said, so are any of the other tools mentioned).
    Here's what I suggest:
    >First, get a tire plug kit and an air compressor. The cheap (anything under $30-$40 I consider "cheap" not just "inexpensive) compressors are "fine", but something like a Viair 88P is a really good investment, and at $~70 it's still not what I'd consider "expensive" anyway.
    >Head out on one of your adventures, and stop midway through for a mock tire change. Assuming you're relatively familiar with the process normally, try it on a dirt road somewhere that's fairly representative of the trails you like to travel. Create a situation where you're going to "need" to change a tire, but you are under no real pressure to actually do so. Obviously, be safe, and have a friend with you is always a good idea.
    >Take what you learn from this and see what of the options listed above (I'm sure there are others I've neglected to mention), and see what you'd think will work best for you.
    tacotoe likes this.
