Changing Diff Fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by randyg123, Jun 28, 2010.
  1. Jun 28, 2010 at 5:36 PM
    randyg123
    randyg123 [OP] Well-Known Member
    Randy
    2024 Bronze LTD
    Sorry I lost the links to the instructions on changing out the differential fluids. Can someone please post links to the instructions for fluid changes?
    Are there special instructions/additives for 4x4 with the locking differentials? I picked up a tube of MOC Extreme-Pressure Lubricant from Toyota Part# 01141. But the guy at the parts counter didn't seem to know what he was doing (first he told me I didn't need to change the fluids at 30k, then he didn't think I needed any additive). What is the proper amount of this to add when changing out the fluids? I was going to do this last weekend but figured what can be more patriotic than working on your pick-up on the 4th Holiday weekend ;-D
  2. Jun 28, 2010 at 5:45 PM
    The_Dude
    The_Dude Well-Known Member
  3. Jun 28, 2010 at 7:30 PM
    randyg123
    Randy
    2024 Bronze LTD
  4. Jun 29, 2010 at 6:42 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  5. Jun 29, 2010 at 6:46 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    Make sure you can get the fill plug loose first!
    Some people drain the fluid and then can't get the fill plug open.
    Leaving them with an empty cavity needing fluid and a hassle to get it refilled.
  6. Jun 29, 2010 at 4:31 PM
    randyg123
    Randy
    2024 Bronze LTD
    So do I use the additive with a locking rear end or not? I am still confused on which type of oil and if the additive is used and is it consistent for all three?
    Quoting screeber's post
    "(I used Redline 75w-90ns for my TRD Off Road with Locker) for both diffs and the transfer case..."
    "TRD Sport models and trucks with the mechanical LSD should use Redline 75w-90 (not the ns), as this contains the friction modifiers necessary for the LSD. If you are using a different fluid brand, just make sure it is formulated for LSD rear ends"
    I am not sure from those two descriptions, which one I have. I assume the top one since he states, "with the Locker" but then later one when he says, "Trucks with mechanical LSD.." I loose confidence in my decision.
    Thanks in advance for the assist.
  7. Jun 29, 2010 at 4:35 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  8. Jun 30, 2010 at 6:42 AM
    05Moose
    Jim
    You've got a TRD Off Road...thus no mechanical LSD (you have a locker instead). No need for friction modifier.
  9. Jun 30, 2010 at 7:05 AM
    randyg123
    Randy
    2024 Bronze LTD
    Thanks 05Moose. That clears it up. Then that means I do not even have to change my diff fluid right now (according to the Maint Schedule). That makes the project even easier:D I can take all the money saved and invest in some Sam Adams (strictly for patriotic reasons on this holiday weekend, of course).
