Charleston, SC
Discussion in 'South East' started by dan0mite, Jun 8, 2018.
  1. Oct 11, 2022 at 11:26 AM
    #401
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    OCD 08 likes this.
  2. Oct 5, 2024 at 12:50 PM
    #402
    James2406
    James2406 Well-Known Member
    James
    South Carolina
    2021 TRD OR Premium
    Lots
    Anyone got a ECGS Needle Bearing removal and install tool I can borrow?
  3. Oct 5, 2024 at 3:15 PM
    #403
    frankybones
    frankybones Well-Known Member
    Frank
    Summerville SC
    2017 TRD PRO - CEMENT
    If you want to install one for me on my truck as well I'll buy you the tool and bearing if you don't have it already, I'll supply beers as well.
    I'm not mechanically inclined or patient enough to try it myself.
    I live in Summerville weekdays and West Ashley on the weekends.
  4. Oct 5, 2024 at 3:29 PM
    #404
    James2406
    James
    South Carolina
    2021 TRD OR Premium
    Lots
    I'm actually an Aircraft Mechanic, and run a mobile mechanic business on the side.
    I'm definitely down like four flat tires buddy, order the install, seal, and the removal tool and we'll do them both at the same time
    The_Hodge likes this.
  5. Oct 6, 2024 at 8:15 AM
    #405
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    Well, That worked out perfectly! I love seeing people helping people. Good on y'all!
    The_Hodge and James2406 like this.
  6. Oct 7, 2024 at 8:12 AM
    #406
    frankybones
    Frank
    Summerville SC
    Not sure why I didn't get the notification on this but I'll order today and let you know eta on delivery. I just saw the pm so I'll reach out there. Many thanks!
  7. Oct 14, 2024 at 5:55 PM
    #407
    James2406
    James
    South Carolina
    2021 TRD OR Premium
    Lots
    Update for anyone wondering,
    My old axle seal was falling apart when it was removed, so definitely my issue resolved. No leaks. ECGS removal tool was a little ticky to use, had to really make sure I was square on the needle bearing for removal, and the tool itself was just like 0.0500 too large to fit, a punch and a few baby taps from a ball peen and it was behind the the needle bearing.
    Removal was the same, once I felt I was square on the back side of the needle bearing I just had to commit and it came right out. Installation was the reverse process with the ECGS installation tool, got it about 1/8in protrusion as confirmed by ECGS, and called it good. Loud and not necessary pretty in process but it never is.
    Overall easy enough job once you've done it.
    Found a video online, and only three bolts were required to do the whole job (besides the wheel and lug nuts ofc)
    Sway bar linkage to the knuckle.
    bottom ball joint to LCA.
    Seems a bit smoother now, and most importantly I'm not leaking gear oil anymore.
    OCD 08, ahspurlock and jpneely like this.
  8. Oct 15, 2024 at 3:10 AM
    #408
    ahspurlock
    Adam
    I'm glad everything worked out and you were able to get it done. Also not many around this thread so I'm going to post a link to our main thread which is everybody's on that one
    https://www.tacomaworld.com/threads...nd-lives-in-sc.411211/page-8355#post-30196237
    OCD 08 likes this.
  9. Oct 20, 2024 at 1:45 PM
    #409
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    This weather has me wanting to get out to the FMF again soon for a day. Anyone been recently out there? How's the water look on everything but Hellhole Rd (since it is always a mess)
  10. Oct 21, 2024 at 11:48 AM
    #410
    James2406
    James
    South Carolina
    2021 TRD OR Premium
    Lots
    If anyone needs a ECGS bushing installed or any other work in the area give me a holler!
    jayandersen5 likes this.
  11. Nov 26, 2024 at 9:19 AM
    #411
    James2406
    James
    South Carolina
    2021 TRD OR Premium
    Lots
    I have to swap out my rack and pinion, and install my 5100's this weekend. Does anyone have a hard concrete surface I can use? My driveway is crush n run and I'm skeptical about usually it for such an in-depth job.
    Thanks!
  12. Nov 26, 2024 at 11:34 AM
    #412
    jpneely
    Charleston, SC
    What part of Charleston are you in?
    also post up in here for some more Chs people. https://www.tacomaworld.com/threads...nd-lives-in-sc.411211/page-8366#post-30283602
  13. Nov 26, 2024 at 1:49 PM
    #413
    James2406
    James
    South Carolina
    2021 TRD OR Premium
    Lots
