Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Dec 14, 2016 at 6:42 AM
    #2021
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    good to hear it worked out for you! Kinda nice to hear that 8 years later it still helped someone lol.
    sparker likes this.
  2. Dec 17, 2016 at 7:57 PM
    #2022
    AANorthwest
    AANorthwest Well-Known Member
    Washington
    2012 DCLB 4x4 TRD sport
    Need to safe this so I can refer back to it. Thanks!!
    ecotecin likes this.
  3. Dec 25, 2016 at 8:22 PM
    #2023
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  4. Dec 30, 2016 at 6:19 PM
    #2024
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    is this just for off road? Or Sports to?
  5. Dec 30, 2016 at 8:20 PM
    #2025
    LP808
    LP808 Well-Known Member
    2016 Base SR5 Tacoma
    None
    Hi guys. I'm new here but have been following this page for a while. I recently picked up a 2016 Base SR5 Tacoma(QC/short bed) and is wondering if any of you can recommend a descent 3-4" leveling kit that will last but won't break the bank. I'll be using it as a daily driver with some weekend off roading. Any leads will help. Thanks in advance.
    Nessmuk likes this.
  6. Dec 31, 2016 at 7:53 AM
    #2026
    lpfe42
    lpfe42 Well-Known Member
    Kenny
    Santa Barbara County
    20 DCSB CEMENT
    5100/887 Icon uca
    6112's
    LP808 likes this.
  7. Jan 2, 2017 at 4:43 PM
    #2027
    COJoe
    COJoe Active Member
    Joey
    Belgrade, MT
    Mods, the Factory Service Manual link at the end of the OP no longer contains downloadable manuals. They received a take-down notice for the content. Just letting you know in case you wanted to remove the link to that site.
    LP808 likes this.
  8. Jan 4, 2017 at 5:07 AM
    #2028
    Camel51
    Camel51 Well-Known Member
    Colorado
    2006 DCSB TRD-Offroad
    OME BP51's, Brute Force Fab
    I'm starting to learn a lot more about electrical now. Does splicing into the green wire mean attaching another wire in the middle of the green wire and run it to the fog relay? Or does it mean cut the green wire, attach the cut end to the new wire, and run the green/wire extension from the plug to the fog relay?
  9. Jan 4, 2017 at 7:48 AM
    #2029
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    If your are splicing another wire to it, then you just use th quick splice and attach a wire to it, so essentially you would just be connecting a wire to it, just to get the voltage from that wire to the new wire.
    Does this help?
  10. Jan 4, 2017 at 2:14 PM
    #2030
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Splice means connect them together. Cut means cut and use one end.
    Dakotataco77 and Camel51[QUOTED] like this.
  11. Jan 4, 2017 at 3:14 PM
    #2031
    Camel51
    Colorado
    Ah I see. Do you need the quick splice thing? Can I wrap another wire around the existing wire and solder it?
    ecotecin[QUOTED] likes this.
  12. Jan 4, 2017 at 3:52 PM
    #2032
    piercedtiger
    Jon
    Southern Tier, NY
    Solder and shrink tube would be best. Especially the marine grade shrink tube with adhesive inside. That would help prevent corrosion if you deal with snow and road salt. Those quick splices are quick n easy, but they leave copper exposed to the elements.
  13. Jan 4, 2017 at 8:24 PM
    #2033
    ecotecin
    WV
    You dont need it, but it makes things simpler, and i can be removed later on if needed, with minimal damage to original wire.
    Camel51[QUOTED] likes this.
  14. Jan 18, 2017 at 12:21 AM
    #2034
    lincoln26
    lincoln26 New Member
    2017 gray tacoma trd sport
    will this fit the Gen 3 console?
  15. Jan 18, 2017 at 2:26 AM
    #2035
    DrFunker
    DrFunker Well-Known Member
    Hmmm...didn't know there was such a thing. Will have to look for this.
  16. Jan 18, 2017 at 7:04 AM
    #2036
    piercedtiger
    Jon
    Southern Tier, NY
    I didn't either until I went to use some I'd just grabbed from a store. I noticed something bubbling out from the end when I heated it. At first I thought I'd melted the insulation, but then I read the packaging later.
    • Heat activated adhesive lining provides impermeable seal to salt water and other liquid.
    Stuff like this: https://www.amazon.com/dp/B01LMRE1H2?psc=1
    mrlee and DrFunker[QUOTED] like this.
  17. Jan 18, 2017 at 10:11 AM
    #2037
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    I inadvertently picked some of this up at Harbor Freight the other day, and have to say I like it better than regular because of the adhesive that comes out.
    DrFunker likes this.
  18. Jan 18, 2017 at 10:35 AM
    #2038
    piercedtiger
    Jon
    Southern Tier, NY
    I suspect I did the same thing! lol After using it I have to wonder why you would ever use the other kind. haha
    Sandman614 likes this.
  19. Feb 3, 2017 at 9:56 PM
    #2039
    CG87_
    CG87_ Well-Known Member
    2015 BR DCSB PreRunner SR5 V6
    In Progress...
    sub'd
  20. Feb 7, 2017 at 3:32 PM
    #2040
    Ak4T777
    Ak4T777 Well-Known Member
    Kevin
    2003 Tacoma crew cab
    OME lift 3" lift 1.5" lift shackles Aftermarket bumpers 1" body lift
    Ok..ok. Maybe people can benifit from this idea. So I've been looking online at sunglass vehicle holders. For instance like visor clip style ones. Most I found had bad reviews on Amazon. Then I searched camo sunglass cases. Cool but I passed on those as well. Then I started thinking.... What do I have around the house that won't cost any money? BAM!! It hit me!
    I immediately went to my B.O.B. gear. Pulled it off one of my packs and presto! Works like a charm and no additional cost spent! ---Freebie from my Pops :D
    They are Condor molle mod 6 straps ((6" ones)) and work great. Goes with the theme of the truck perfectly! They come in blk, tan, od and grey I believe. Can get a 4pk for like $5! The glasses pushed to the front fit nice and snug. (See pic)
    And yes, I DO NOT buy expensive sunglasses. Lol $5 dollar Home Depot gems. (I wk there) Would rather spend my money on guns, ammo, lots of ammo :D and truck stuff haha. I'm sure paracord would wk as well. (Got A LOOOOT of that stuff laying around lol) Just make it tight and melt ends.20170207_160839.jpg 20170207_161020.jpg (((edit Just thought of this. Maybe I'll make a paracord "bracelet" big enough to fit the visor. Boom doubles as a sunglass holder and have some backup cord in survival situation)))
    DrFunker, stbear and mrlee like this.
