Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Oct 21, 2014 at 3:14 PM
    #1721
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    There is one thing that the Gods gave to us and it's called SEARCH BOX lololol
  2. Oct 24, 2014 at 8:25 AM
    #1722
    Flippo
    Flippo Member
    North
    Double Cab 4X4
    Oem tube steps, Access Tonneau cover, Bed Rug Pop n Lock Gentex Mirror with outside temp, compas and Homelink
    Yes sir. Thomas Jefferson wa a great man
  3. Oct 25, 2014 at 8:34 AM
    #1723
    15Taco
    15Taco Well-Known Member
    Shawn
    Harrisburg, PA
    22 Tacoma DC offroad
    URD short throw shifter, Anytime fog light mod, Kenwood head unit with dashcam and Aftermarket speakers with JL Audio amp and 2 10" subs, Aftermarket grill, Yokohama AT, Seat covers in the front, OME remote reservoir shocks, ARB rear springs, JBA upper control arms, Rigid ditch light.
    Has anyone tried the anytime locker mod on a 14 or 15 yet, I'm debating on trying it on my15. Any suggestions would be helpful
  4. Nov 19, 2014 at 11:22 AM
    #1724
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    I just performed this mod on my '11 and it mostly worked. The problem is that the outer (small) bulb is not working on the side that I did the mod on. Other side was working, but when I switched that bulb over to test it seems to have blown that bulb as well. No shorts or grounds that I can tell and fuse is not blown. Anyone have an idea on what could have caused this?
  5. Nov 19, 2014 at 12:15 PM
    #1725
    doughboy
    doughboy Well-Known Member
    norcal
    2010 Tacoma TRD 4x4
    hid head lights, hid fog lights, always on fog lights, bed lights
    using the dim filament will not give you a bright enough light to be visible during the day against direct sunlight (which is the whole point of DRL). A better option for DRL is the fog light anytime mod and use the foglights as DRL.
  6. Nov 25, 2014 at 9:10 PM
    #1726
    TT2015
    TT2015 Member
    Port Moody, BC, Canada
    2015 4x4 4cyl manual standard package
    Matching colour Arrow cap
    Thank you for the pics! I just bought 2015 Tacoma and it came with a basic two speed wiper switch!!?? After arguing with my dealership, I finally convinced them to order me a intermittent switch. I think I'm going to do the install myself since they charge big bucks to do the work…
    Thanks again for the very instructional post.
    TT2015
  7. Nov 26, 2014 at 7:19 AM
    #1727
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Just Curious - why would you have to argue ? Can't you just go to the parts counter and say give me one ?
  8. Nov 26, 2014 at 8:05 AM
    #1728
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    They probably were telling him that there is no such thing for a Tacoma that didn't come factory with it. That is what the dealerships seem to believe.
  9. Nov 27, 2014 at 7:29 AM
    #1729
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    Wow, my 2012 Tacoma has the switch that when pushed up it does a quick wipe, first position down, is intermittent with several times, and then normal low and high. Can't imagine they would cheap out and do away with that, even the 2005 I had has that same switch! Happy Thanksgiving everyone!
  10. Nov 27, 2014 at 8:13 AM
    #1730
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    It's those little things that could potentially persuade someone into buying a more expensive model.
  11. Nov 27, 2014 at 11:00 AM
    #1731
    Colassio
    Colassio @Project_SilverTaco
    Cole Moecklin
    Florida
    05 PreRunner SR5 TRD Off-Road
    ProComp 3" lift SCS SR8 17x8.5 Mud Graps 33x12.5 FCK 40" Curved Retrofit headlights 15% tint 2 10" Alpine Bassline Subs with box Kicker door speakers Apps2car Bluetooth OEM Roof Rails Rough Country lightbar brackets ARE Tonneau Cover Backup Camera RGB Rock lights Thrush Glass Pack Dixie horn Body Armor sliders/steps Wet Okole Neoprene Seat covers Carbon Fiber wrap on select parts Color match grille Weather Tech mats Onyx Halos in fogs Sweet decals Led lights inside
    Worked perfectly, easy to install. Thanks you :)
  12. Nov 27, 2014 at 10:56 PM
    #1732
    clupi
    clupi Well-Known Member
    Sacramento Ca
    07 taco 4x4
    Hi guys, im new to TacoWorld and not even sure of how to use it properly yet since I dont spend much time on here but I like getting good advice or help so I thought I'd lile to pass it along. After getting my 285/75/17 (33") tires on my Tacoma with a 2.25" lift I figured id like to fix the little rubbing that I had. I have aftermarket wheels so backspacing isnt as bad as stock. It rubbed verry little while standing still but when driving since the factory suspension is all on rubber mounts or bushings it rubbed a little more. I dont like having a 6" lift like some guys with some little tires but thats just me.
    most important for me when starting is not to do like most by cutting a little at a time! Cut a little to fit 33", than in a year cut a little more for 35"s so i got all the info off different trends and this is what i figured on doing. Most guys cut as much as possible while leaving one of the two bolts that mount the rubber mount to the frame mount, so for me it only made sence to unbolt the rubber mount that looks like a trianglit on and the corner that faces toward the front which gets in the way when you try to cut as much as possible gets in the way. So i unbolted it, rotated it completely oposite of how it was and i drilled new holes in the bottom. After that i cut from the (Back outer)corner of the mount in a strait line maybe a 1/8 inch into the big hole on the bottom to just leave enough room to still service or work in there and not to let the rubber mount and washer rubb the edge and cut a strait line all the way around a piece at a time with a grinder and cut off wheel. Then I traced out on paper the shape of the hole put it on metal and cut it out. I then welded it up and now I have room to spare up to 35"s for sure.
  13. Nov 27, 2014 at 11:06 PM
    #1733
    clupi
    Sacramento Ca
    07 taco 4x4
    The last picture I have the wheel turned only 1/2 way were most of the rubbing was before I cut it and I have about 3" of clearance now. At full lock I have about an inch and a half and I could cut and plate the front of the mount if id want room for bigger that 35"s which would never happen for me :) plus you need to start making room in the edge of the firewall if going with 35"s anyway which will be another interesting project
  14. Dec 8, 2014 at 6:24 PM
    #1734
    gatty
    gatty saltyyota
    andrew
    Texas
    15 4Dr 4x4 black
    Fog light mod, volant cold air intake, uws tool box, 3 inch ready lift, 285 60 r 18 nitto terragrapplers 18x9 Ballistic jester wheels, grille craft front grill insert, strobes n more floodlight, cool white led bed lights, blue seas fuse box, soon SOS Concepts front bumper
    Hey as for the 4x4 switch do you know if there is another place to find it other than trdparts4u. I looked at their website but could not find it.
  15. Dec 17, 2014 at 6:52 PM
    #1735
    snowrx
    snowrx Active Member
    Priest Lake
    '13 Blue Off Road V6 6Spd
    H4 H9 bulbs,Hidden Warn M8000, Bed & hood lights, clock panel voltmeter,
  16. Dec 28, 2014 at 1:32 AM
    #1736
    07 v4 stick shift
    07 v4 stick shift New Member
    Hi I have a 2007 regular cab 4 cylinder 4wd with a manual transmission and I was wondering if an 8 cylinder swap would even be possible if so how would I go about starting such a project and if not what could I do to get a good deal of power out of the truck
  17. Dec 28, 2014 at 3:03 AM
    #1737
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Urd supercharger
  18. Dec 28, 2014 at 4:07 AM
    #1738
    Clearwater Bill
    Billy
    Largo Florida
    Of course it can.
    But it won't be a 'cheap/free mod' thread topic, which is where you posted.
    TacoTacoma97 likes this.
  19. Dec 28, 2014 at 7:13 AM
    #1739
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    LOL, I think he wants a free v8 swap :D
  20. Dec 28, 2014 at 9:35 AM
    #1740
    replica9000
    2019 T4R ORP
    Anything is possible. I can't see it being cheap though.
