Clanking noise from front end normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DiffLock, Sep 25, 2017.
  1. Oct 3, 2017 at 7:00 PM
    4lo
    4lo Well-Known Member
    El Campo, TX
    2017 TRD Sport
    some stuff
    At a thousand miles I re torqued everything I could. I had a similar noise up front, and I think it was the front diff, it was way out if spec. Also pull your skid plate, there is almost no clearance with or without lift. Combination of no clearance on the skid and loose diff bolts maybe.
  2. Oct 3, 2017 at 7:07 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I think the noise you're referring to is when you are in neutral or clutch depressed.if in gear and going over bumps I don't hear the clanking but in neutral coasting over bumps I hear it. It's normal. If you get under and rotate the driveshaft when you grease the zerks it's the same noise.
  3. Oct 3, 2017 at 7:09 PM
    Chrispytaco91
    Chrispytaco91 Well-Known Member
    Christopher
    San Diego,CA
    2016 Tacoma trd offroad 4x4
    I just went through this.... lower shock bushing goes bad.. rubber tears and causes clicking/clunking noise over dips and bumps dealer didn't want to warranty front shocks on my "trd Off-road" because it was offroaded. I had a set of fox coilovers sitting in my garage so it was all good.
    :luvya:FUCK YOU DEALERSHIP:luvya:
    helix66 and GaryLaurenLogan like this.
  4. Oct 4, 2017 at 2:40 PM
    djthicks
    djthicks Well-Known Member
    Orange County
    07 DCLB TRD Sport
    King's all around Long traveled Methods KO2s
    What lower bushings are you referring to?
  5. Oct 4, 2017 at 2:45 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Wtf! They didnt want to warranty a truck literaly built to offroad. Hence the name. Cheap dealers
    helix66 likes this.
  6. Oct 4, 2017 at 6:26 PM
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    My truck has been doing this since I bought it. Its just gotten worse over time.
  7. Oct 5, 2017 at 9:22 AM
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    This noise happens when I pull into my driveway. It's the "honey, I'm home" alert. I didn't find any mention of it in the manual.
    twitchhero and GaryLaurenLogan like this.
  8. Oct 5, 2017 at 12:20 PM
    Chipi3s
    San Diego
    Mine has never done it, coming up to 1000miles soon
  9. Oct 5, 2017 at 4:13 PM
    mhtacoma
    mhtacoma Well-Known Member
    Columbus, Ohio
    2016 DCSB MGM TRD Sport
    Mine does it. If dealer can't repeat it they aren't interested in fixing it. I showed them the video and my own audio clip. Told them it was the shock mount. Since there aren't any road humps near the dealership we couldn't make it do it. Won't even look at the mount if they don't hear it. Worried about who pays for it. Them or Toyota. At that point I told him to forget it. Putting on 5100's soon to make it go away.
  10. Oct 23, 2017 at 11:05 AM
    DiffLock
    DiffLock [OP] Well-Known Member
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Still having this issue. I can tell you what it's not...
    not brakes - happens even with brake pressed
    not shocks - have had bilsteins, toytec and now kings
    not sway bar - torqued
    not skid plate - replaced with TRD pro skid
    not diff - removed diff drop and torqued
    Any other ideas? Its really annoying offroad, like the truck is falling apart.
  11. Oct 23, 2017 at 11:24 AM
    Chipi3s
    San Diego
    Heres a list that may or may not help but worth a shot.
    Plastic engine cover
    Center hub caps (if you have stock tires)
    Sticky weights, they can loosen sometimes
    Check engine bay for loose bolts
    Mud flaps! Make sure they are not loose
    Might sound dumb but if you have double cab make sure the seat belts are not hitting the walls in the back
  12. Oct 23, 2017 at 11:25 AM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Thanks, I've checked off most of these. It is definitely a metal-on-metal sound from the front end. I'll try to get a gopro down there.
  13. Oct 23, 2017 at 12:13 PM
    Cbevington6
    Cbevington6 Well-Known Member
    T4R
  14. Oct 23, 2017 at 12:28 PM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    Did you check your front body mounts?
    https://www.tacomaworld.com/threads...at-noise-may-not-be-your-leaf-springs.464993/
  15. Oct 23, 2017 at 12:32 PM
    #35
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    I will check that. Could it really come from the factory like that?
  16. Oct 23, 2017 at 12:41 PM
    #36
    CombatVeteranOIF
    CombatVeteranOIF Well-Known Member
    Mesa Az
    2010 TRD OR Prerunner DCSB
    My 15 made the same noise. Dealer couldnt replicate it. I just had to deal with it. I was excited when my lease was up I could get into the 3rd gen. My 17 has the exact noise of my 15. :facepalm:
    GaryLaurenLogan likes this.
  17. Oct 23, 2017 at 12:44 PM
    #37
    Camel89
    Houston, TX
    2016 TRD OR 4x4
    Not from the factory, but I've heard they can deteriorate quickly. Some polyurethane bushings will last much longer.
  18. Oct 23, 2017 at 1:06 PM
    #38
    uberschall
    uberschall Member
    2017 TRD Off-Road
    While I don't have a camera to mount under the truck, the video sounds very similar - metallic clank going over small bumps at low speed. Wobbling the stick in neutral makes a similar noise. Has this been happening to both A/T and M/T trucks?
  19. Oct 23, 2017 at 1:08 PM
    #39
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Exactly... sounds like changing gears or wobbling the stick. I have a M/T.
  20. Oct 24, 2017 at 1:31 PM
    #40
    Chipi3s
    San Diego
    All the people having this issue are you using Manual transmissions? I have 2017 auto and i can hit speed bumps pretty hard and No sound yet, lets hope it stays that way
