Clutch/Shifting Problem - 2006 4 cyl. 4x4 5 Speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stockplus, Dec 27, 2018.
  1. Dec 27, 2018 at 8:42 PM
    stockplus
    stockplus [OP] Well-Known Member
    L.J.
    Way way north of Redding
    06 4x4 SR5 Access Cab
    TC, ToyTec, Boztec, All-Pro, ATO
    I need some guidance from you gurus on what this could be:
    2006 4 cyl. 4x4 manual, 84K, owned since new. Weather here in W. Oregon isn't too cold (40s +)
    A few weeks ago I was taking my son to practice and suddenly I couldn't shift into gear at an intersection. Clutch pedal felt normal, everything seemed fine, I just couldn't shift out of neutral and into gear with the engine running. By starting and stopping the engine, I was able to get out of the intersection and onto a side street. I did some more of this and eventually I was able to start pushing it into gear without much clashing...and by the time I got home (about 5 miles away), it was shifting more or less normally.
    Since then, I have been driving it without much incident about 10-20 miles a day for the last few weeks. Today I started having the issue where I couldn't shift into gear again. I've learned to sort of coast and feel when I can shift it into gear again, and I am able to get around without much issue. The difficulty of getting it into gear changes over time. Sometimes it feels completely normal, other times it's impossible...all within the span of a few minutes of driving.
    The main symptom besides not being able to shift reliably, is that I hear a "slushy", faint grinding sound when the clutch pedal is IN. There are a few light squeaky sounds here and there, some rattling, etc. When I let the clutch OUT, the noise stops completely.
    This has never been a great feeling clutch pedal, and it has squeaked off and on since the first year I bought it. Nevertheless, I haven't ever had a rig where there was a clutch problem and it acted inconsistently like this. Normally it just breaks. What could be the problem here?
    Thanks!
  2. Dec 28, 2018 at 4:17 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It sounds like your clutch is broken, or more specifically the pressure plate.
    stockplus[OP] and MY50cal like this.
  3. Dec 28, 2018 at 5:02 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    :pccoffee:
    Before you dive into replacing stuff, make sure your clutch is properly adjusted, and bleed the system.
    The noise you're hearing with the pedal depressed is the pilot bearing, I'm guessing it's smoked. The shifting issue sounds like a worn/damaged pressure plate.
    Cost of a new clutch kit ranges from $150 - $400; for stock, go with this. Do not get a LUK clutch, there's a history of issues with them. The labor however, will be a lot more ($1000 +/-) if you can't tackle it by yourself. Find a local machine shop and have the flywheel resurfaced at the same time, usually runs around $70 +/-.
    Here's a few thread/info links:
    R-155 manual transmission information
    Replacement Clutch Recommendations
    Better clutch for 2TR thread - a nice R&R write-up by @allmotorrex is on page 3, post #42
    lo2hi, stockplus[OP] and Jimmyh like this.
  4. Dec 28, 2018 at 8:10 AM
    stockplus
    L.J.
    Thanks for the help guys!!!
