CODE P2441!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DRDANTDC, Oct 12, 2015.
  1. Oct 26, 2015 at 3:48 PM
    #41
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    This is for Tundra Trucks. Anyone has a Tundra emblem I can borrow?
  2. Oct 26, 2015 at 6:15 PM
    #42
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    12' Tacoma's suffer from the same issue that the Tundra's did with water messing up the pump. If you listen to a 13' up tacoma when the truck is shut off the pump will activate to evacuate and residual moisture. Toyota's answer to the moisture problem in the pumps, wish the 12' pumps did this, I to had the same code. Should very well be covered under the emissions warranty I would think like others stated. Mine happened when I was under the 3/36k warranty. Good luck op and stay on them to fix it, Toyota knows they have an issue with these pumps.
  3. Oct 26, 2015 at 6:44 PM
    #43
    billybob50
    Bob
    The pump intake should be drawing in good clean air from where the air filter is located. Instead it's drawing air from all the road debris, road salt, and water. If the system is currently working and your warrenty is up. I suggest everyone to consider in getting a Hewitt by-pass kit. It's design to let the ECM know the secondary air injection pump & valve are operational, but it disables this system from running. https://www.hewitt-tech.com/store/
    Torspd likes this.
  4. Oct 27, 2015 at 9:51 AM
    #44
    DRDANTDC
    DRDANTDC [OP] Active Member
    DAN
    ENUMCLAW WA
    TRD OFFROAD
    3" Toytec lift,spidertrax wheel spacers.
    just spoke to corporate....they are doing a One Time coverage. So I'm good this time!
    STEVECBR929RR and Blacktaco2042 like this.
  5. Oct 27, 2015 at 1:12 PM
    #45
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Awesome to hear! This can be an expensive fix so glad to see Toyota is picking up the tab for you.
  6. Oct 28, 2015 at 1:57 PM
    #46
    Large
    Large Red
    Already posted that, it was ignored lol
  7. Apr 10, 2017 at 7:38 AM
    #47
    Bwthomas77
    Bwthomas77 Well-Known Member
    North Carolina
    12 dbl cab trd sport 6spd
    Supercharger, flowmaster exhaust, 4runner disc brakes, Volant CAI, ECGS bushing
    Realize this is an old thread, but just wanted to give an update as I got the P2441 CEL code over the weekend on my 2012 Taco.
    I just got out of the dealership.
    They diagnosed it as the valves, not the pump. Pump would be covered under power train warranty, valves are under the 3 year emissions warranty. Unless you are in California (which unfortunately I am not) then it falls under the 8 year emissions warranty.
    Parts are 700 and change, double it with labor. I called the national customer service line and they confirmed what the dealership told me. They did say they will try and work to get me a discount. I pick it up tomorrow, so we'll see.
    Anyhow, hope that gives some clarification for anyone else that runs into this thread.
  8. May 21, 2018 at 8:40 PM
    #48
    jbandt
    jbandt Well-Known Member
    Hi guys,
    Reviving this thread before starting a new one.
    Got p2441 last week. Changed what i believe was the vacuum switching valve (VSV). Reset codes after several days of waiting for them to turn off by themselves. After a day lights are back on (ck enging & trac off). Research would suggest the air switching valves are the next item to check. Just wanted to see if there was anything else to check or a way to determine for sure its the air switching valves. Thanks for any help.
  9. Mar 16, 2019 at 6:11 AM
    #49
    STEVECBR929RR
    STEVECBR929RR STEVECBR929RR
    STEVE
    CONNECTICUT
    06 TACOMA DBL CAB SR5 TRD
    black nerf bars, AVS in channel rain guards
    My 2012 Tacoma with 94k miles had this code. Both the CEL & TRAC lights were on. At first dealer said it was not covered and would be $1,100 to repair stating that the air injection pump needed to be replaced. I mentioned some of the comments in this post and the similar Tundra issue that Toyota is extending the warranty to cover. The service writer at the dealer called Toyota and they agreed to cover it! It cost me ZERO to have this fixed. Thanks guys!
  10. Mar 16, 2019 at 6:24 AM
    #50
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Please read through this. Certain 2012 models. 10 years, regardless of mileage.
  11. Aug 8, 2019 at 1:38 PM
    #51
    2012_Tacoma_in_MS
    2012_Tacoma_in_MS New Member
    HAVOC, thank you for posting that Dealer Letter! I think you may have just saved me a couple grand$$ Dealer service scheduled for Monday!
  12. Jan 8, 2020 at 10:55 AM
    #52
    JimB0830
    JimB0830 New Member
    Jim
    Alabama
    22 Tacoma TRD Sport
    Have the same P2441 code on my 2012 Tacoma..dealer said to be covered by Toyota it would have to throw a P2440, 2443 or 2445. The difference is valve stuck open or closed. Called customer service and made my case. After review they made a good will offer to pay half. Can't give reason why program only covers valve stuck open and not closed. Bottom line the system has to be replaced either way..so why not be a stand up company and cover the repair.
  13. Jan 8, 2021 at 1:00 PM
    #53
    danielsthomas57
    danielsthomas57 Well-Known Member
    Thomas
    Virginia
    2013 Super White TRD Sport DCLB
    5100s, OME 887 and 1/4" pacer, 285/75/17s
    I just had this code hit on my 2013 Tacoma. I’m currently in the outer banks,nc and I live in Richmond va. Can I drive home on this?
  14. Jan 9, 2021 at 6:57 AM
    #54
    Soylent Green2012
    Soylent Green2012 RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    I recently had been having intermittent codes and all was looking like the Switching valve
    was failing. Took the advise on this forum and took it to the dealer Toyota of Orlando.
    They ran the VIN and told me the Campaign for the SAIS failures were covered on my truck.
    2012 4.0 Prerunner 83K miles. Both the switching valve assembly and the air pump were replaced
    and did not cost me a penny. This was less than 3 weeks ago.
    My codes were : 2440 and 2442 and limp mode
    saweetlou likes this.
  15. Jan 9, 2021 at 7:05 AM
    #55
    Soylent Green2012
    jake
    Apopka, Florida
    OP Please read my post number 54 it is doable for free.
    The campaign has been extended to cover for 100K miles.
  16. Jul 21, 2021 at 12:33 PM
    #56
    Bravo160
    Bravo160 New Member
    2012 TRD
    Started seeing this code recently and have just been clearing it intermittently to see if the valve would fix itself. No luck. Talking with the dealership now with the warranty update in hand to see if its still covered. (at 9 years so hopefully they will still honor it). They need to see it in person however. Will try and keep the post updated with new info.
  17. Jul 22, 2021 at 8:08 AM
    #57
    danielsthomas57
    Thomas
    Virginia
    Most likely no dice.
  18. Jul 25, 2022 at 12:09 PM
    #58
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    Got the dreaded p2441 on my 2014 TRDOR last week. Called the dealer today. They see the recall, but said I first need to come in for an inspection. Have an appointment for 2 days from now, but I have a few questions for the brain-trust.
    I've already cleared the code. Were it to not return between now and the appointment would that be an issue at inspection?
    I have an aftermarket CAI installed, will that affect their willingness to compete the repair?
    Same question but regarding the uni filter?
  19. Jul 28, 2022 at 9:26 AM
    #59
    powder1134
    No coverage says the all knowing toyota service guy. Said it was only affecting the 3rd gens? I explained that was outright wrong info, got the # for toyota customer service, amd now I gotta raise some hell.
  20. Jul 29, 2022 at 10:18 AM
    #60
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    As far as I know the customer satisfaction campaign/extended warranty for the secondary air system only covered 2012 V6 trucks, 13-15 models were not included.
    powder1134[QUOTED] likes this.
