Combination of Error Codes
Discussion in '1st Gen. Tacomas (1995-2004)' started by brogers, Jul 9, 2010.
  1. Jul 9, 2010 at 12:32 PM
    brogers
    brogers [OP] New Member
    Atlanta
    01 4WD Tacoma 4cyl
    Any ideas about what may be going on here? Thanks for any help! (I also posted this in the Technical section, apologies for posting in multiple forums - not sure which is best for this question).
    2001 Toyota Tacoma 4WD, 4cyl 2.7L, 110 K miles
    The check engine light came on -- codes were P0125 and P1135. I reset the light by disconnecting the battery cable and drove a couple of miles. When the light came back on, a new code appeared P0171, the other codes did not come back up.
    The following was done:
    1. Removed and replaced spark plugs
    2. Cleaned the MAF sensor
    3. Replaced the air filter
    4. Reset the light
    Then I drove the truck, the light came back on, one code: P0125
    1. Replaced the thermostat (actually looked fine)
    2. Replaced the ECT sensor (could that have been in a tougher place to get to?)
    3. Refilled the coolant
    4. Reset the light
    Then drove the truck -- the light came back on, this time only P0171.
    1. Checked for coolant leaks
    2. Found that I had knocked the vacuum line off from the air intake, reconnected it.
    3. Reset the light
    Drove the truck, light came back on. This time all three codes came up: P0125, P1135, P0171.
    Any suggestions for the next step?
  2. Jul 10, 2010 at 8:18 AM
    03redtaco
    03redtaco Well-Known Member
    Richard
    Myrtle Beach SC/ Starke FL
    03 Tacoma Prerunner SR5 DC 3.4L
  3. Jul 10, 2010 at 8:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would replace the air/fuel and O2 sensors.
  4. Jul 10, 2010 at 1:56 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    X2
  5. Jul 31, 2010 at 11:00 AM
    Andruck
    Andruck New Member
    North Carolina
    2001 Tacoma
  6. Oct 25, 2020 at 7:11 PM
    thehadmatter
    thehadmatter Member
    Charlottesville, VA
    2001 EXT CAB SR5 2RZ-FE 5spd 2WD
    I just had this same issue occur and all my diagnostics point to the A/F sensor but part of me wants to smoke test the intake. Should I smoke test or just replace the sensor?
  7. Nov 21, 2020 at 6:36 AM
    thehadmatter
    thehadmatter Member
    Charlottesville, VA
    I smoke tested the intake and found a small leak at the aftermarket PCV hose to my cheap Chinese oil catch can. If you spend over $30 (shipping included) on a catch can then you're wasting your money. I tightened up that hose, cleared codes, and test drove. The lean code went away but the coolant temp and A/F codes came back. Replaced A/F sensor Denso part number 234-4189, Toyota part number 89465-09330, cleared codes, test drove and the cel remained off. Truck ran better too. Be prepared for seized/corroded fasteners holding the A/F sensor in place and have M8x1.25 COPPER flange nuts to replace the fasteners that are in place. You may have to grind or torch them off. Good luck and happy torching!
  8. Nov 21, 2020 at 5:09 PM
    Thomas670
    Thomas670 Well-Known Member
    2002 Taco Regular 5 speed
    P1135 is the air and fuel sensor. get denso brand i learned my lesson buy cheap brand ones
