Complete list of tools, sockets and wrenches for 2nd Gen Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, May 22, 2011.
  1. Dec 31, 2014 at 11:10 AM
    #81
    bbersanti
    bbersanti Well-Known Member
    Ben
    Arvada, CO
    2011 Access TRD Offroad 4.0 V6, 6-spd
    Weathertech's, All-Pro APEX Front Bumper, Maglite seat mount, Fog Light Anytime, Aux Blue Sea Fuse Box, Toyota Bed Mat, color-match grille, 21" LED bumper Light bar, Redline Hood Struts, Full OME 3" Lift
    Great thread, sub'd
  2. Dec 31, 2014 at 11:29 AM
    #82
    TugBoatTrash
    TugBoatTrash Face first!! Hammer down!!!
    Bob
    E. Freetown MA
    15 DC Tundra SR5
    Do dents and scratches count?
  3. Dec 31, 2014 at 1:22 PM
    #83
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  4. Dec 31, 2014 at 3:00 PM
    #84
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    nice, those are awfully handy and on some jobs, the ratcheting box end is a life saver...
    jowybyo likes this.
  5. Dec 31, 2014 at 3:14 PM
    #85
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
    Better to have it and not need it .... Then to need it and not have it !
  6. Dec 31, 2014 at 3:20 PM
    #86
    george3
    New Jersey
    Thanks.
  7. Dec 31, 2014 at 5:26 PM
    #87
    NmBeefTaco
    NmBeefTaco Well-Known Member
    Greg
    New Mexico
    18 TRD Off Road Access Cab
    Toytec Boss lift, AAL, Ride rite air bags, Daystar cradles, Total Chaos UCA, Icon 17 inch Rebounds, 285/70R17 BFG KO2s, Ruff country 30” LED light bar kit, ruff country tri fold bed cover. Interior LED lighting and lic./reverse LED lights.
  8. Jan 1, 2015 at 10:57 AM
    #88
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    heres a couple that are missing. needed for front diff removal.
    10mm allen
    12mm allen
    E14 interior torque
    also good to have:
    dead blow hammer
    5lb sledge hammer
    pry bar
    and maybe update the 35mm axle nut socket to 35/36 because either one works. i forget which size socket i have, but sears carries one size and not the other
  9. Jan 1, 2015 at 11:01 AM
    #89
    BamaToy1997
    Bill
    Navarre, FL
    FIFY
  10. Jan 1, 2015 at 11:06 AM
    #90
    JLink
    Josh
    Ocean, NJ
    thanks. i didn't type it. copied and pasted from east coast gear supply's website.
  11. Jan 1, 2015 at 1:41 PM
    #91
    nealkas
    nealkas Well-Known Member
    nealkas
    Pee-Ay
    08 Superwhite DCSB 4x4, stock.
    I'm somewhere in the middle.
    Decent set of general tools and supplies is fine for general driving.
    But the take everything mindset can be a headache.
    Where do you stop?
    Oxy-Acet set, 20-ton press,...a lathe? Spare engine?
    There are certainly times for that approach.
    Traveling Pros, being way in the boonies, extended trips.
    But I don't want to take 600lbs and 20 grand in tools every time I run for milk.
  12. Jan 1, 2015 at 2:15 PM
    #92
    hetkind
    Howard
    Johnson City
    Five pound sledge? I have 4 pound hand drill hammer, 4 pound engineers hammer, and sledges in the following sizes 6, 8, 10, 12, and 16. A 20 would complete the set, but it would be a bear to swing for too long.
    I think a 4lb hand drill hammer would be just about right and easy to swing in tight places. On the other hand, a 2lb ball peen has been in my tool kit since about day 1.
    As for tools on the road, I carry a hilift, 20' of 3/8 logging chain, recovery strap, screwdrives, water pump pliers, dykes, needlenose and cresent wrench. The rollway stays at home. The last time I needed a tool from the truck it was for a stuck file cabinet at work...
    Howard
  13. Jan 1, 2015 at 4:21 PM
    #93
    BamaToy1997
    Bill
    Navarre, FL
    Certainly there are limits to that concept. However as a pro-wheeler I learned that as you build your truck, and your wheeling group, you have to build your gear to go with it. Basic trail rides typically require basic tools, however there are times when if you DO have the gear, it is a good idea to bring it. Case-in-point, several years ago my trail rig was a decent-built 1987 Pathfinder. I had a full oxy-acetelyne kit, and a portable welder kit.
    I got teased a bit when we were out on the weekend runs in Ocala National Forest for always bringing all this stuff on the trail. One time a guy got a little crazy and ended up bending both of his inner tie rods. We were well off the beaten path, and it would have taken several hours to drive into town and hope that the parts stores not only had the parts, but the special tool needed to replace the inner tie rods. This essentially would have ruined the who day.
    Fortunately I was able to break out the oxy-kit, remove the inner boots, lay out the welding blanket, and heat the tie rods, one at a time, while we strapped the truck to a tree on one side, and a winch pulled from the other. Took about 45 minutes and we had him field-repaired enough to get him home. So we parked his truck and the rest of us were able to finish an enjoyable day while he rode with a friend.
    Obviously you can't carry for every single possible failure, but when it comes to TOOLS, you can't bring too many of them. Especially when you wheel with more than just Toyota trucks.
  14. Jan 4, 2015 at 9:25 AM
    #94
    JLink
    Josh
    Ocean, NJ
    Yea a portable welder like the ready welder for like $600 seems like it could be a life saver.
    twotwentyswift likes this.
  15. Jan 4, 2015 at 10:44 AM
    #95
    Mudman
    Mudman Well-Known Member
    Cerritos
    08 4X4 TRD Sport
    Very useful info, Thanks.
  16. Jan 4, 2015 at 3:11 PM
    #96
    jmich2001
    jmich2001 Well-Known Member
    Toms River, NJ
    12 Access Cab TRD OR
    Yellow Fog Lamps, Ham Radio
    Plugs are 5/8th. also need long 12" extension for plug change. I would also advise the allen wrench for the tranny check plug
  17. Jan 4, 2015 at 4:34 PM
    #97
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
  18. Jan 4, 2015 at 8:36 PM
    #98
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Depending on your needs, either a Pickle Fork, or one of those big Screwdriver type things with the wide end that is bent (not sure of the name, but you can pry, scrape etc with them). For long trips I also agree with the RediWelder...our club bought one and we also take at least one on every BAJA trip...the welder gets used often enough to include it. For misc. stuff other than the normal tape, wire etc, a pack of the two part epoxy putty is a life saver in many areas.
  19. Jan 5, 2015 at 4:16 AM
    #99
    nealkas
    nealkas
    Pee-Ay
    I have to laugh because I just updated my old emt pack again. (I do it every six months.)
    I have a 6-pack of O2 tanks, 3 separate regulators and masks, IV kits, 6 different bp cuffs(handy to control some types of bleeding), gowns, masks, gloves, blankets, knives, flashlights, and enough other assorted junk to open a small clinic.
    No narcs for any junkies reading this out there. I turned my kit back in so as not to worry about it.
    What is funny is I don't even work ems anymore.
    But having that stuff with me is my security blanket. :eek:
  20. Jan 8, 2015 at 8:22 PM
    #100
    Greddy
    Greddy Would you eat the moon if it were made of ribs?
    Cam
    Bonney Lake, WA
    It's a Tacoma, white n black, DCLB
    Front & Rear HC Bumper with Swing Out, Full Skids, Icon CO's and UCA's, Dakar w/AAL, Icon Rear Shocks and U-bolt flip, w/Superbumps. 17" XD Wheels, 34" BFG KM3s, CB/Ham Radio, 10% Tint, Snugtop, WeatherTech Mats and Deflectors, Rigid Fog Lights, UltraGauge, TRD Seatcovers, On-Board CO2 and 20L fuel. Roof Top Tent. AirFlow Snork, smittybilt winch, 20" light bar.
    I like what you did here. I'll be using this to make sure i have everything i need. Nice work!
    Crom[OP] likes this.
